Official File parts/55967.dat
0 ~Electric Mindstorms NXT Touch Sensor Shell Front (Needs Work)
0 Name: 55967.dat
0 Author: Steve Bliss [sbliss]
0 !LDRAW_ORG Part UPDATE 2012-01
0 !HISTORY 2006-12-03 [kclague] filled in the inside walls of the shell
0 !HISTORY 2007-10-23 [Philo] drilled button hole
0 !HISTORY 2012-01-13 [Steffen] added missing edges
0 // Needs work: Internal structure should be modelled
4 16 16 -26 0 -16 -26 0 -16 -26 -29 16 -26 -29
1 16 16 -16 -29 10 0 0 0 0 -10 0 29 0 1-4cyli.dat
1 16 16 -16 -29 7 0 0 0 0 -7 0 29 0 1-4cyli.dat
4 16 26 -16 0 26 -16 -29 26 18 -29 26 18 0
1 16 16 18 -29 0 0 10 10 0 0 0 29 0 1-4cyli.dat
1 16 16 18 -29 0 0 7 7 0 0 0 29 0 1-4cyli.dat
4 16 -16 28 0 16 28 0 16 28 -29 -16 28 -29
1 16 -16 18 -29 -10 0 0 0 0 10 0 29 0 1-4cyli.dat
1 16 -16 18 -29 -7 0 0 0 0 7 0 29 0 1-4cyli.dat
4 16 -26 18 0 -26 18 -29 -26 -16 -29 -26 -16 0
1 16 -16 -16 -29 0 0 -10 -10 0 0 0 29 0 1-4cyli.dat
1 16 -16 -16 -29 0 0 -7 -7 0 0 0 29 0 1-4cyli.dat
1 16 16 18 -29 0 10 0 10 0 0 0 0 -10 1-8sphe.dat
1 16 -16 18 -29 -10 0 0 0 10 0 0 0 -10 1-8sphe.dat
1 16 -16 -16 -29 0 -10 0 -10 0 0 0 0 -10 1-8sphe.dat
1 16 16 -16 -29 10 0 0 0 -10 0 0 0 -10 1-8sphe.dat
0 // The back wall
1 16 24.5 1 0 0 0 -1.5 -17 0 0 0 -1 0 rect2p.dat
1 16 -24.5 1 0 0 0 -1.5 -17 0 0 0 -1 0 rect2p.dat
1 16 0 -24.5 0 -16 0 0 0 0 1.5 0 -1 0 rect2p.dat
1 16 11 26.5 0 0 0 -5 -1.5 0 0 0 -1 0 rect3.dat
1 16 -11 26.5 0 0 0 5 1.5 0 0 0 -1 0 rect3.dat
1 16 0 26.5 10 0 0 5.5 1.5 0 0 0 -1 0 rect.dat
1 16 16 -16 0 1 0 0 0 0 -1 0 -1 0 1-4ring7.dat
1 16 16 -16 0 2 0 0 0 0 -2 0 -1 0 1-4ring4.dat
1 16 16 -16 0 7 0 0 0 0 -7 0 -1 0 1-4edge.dat
1 16 16 18 0 0 0 1 1 0 0 0 -1 0 1-4ring7.dat
1 16 16 18 0 0 0 2 2 0 0 0 -1 0 1-4ring4.dat
1 16 -16 -16 0 0 0 -7 -7 0 0 0 1 0 1-4edge.dat
1 16 -16 18 0 -1 0 0 0 0 1 0 -1 0 1-4ring7.dat
1 16 -16 18 0 -2 0 0 0 0 2 0 -1 0 1-4ring4.dat
1 16 -16 18 0 -7 0 0 0 0 7 0 -1 0 1-4edge.dat
1 16 -16 -16 0 0 0 -1 -1 0 0 0 -1 0 1-4ring7.dat
1 16 -16 -16 0 0 0 -2 -2 0 0 0 -1 0 1-4ring4.dat
1 16 16 18 0 0 0 7 7 0 0 0 1 0 1-4edge.dat
1 16 16 -16 0 10 0 0 0 0 -10 0 29 0 1-4edge.dat
1 16 16 18 0 0 0 10 10 0 0 0 29 0 1-4edge.dat
1 16 -16 -16 0 -10 0 0 0 0 -10 0 -29 0 1-4edge.dat
1 16 -16 18 0 0 0 -10 10 0 0 0 -29 0 1-4edge.dat
0 // The inside walls
1 16 16 18 -29 10 0 0 0 -16.25 0 0 0 -10 1-4cyli.dat
1 16 16 -16 -29 10 0 0 0 14.25 0 0 0 -10 1-4cyli.dat
1 16 -16 18 -29 -10 0 0 0 -16.25 0 0 0 -10 1-4cyli.dat
1 16 -16 -16 -29 -10 0 0 0 14.25 0 0 0 -10 1-4cyli.dat
1 16 16 -16 -29 0 -14.25 0 -10 0 0 0 0 -10 1-4cyli.dat
1 16 -16 -16 -29 0 14.25 0 -10 0 0 0 0 -10 1-4cyli.dat
1 16 16 18 -29 0 -14.25 0 10 0 0 0 0 -10 1-4cyli.dat
1 16 -16 18 -29 0 14.25 0 10 0 0 0 0 -10 1-4cyli.dat
1 16 16 1.75 -29 10 0 0 0 -3.5 0 0 0 -10 1-8cyli.dat
1 16 -1.75 18 -29 0 3.5 0 10 0 0 0 0 -10 1-8cyli.dat
1 16 -16 -1.75 -29 -10 0 0 0 3.5 0 0 0 -10 1-8cyli.dat
1 16 1.75 -16 -29 0 -3.5 0 -10 0 0 0 0 -10 1-8cyli.dat
1 16 16 1.75 -29 7.07107 0 -7.07107 0 -3.5 0 -7.07107 0 -7.07107 1-8edge.dat
1 16 16 -1.75 -29 7.07107 0 -7.07107 0 -3.5 0 -7.07107 0 -7.07107 1-8edge.dat
1 16 -16 1.75 -29 -7.07107 0 7.07107 0 -3.5 0 -7.07107 0 -7.07107 1-8edge.dat
1 16 -16 -1.75 -29 -7.07107 0 7.07107 0 -3.5 0 -7.07107 0 -7.07107 1-8edge.dat
2 24 23.07 1.75 -36.07 23.07 -1.75 -36.07
2 24 -23.07 1.75 -36.07 -23.07 -1.75 -36.07
4 16 23 18 0 23 18 -29 23 -16 -29 23 -16 0
4 16 -23 -16 0 -23 -16 -29 -23 18 -29 -23 18 0
4 16 16 -23 -29 -16 -23 -29 -16 -23 0 16 -23 0
4 16 -16 25 -29 16 25 -29 16 25 0 -16 25 0
2 24 -5.5 28 10 -6 28 0
4 16 -5.5 28 10 -6 28 0 -6 25 0 -5.5 25 10
2 24 -5.5 25 10 -6 25 0
2 24 5.5 25 10 6 25 0
4 16 5.5 25 10 6 25 0 6 28 0 5.5 28 10
2 24 5.5 28 10 6 28 0
4 16 5.5 28 10 6 28 0 -6 28 0 -5.5 28 10
4 16 -5.5 25 10 -6 25 0 6 25 0 5.5 25 10
1 16 -14.385 1.75 -34 0 0 1.615 0 1 0 -5 0 0 rect3.dat
1 16 -14.385 -1.75 -34 0 0 1.615 0 -1 0 -5 0 0 rect3.dat
1 16 -1.75 -14.385 -34 0 -1 0 0 0 1.615 -5 0 0 rect3.dat
1 16 1.75 -14.385 -34 0 1 0 0 0 1.615 -5 0 0 rect3.dat
1 16 14.385 -1.75 -34 0 0 -1.615 0 -1 0 -5 0 0 rect3.dat
1 16 14.385 1.75 -34 0 0 -1.615 0 1 0 -5 0 0 rect3.dat
1 16 -1.75 15.385 -34 0 -1 0 0 0 -2.615 -5 0 0 rect3.dat
1 16 1.75 15.385 -34 0 1 0 0 0 -2.615 -5 0 0 rect3.dat
0 // front
4 16 12.77 -1.75 -39 12.13 -5.02 -39 12.13 -5.02 -29 12.77 -1.75 -29
4 16 12.13 -5.02 -39 9.28 -9.28 -39 9.28 -9.28 -29 12.13 -5.02 -29
5 24 12.13 -5.02 -39 12.13 -5.02 -29 9.28 -9.28 -39 13.12 0 -39
4 16 9.28 -9.28 -39 5.02 -12.13 -39 5.02 -12.13 -29 9.28 -9.28 -29
5 24 9.28 -9.28 -39 9.28 -9.28 -29 5.02 -12.13 -39 12.13 -5.02 -39
4 16 5.02 -12.13 -39 1.75 -12.77 -39 1.75 -12.77 -29 5.02 -12.13 -29
5 24 5.02 -12.13 -39 5.02 -12.13 -29 0 -13.12 -39 9.28 -9.28 -39
2 24 12.77 -1.75 -39 12.13 -5.02 -39
2 24 12.13 -5.02 -39 9.28 -9.28 -39
2 24 9.28 -9.28 -39 5.02 -12.13 -39
2 24 5.02 -12.13 -39 1.75 -12.77 -39
4 16 16 -1.75 -39 16 -16 -39 12.13 -5.02 -39 12.77 -1.75 -39
3 16 16 -16 -39 9.28 -9.28 -39 12.13 -5.02 -39
3 16 16 -16 -39 5.02 -12.13 -39 9.28 -9.28 -39
4 16 16 -16 -39 1.75 -16 -39 1.75 -12.77 -39 5.02 -12.13 -39
4 16 -1.75 -12.77 -39 -5.02 -12.13 -39 -5.02 -12.13 -29 -1.75 -12.77 -29
4 16 -5.02 -12.13 -39 -9.28 -9.28 -39 -9.28 -9.28 -29 -5.02 -12.13 -29
5 24 -5.02 -12.13 -39 -5.02 -12.13 -29 -9.28 -9.28 -39 0 -13.12 -39
4 16 -9.28 -9.28 -39 -12.13 -5.02 -39 -12.13 -5.02 -29 -9.28 -9.28 -29
5 24 -9.28 -9.28 -39 -9.28 -9.28 -29 -12.13 -5.02 -39 -5.02 -12.13 -39
4 16 -12.13 -5.02 -39 -12.77 -1.75 -39 -12.77 -1.75 -29 -12.13 -5.02 -29
5 24 -12.13 -5.02 -39 -12.13 -5.02 -29 -13.12 0 -39 -9.28 -9.28 -39
2 24 -1.75 -12.77 -39 -5.02 -12.13 -39
2 24 -5.02 -12.13 -39 -9.28 -9.28 -39
2 24 -9.28 -9.28 -39 -12.13 -5.02 -39
2 24 -12.13 -5.02 -39 -12.77 -1.75 -39
4 16 -1.75 -16 -39 -16 -16 -39 -5.02 -12.13 -39 -1.75 -12.77 -39
3 16 -16 -16 -39 -9.28 -9.28 -39 -5.02 -12.13 -39
3 16 -16 -16 -39 -12.13 -5.02 -39 -9.28 -9.28 -39
4 16 -16 -16 -39 -16 -1.75 -39 -12.77 -1.75 -39 -12.13 -5.02 -39
4 16 1.75 12.77 -39 5.02 12.13 -39 5.02 12.13 -29 1.75 12.77 -29
4 16 5.02 12.13 -39 9.28 9.28 -39 9.28 9.28 -29 5.02 12.13 -29
5 24 5.02 12.13 -39 5.02 12.13 -29 9.28 9.28 -39 0 13.12 -39
4 16 9.28 9.28 -39 12.13 5.02 -39 12.13 5.02 -29 9.28 9.28 -29
5 24 9.28 9.28 -39 9.28 9.28 -29 12.13 5.02 -39 5.02 12.13 -39
4 16 12.13 5.02 -39 12.77 1.75 -39 12.77 1.75 -29 12.13 5.02 -29
5 24 12.13 5.02 -39 12.13 5.02 -29 13.12 0 -39 9.28 9.28 -39
2 24 1.75 12.77 -39 5.02 12.13 -39
2 24 5.02 12.13 -39 9.28 9.28 -39
2 24 9.28 9.28 -39 12.13 5.02 -39
2 24 12.13 5.02 -39 12.77 1.75 -39
4 16 1.75 18 -39 16 18 -39 5.02 12.13 -39 1.75 12.77 -39
3 16 16 18 -39 9.28 9.28 -39 5.02 12.13 -39
3 16 16 18 -39 12.13 5.02 -39 9.28 9.28 -39
4 16 16 18 -39 16 1.75 -39 12.77 1.75 -39 12.13 5.02 -39
4 16 -1.75 12.77 -29 -5.02 12.13 -29 -5.02 12.13 -39 -1.75 12.77 -39
4 16 -5.02 12.13 -29 -9.28 9.28 -29 -9.28 9.28 -39 -5.02 12.13 -39
5 24 -5.02 12.13 -39 -5.02 12.13 -29 -9.28 9.28 -39 0 13.12 -39
4 16 -9.28 9.28 -29 -12.13 5.02 -29 -12.13 5.02 -39 -9.28 9.28 -39
5 24 -9.28 9.28 -39 -9.28 9.28 -29 -12.13 5.02 -39 -5.02 12.13 -39
4 16 -12.13 5.02 -29 -12.77 1.75 -29 -12.77 1.75 -39 -12.13 5.02 -39
5 24 -12.13 5.02 -39 -12.13 5.02 -29 -13.12 0 -39 -9.28 9.28 -39
2 24 -1.75 12.77 -39 -5.02 12.13 -39
2 24 -5.02 12.13 -39 -9.28 9.28 -39
2 24 -9.28 9.28 -39 -12.13 5.02 -39
2 24 -12.13 5.02 -39 -12.77 1.75 -39
4 16 -1.75 12.77 -39 -5.02 12.13 -39 -16 18 -39 -1.75 18 -39
3 16 -5.02 12.13 -39 -9.28 9.28 -39 -16 18 -39
3 16 -9.28 9.28 -39 -12.13 5.02 -39 -16 18 -39
4 16 -12.13 5.02 -39 -12.77 1.75 -39 -16 1.75 -39 -16 18 -39
0 // slit sides
4 16 23 1.75 -29 23.071 1.75 -36.071 23.071 -1.75 -36.071 23 -1.75 -29
4 16 -23 -1.75 -29 -23.071 -1.75 -36.071 -23.071 1.75 -36.071 -23 1.75 -29
1 16 -16 1.75 -29 0 0 -10 0 1 0 -10 0 0 1-8chrd.dat
4 16 -23.071 -1.75 -36.071 -23 -1.75 -25 -16 -1.75 -29 -16 -1.75 -39
1 16 -16 -1.75 -29 0 0 -10 0 -1 0 -10 0 0 1-8chrd.dat
4 16 -16 1.75 -39 -16 1.75 -29 -23 1.75 -25 -23.071 1.75 -36.071
1 16 16 1.75 -29 0 0 10 0 1 0 -10 0 0 1-8chrd.dat
4 16 16 -1.75 -39 16 -1.75 -29 23 -1.75 -25 23.071 -1.75 -36.071
1 16 16 -1.75 -29 0 0 10 0 -1 0 -10 0 0 1-8chrd.dat
4 16 23.071 1.75 -36.071 23 1.75 -25 16 1.75 -29 16 1.75 -39
4 16 -1.75 -16 -39 -1.75 -16 -29 -1.75 -22 -25 -1.75 -22.05 -36.753
4 16 1.75 -16 -29 1.75 -16 -39 1.75 -22.05 -36.753 1.75 -22 -25
4 16 -1.75 18 -29 -1.75 18 -39 -1.75 24.05 -36.753 -1.75 24 -25
4 16 1.75 18 -39 1.75 18 -29 1.75 24 -25 1.75 24.05 -36.753
4 16 1.75 -22 -25 1.75 -22.071 -36.753 -1.75 -22.071 -36.753 -1.75 -22 -25
2 24 -1.75 -22.048 -36.753 1.75 -22.048 -36.753
3 16 -1.75 -19.827 -38.239 -1.75 -16 -39 -1.75 -22.05 -36.753
2 24 -1.75 -22.05 -36.753 -1.75 -22 -25
2 24 -1.75 -16 -39 -1.75 -19.827 -38.239
2 24 -1.75 -22.05 -36.753 -1.75 -19.827 -38.239
3 16 1.75 -22.05 -36.753 1.75 -16 -39 1.75 -19.827 -38.239
2 24 1.75 -22.05 -36.753 1.75 -22 -25
2 24 1.75 -16 -39 1.75 -19.827 -38.239
2 24 1.75 -22.05 -36.753 1.75 -19.827 -38.239
4 16 -1.75 24 -25 -1.75 24.071 -36.753 1.75 24.071 -36.753 1.75 24 -25
2 24 -1.75 24.048 -36.753 1.75 24.048 -36.753
2 24 -1.75 24.05 -36.753 -1.75 24 -25
3 16 -1.75 24.05 -36.753 -1.75 18 -39 -1.75 21.827 -38.239
2 24 -1.75 18 -39 -1.75 21.827 -38.239
2 24 -1.75 24.05 -36.753 -1.75 21.827 -38.239
2 24 1.75 24.05 -36.753 1.75 24 -25
2 24 1.75 18 -39 1.75 21.827 -38.239
2 24 1.75 24.05 -36.753 1.75 21.827 -38.239
4 16 -1.75 -22.048 -36.753 1.75 -22.048 -36.753 1.75 -23.071 -36.071 -1.75 -23.071 -36.071
4 16 -1.75 25.071 -36.071 1.75 25.071 -36.071 1.75 24.048 -36.753 -1.75 24.048 -36.753
2 24 12.77 -1.75 -31 12.77 -1.75 -39
2 24 1.75 -12.77 -39 1.75 -12.77 -31
2 24 12.77 -1.75 -39 16 -1.75 -39
2 24 1.75 -16 -39 1.75 -12.77 -39
2 24 -1.75 -12.77 -31 -1.75 -12.77 -39
2 24 -12.77 -1.75 -39 -12.77 -1.75 -31
2 24 -1.75 -12.77 -39 -1.75 -16 -39
2 24 -16 -1.75 -39 -12.77 -1.75 -39
2 24 1.75 12.77 -31 1.75 12.77 -39
2 24 12.77 1.75 -39 12.77 1.75 -31
2 24 1.75 12.77 -39 1.75 18 -39
2 24 16 1.75 -39 12.77 1.75 -39
2 24 -1.75 12.77 -39 -1.75 12.77 -31
2 24 -12.77 1.75 -31 -12.77 1.75 -39
2 24 -1.75 18 -39 -1.75 12.77 -39
2 24 -12.77 1.75 -39 -16 1.75 -39
2 24 23.071 1.75 -36.071 23.071 -1.75 -36.071
2 24 23.071 1.75 -36.071 23 1.75 -25
2 24 -23.071 -1.75 -36.071 -23.071 1.75 -36.071
2 24 -23.071 -1.75 -36.071 -23 -1.75 -25
2 24 -23 -1.75 -25 -16 -1.75 -29
2 24 -16 1.75 -29 -23 1.75 -25
2 24 -23 1.75 -25 -23.071 1.75 -36.071
2 24 16 -1.75 -29 23 -1.75 -25
2 24 23 -1.75 -25 23.071 -1.75 -36.071
2 24 23 1.75 -25 16 1.75 -29
2 24 -1.75 -16 -29 -1.75 -22 -25
2 24 1.75 -22 -25 1.75 -16 -29
2 24 -1.75 24 -25 -1.75 18 -29
2 24 1.75 18 -29 1.75 24 -25
2 24 1.75 -22 -29 1.75 -22.071 -36.753
2 24 -1.75 -22.071 -36.753 -1.75 -22 -29
2 24 -1.75 -22 -25 1.75 -22 -25
2 24 -1.75 -22.048 -36.495 -1.75 -22.05 -36.753
2 24 1.75 -22.05 -36.753 1.75 -22.048 -36.495
2 24 -1.75 24 -29 -1.75 24.071 -36.753
2 24 1.75 24.071 -36.753 1.75 24 -29
2 24 1.75 24 -25 -1.75 24 -25
2 24 -1.75 24.05 -36.753 -1.75 24.048 -36.495
2 24 1.75 24.048 -36.495 1.75 24.05 -36.753
2 24 12.13 -5.02 -29 12.77 -1.75 -29
2 24 9.28 -9.28 -29 12.13 -5.02 -29
2 24 5.02 -12.13 -29 9.28 -9.28 -29
2 24 1.75 -12.77 -29 5.02 -12.13 -29
2 24 -5.02 -12.13 -29 -1.75 -12.77 -29
2 24 -9.28 -9.28 -29 -5.02 -12.13 -29
2 24 -12.13 -5.02 -29 -9.28 -9.28 -29
2 24 -12.77 -1.75 -29 -12.13 -5.02 -29
2 24 5.02 12.13 -29 1.75 12.77 -29
2 24 9.28 9.28 -29 5.02 12.13 -29
2 24 12.13 5.02 -29 9.28 9.28 -29
2 24 12.77 1.75 -29 12.13 5.02 -29
2 24 -1.75 12.77 -29 -5.02 12.13 -29
2 24 -5.02 12.13 -29 -9.28 9.28 -29
2 24 -9.28 9.28 -29 -12.13 5.02 -29
2 24 -12.13 5.02 -29 -12.77 1.75 -29
3 16 1.75 21.827 -38.239 1.75 18 -39 1.75 24.05 -36.753
Official
