Official File parts/866.dat
Train Track 12V Curved Insert Type 1 (Needs Work)
0 Train Track 12V Curved Insert Type 1 (Needs Work)
0 Name: 866.dat
0 Author: Steffen [Steffen]
0 !HELP The curve elements are rotated around this point (MLCAD Syntax):
0 !HELP 0 ROTATION CENTER -160 0 -800 0 "CURVECENTER"
0 !HELP 0 ROTATION CONFIG 1 1
0 !HELP with a step of 0.5625 degrees
0 !HELP The underside is designed by LEGO in a way which does not fit onto a
0 !HELP plate (sadly): the two center rims prevent that.
0 !CMDLINE -c1
0 // Needs work: underside geometry is still mockup at the prism cutouts at the ends
1 16 -81.586 13.5 -3.854 1.99037 0 1.56827 0 -1.5 0 -0.196034 0 15.923 box.dat
1 16 -3.929 13.5 -15.374 1.96157 0 3.12145 0 -1.5 0 -0.39018 0 15.6926 box.dat
1 16 -9.324 13.5 -14.321 0.982103 0 3.01353 0 -1.5 0 -0.188346 0 15.7136 box.dat
1 16 1.459 13.5 -16.465 0.979421 0 3.22921 0 -1.5 0 -0.201826 0 15.6707 box.dat
1 16 -81.586 12 -3.854 -0.196034 0 1.99037 0 1 0 -1.99037 0 -0.196034 box3u2p.dat
1 16 -3.929 12 -15.374 -0.39018 0 1.96157 0 1 0 -1.96157 0 -0.39018 box3u2p.dat
1 16 -3.929 12 -15.374 -0.390181 0 0.980785 0 1 0 -1.96157 0 -0.19509 box3u2p.dat
1 16 -9.324 12 -14.321 -0.376691 0 0.982103 0 1 0 -1.96421 0 -0.188346 box3u2p.dat
1 16 1.459 12 -16.465 -0.403652 0 0.979421 0 1 0 -1.95884 0 -0.201826 box3u2p.dat
1 16 72.226 13.5 -34.45 1.91388 0 4.64455 0 -1.5 0 -0.580569 0 15.311 box.dat
1 16 72.226 12 -34.45 -0.580569 0 1.91388 0 1 0 -1.91388 0 -0.580569 box3u2p.dat
1 16 -128.592 0 -0.618 0.999229 0 0.0392598 0 1 0 -0.0392598 0 0.999229 s\3241s04.dat
1 16 -120.746 0 -0.965 0.998795 0 0.0490677 0 1 0 -0.0490677 0 0.998795 s\3241s04.dat
1 16 -112.904 0 -1.389 0.998266 0 0.0588708 0 1 0 -0.0588708 0 0.998266 s\3241s04.dat
1 16 -105.066 0 -1.89 0.99764 0 0.0686683 0 1 0 -0.0686683 0 0.99764 s\3241s04.dat
1 16 -97.233 0 -2.468 0.996917 0 0.0784591 0 1 0 -0.0784591 0 0.996917 s\3241s04.dat
1 16 -89.406 0 -3.123 0.996099 0 0.0882424 0 1 0 -0.0882424 0 0.996099 s\3241s04.dat
1 16 -81.586 0 -3.854 0.995185 0 0.0980171 0 1 0 -0.0980171 0 0.995185 s\3241s04.dat
1 16 -73.774 0 -4.662 0.994175 0 0.107782 0 1 0 -0.107782 0 0.994175 s\3241s04.dat
1 16 -65.97 0 -5.547 0.993068 0 0.117537 0 1 0 -0.117537 0 0.993068 s\3241s04.dat
1 16 -58.175 0 -6.508 0.991867 0 0.127281 0 1 0 -0.127281 0 0.991867 s\3241s04.dat
1 16 -50.39 0 -7.546 0.99057 0 0.137012 0 1 0 -0.137012 0 0.99057 s\3241s04.dat
1 16 -42.616 0 -8.66 0.989177 0 0.146731 0 1 0 -0.146731 0 0.989177 s\3241s04.dat
1 16 -34.853 0 -9.851 0.987689 0 0.156435 0 1 0 -0.156435 0 0.987689 s\3241s04.dat
1 16 -27.102 0 -11.118 0.986105 0 0.166123 0 1 0 -0.166123 0 0.986105 s\3241s04.dat
1 16 19.109 0 -20.31 0.974615 0 0.223888 0 1 0 -0.223888 0 0.974615 s\3241s04.dat
1 16 26.755 0 -22.106 0.97237 0 0.233445 0 1 0 -0.233445 0 0.97237 s\3241s04.dat
1 16 34.383 0 -23.977 0.970032 0 0.24298 0 1 0 -0.24298 0 0.970032 s\3241s04.dat
1 16 41.992 0 -25.923 0.967599 0 0.252492 0 1 0 -0.252492 0 0.967599 s\3241s04.dat
1 16 49.582 0 -27.943 0.965074 0 0.261979 0 1 0 -0.261979 0 0.965074 s\3241s04.dat
1 16 11.446 0 -18.589 0.976766 0 0.214309 0 1 0 -0.214309 0 0.976766 s\3241s04.dat
1 16 -19.364 0 -12.461 0.984427 0 0.175797 0 1 0 -0.175797 0 0.984427 s\3241s04.dat
1 16 -11.639 0 -13.88 0.982654 0 0.185453 0 1 0 -0.185453 0 0.982654 s\3241s04.dat
1 16 -3.929 0 -15.374 0.980786 0 0.195091 0 1 0 -0.195091 0 0.980786 s\3241s04.dat
1 16 3.766 0 -16.944 0.978823 0 0.20471 0 1 0 -0.20471 0 0.978823 s\3241s04.dat
1 16 57.151 0 -30.038 0.962455 0 0.27144 0 1 0 -0.27144 0 0.962455 s\3241s04.dat
1 16 64.699 0 -32.207 0.959744 0 0.280876 0 1 0 -0.280876 0 0.959744 s\3241s04.dat
1 16 72.226 0 -34.45 0.95694 0 0.290285 0 1 0 -0.290285 0 0.95694 s\3241s04.dat
1 16 79.73 0 -36.767 0.954044 0 0.299665 0 1 0 -0.299665 0 0.954044 s\3241s04.dat
1 16 87.211 0 -39.157 0.951057 0 0.309017 0 1 0 -0.309017 0 0.951057 s\3241s04.dat
1 16 94.669 0 -41.621 0.947977 0 0.318339 0 1 0 -0.318339 0 0.947977 s\3241s04.dat
1 16 102.102 0 -44.158 0.944806 0 0.32763 0 1 0 -0.32763 0 0.944806 s\3241s04.dat
1 16 109.51 0 -46.768 0.941544 0 0.33689 0 1 0 -0.33689 0 0.941544 s\3241s04.dat
1 16 116.892 0 -49.45 0.938191 0 0.346117 0 1 0 -0.346117 0 0.938191 s\3241s04.dat
2 24 -144 13 2 -144 13 -2
2 24 -144 13 -2 -144 12 -2
2 24 -144 13 2 -144 12 2
1 16 -142 12 0 2 0 0 0 1 0 0 0 -2 box3u8p.dat
2 24 130.599 13 -56.6212 132.13 13 -52.9257
2 24 132.13 13 -52.9257 132.13 12 -52.9257
2 24 130.599 13 -56.6212 130.599 12 -56.6212
1 16 129.518 12 -54.008 -1.84776 0 0.765367 0 1 0 0.765367 0 1.84776 box3u8p.dat
1 16 -160 8 0 1 0 0 0 1 0 0 0 1 s\866s01.dat
1 16 -136.284 0 -0.352 0.999559 0 0.0296935 0 1 0 -0.0296935 0 0.999559 s\3241s07.dat
1 16 -136.284 0 -0.352 -0.999559 0 -0.0296935 0 1 0 0.0296935 0 -0.999559 s\3241s07.dat
1 16 124.398 0 -52.253 0.934661 0 0.35554 0 1 0 -0.35554 0 0.934661 s\3241s07.dat
1 16 124.398 0 -52.253 -0.934661 0 -0.35554 0 1 0 0.35554 0 -0.934661 s\3241s07.dat
1 16 146.147 8 -60.896 -0.92388 0 -0.382683 0 1 0 0.382683 0 -0.92388 s\866s01.dat
2 24 115.273 13 -50.9839 116.804 13 -47.2863
2 24 113.837 12 -50.4541 115.273 13 -50.9839
2 24 115.369 12 -46.7565 116.804 13 -47.2863
2 24 -127.682 13 -2.6548 -127.682 13 1.3474
2 24 -127.682 13 1.3474 -126.153 12 1.28741
2 24 -127.682 13 -2.6548 -126.153 12 -2.71479
1 494 -128.238 12 8.376 -0.999229 0 -0.0392598 0 1 0 0.0392598 0 -0.999229 s\3241s08.dat
1 494 -128.946 12 -9.609 0.999229 0 0.0392598 0 1 0 -0.0392598 0 0.999229 s\3241s08.dat
1 494 -41.295 12 0.243 -0.989176 0 -0.14673 0 1 0 0.14673 0 -0.989176 s\3241s08.dat
1 494 -43.937 12 -17.56 0.989176 0 0.14673 0 1 0 -0.14673 0 0.989176 s\3241s08.dat
1 494 36.57 12 -15.246 -0.970031 0 -0.242981 0 1 0 0.242981 0 -0.970031 s\3241s08.dat
1 494 32.197 12 -32.703 0.970031 0 0.242981 0 1 0 -0.242981 0 0.970031 s\3241s08.dat
1 494 120.008 12 -41.005 -0.938191 0 -0.346117 0 1 0 0.346117 0 -0.938191 s\3241s08.dat
1 494 113.779 12 -57.888 0.938191 0 0.346117 0 1 0 -0.346117 0 0.938191 s\3241s08.dat
    Line 26: 1 16 -9.324 13.5 -14.321 0.982103 0 3.01353 0 -1.5 0 -0.188346 0 15.7136 box.dat
    Line 27: 1 16 1.459 13.5 -16.465 0.979421 0 3.22921 0 -1.5 0 -0.201826 0 15.6707 box.dat
    Line 28: 1 16 -81.586 12 -3.854 -0.196034 0 1.99037 0 1 0 -1.99037 0 -0.196034 box3u2p.dat
    Line 30: 1 16 -3.929 12 -15.374 -0.390181 0 0.980785 0 1 0 -1.96157 0 -0.19509 box3u2p.dat
    Line 31: 1 16 -9.324 12 -14.321 -0.376691 0 0.982103 0 1 0 -1.96421 0 -0.188346 box3u2p.dat
    Line 32: 1 16 1.459 12 -16.465 -0.403652 0 0.979421 0 1 0 -1.95884 0 -0.201826 box3u2p.dat
    Line 34: 1 16 72.226 12 -34.45 -0.580569 0 1.91388 0 1 0 -1.91388 0 -0.580569 box3u2p.dat
    Line 35: 1 16 -128.592 0 -0.618 0.999229 0 0.0392598 0 1 0 -0.0392598 0 0.999229 s\3241s04.dat
    Line 36: 1 16 -120.746 0 -0.965 0.998795 0 0.0490677 0 1 0 -0.0490677 0 0.998795 s\3241s04.dat
    Line 37: 1 16 -112.904 0 -1.389 0.998266 0 0.0588708 0 1 0 -0.0588708 0 0.998266 s\3241s04.dat
    Line 39: 1 16 -97.233 0 -2.468 0.996917 0 0.0784591 0 1 0 -0.0784591 0 0.996917 s\3241s04.dat
    Line 40: 1 16 -89.406 0 -3.123 0.996099 0 0.0882424 0 1 0 -0.0882424 0 0.996099 s\3241s04.dat
    Line 41: 1 16 -81.586 0 -3.854 0.995185 0 0.0980171 0 1 0 -0.0980171 0 0.995185 s\3241s04.dat
    Line 42: 1 16 -73.774 0 -4.662 0.994175 0 0.107782 0 1 0 -0.107782 0 0.994175 s\3241s04.dat
    Line 43: 1 16 -65.97 0 -5.547 0.993068 0 0.117537 0 1 0 -0.117537 0 0.993068 s\3241s04.dat
    Line 44: 1 16 -58.175 0 -6.508 0.991867 0 0.127281 0 1 0 -0.127281 0 0.991867 s\3241s04.dat
    Line 46: 1 16 -42.616 0 -8.66 0.989177 0 0.146731 0 1 0 -0.146731 0 0.989177 s\3241s04.dat
    Line 47: 1 16 -34.853 0 -9.851 0.987689 0 0.156435 0 1 0 -0.156435 0 0.987689 s\3241s04.dat
    Line 48: 1 16 -27.102 0 -11.118 0.986105 0 0.166123 0 1 0 -0.166123 0 0.986105 s\3241s04.dat
    Line 49: 1 16 19.109 0 -20.31 0.974615 0 0.223888 0 1 0 -0.223888 0 0.974615 s\3241s04.dat
    Line 51: 1 16 34.383 0 -23.977 0.970032 0 0.24298 0 1 0 -0.24298 0 0.970032 s\3241s04.dat
    Line 52: 1 16 41.992 0 -25.923 0.967599 0 0.252492 0 1 0 -0.252492 0 0.967599 s\3241s04.dat
    Line 53: 1 16 49.582 0 -27.943 0.965074 0 0.261979 0 1 0 -0.261979 0 0.965074 s\3241s04.dat
    Line 54: 1 16 11.446 0 -18.589 0.976766 0 0.214309 0 1 0 -0.214309 0 0.976766 s\3241s04.dat
    Line 55: 1 16 -19.364 0 -12.461 0.984427 0 0.175797 0 1 0 -0.175797 0 0.984427 s\3241s04.dat
    Line 56: 1 16 -11.639 0 -13.88 0.982654 0 0.185453 0 1 0 -0.185453 0 0.982654 s\3241s04.dat
    Line 57: 1 16 -3.929 0 -15.374 0.980786 0 0.195091 0 1 0 -0.195091 0 0.980786 s\3241s04.dat
    Line 58: 1 16 3.766 0 -16.944 0.978823 0 0.20471 0 1 0 -0.20471 0 0.978823 s\3241s04.dat
    Line 59: 1 16 57.151 0 -30.038 0.962455 0 0.27144 0 1 0 -0.27144 0 0.962455 s\3241s04.dat
    Line 60: 1 16 64.699 0 -32.207 0.959744 0 0.280876 0 1 0 -0.280876 0 0.959744 s\3241s04.dat
    Line 62: 1 16 79.73 0 -36.767 0.954044 0 0.299665 0 1 0 -0.299665 0 0.954044 s\3241s04.dat
    Line 63: 1 16 87.211 0 -39.157 0.951057 0 0.309017 0 1 0 -0.309017 0 0.951057 s\3241s04.dat
    Line 64: 1 16 94.669 0 -41.621 0.947977 0 0.318339 0 1 0 -0.318339 0 0.947977 s\3241s04.dat
    Line 65: 1 16 102.102 0 -44.158 0.944806 0 0.32763 0 1 0 -0.32763 0 0.944806 s\3241s04.dat
    Line 66: 1 16 109.51 0 -46.768 0.941544 0 0.33689 0 1 0 -0.33689 0 0.941544 s\3241s04.dat
    Line 67: 1 16 116.892 0 -49.45 0.938191 0 0.346117 0 1 0 -0.346117 0 0.938191 s\3241s04.dat
    Line 77: 1 16 -136.284 0 -0.352 0.999559 0 0.0296935 0 1 0 -0.0296935 0 0.999559 s\3241s07.dat
    Line 78: 1 16 -136.284 0 -0.352 -0.999559 0 -0.0296935 0 1 0 0.0296935 0 -0.999559 s\3241s07.dat
    Line 79: 1 16 124.398 0 -52.253 0.934661 0 0.35554 0 1 0 -0.35554 0 0.934661 s\3241s07.dat
    Line 80: 1 16 124.398 0 -52.253 -0.934661 0 -0.35554 0 1 0 0.35554 0 -0.934661 s\3241s07.dat
    Line 88: 1 494 -128.238 12 8.376 -0.999229 0 -0.0392598 0 1 0 0.0392598 0 -0.999229 s\3241s08.dat
    Line 89: 1 494 -128.946 12 -9.609 0.999229 0 0.0392598 0 1 0 -0.0392598 0 0.999229 s\3241s08.dat
    Line 90: 1 494 -41.295 12 0.243 -0.989176 0 -0.14673 0 1 0 0.14673 0 -0.989176 s\3241s08.dat
    Line 91: 1 494 -43.937 12 -17.56 0.989176 0 0.14673 0 1 0 -0.14673 0 0.989176 s\3241s08.dat
    Line 92: 1 494 36.57 12 -15.246 -0.970031 0 -0.242981 0 1 0 0.242981 0 -0.970031 s\3241s08.dat
    Line 93: 1 494 32.197 12 -32.703 0.970031 0 0.242981 0 1 0 -0.242981 0 0.970031 s\3241s08.dat
    Line 94: 1 494 120.008 12 -41.005 -0.938191 0 -0.346117 0 1 0 0.346117 0 -0.938191 s\3241s08.dat
    Line 95: 1 494 113.779 12 -57.888 0.938191 0 0.346117 0 1 0 -0.346117 0 0.938191 s\3241s08.dat
