Official File parts/s/3648s01.dat
~Technic Gear 24 Tooth - Teeth and Outer Ring
0 ~Technic Gear 24 Tooth - Teeth and Outer Ring 0 Name: s\3648s01.dat 0 Author: Lance Hopenwasser [cavehop] 0 !LDRAW_ORG Subpart UPDATE 2024-02 0 !LICENSE Licensed under CC BY 2.0 and CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2009-05-02 [PTadmin] Official Update 2009-01 0 !HISTORY 2024-03-23 [OrionP] Updated ring primitives 0 !HISTORY 2024-03-24 [OrionP] Official Update 2024-02
0 // // Teeth 1 16 0 27.04 0 1 0 0 0 1 0 0 0 1 tooth24.dat 1 16 -6.998 26.1179 0 .9659 -.2588 0 .2588 .9659 0 0 0 1.0 tooth24.dat 1 16 -13.52 23.4166 0 .866 -.5 0 0.5 .866 0 0 0 1.0 tooth24.dat 1 16 -19.12 19.12 0 .7071 -.7071 0 .7071 .7071 0 0 0 1.0 tooth24.dat 1 16 -23.4166 13.52 0 .5 -.866 0 .866 .5 0 0 0 1.0 tooth24.dat 1 16 -26.1179 6.998 0 .2588 -.9659 0 .9659 .2588 0 0 0 1.0 tooth24.dat 1 16 -27.04 0 0 0 -1.0 0 1.0 0 0 0 0 1.0 tooth24.dat 1 16 -26.1179 -6.998 0 -.2588 -.9659 0 .9659 -.2588 0 0 0 1.0 tooth24.dat 1 16 -23.4166 -13.52 0 -.5 -.866 0 .866 -.5 0 0 0 1.0 tooth24.dat 1 16 -19.12 -19.12 0 -.7071 -.7071 0 .7071 -.7071 0 0 0 1.0 tooth24.dat 1 16 -13.52 -23.4166 0 -.866 -.5 0 .5 -.866 0 0 0 1.0 tooth24.dat 1 16 -6.998 -26.1179 0 -.9659 -.2588 0 .2588 -.9659 0 0 0 1.0 tooth24.dat 1 16 0 -27.04 0 -1.0 0 0 0 -1.0 0 0 0 1.0 tooth24.dat 1 16 6.998 -26.1179 0 -.9659 .2588 0 -.2588 -.9659 0 0 0 1.0 tooth24.dat 1 16 13.52 -23.4166 0 -.866 .5 0 -.5 -.866 0 0 0 1.0 tooth24.dat 1 16 19.12 -19.12 0 -.7071 .7071 0 -.7071 -.7071 0 0 0 1.0 tooth24.dat 1 16 23.4166 -13.52 0 -.5 .866 0 -.866 -.5 0 0 0 1.0 tooth24.dat 1 16 26.1179 -6.998 0 -.2588 .9659 0 -.9659 -.2588 0 0 0 1.0 tooth24.dat 1 16 27.04 0 0 0 1.0 0 -1.0 0 0 0 0 1.0 tooth24.dat 1 16 26.1179 6.998 0 .2588 .9659 0 -.9659 0.2588 0 0 0 1.0 tooth24.dat 1 16 23.4166 13.52 0 .5 .866 0 -.866 0.5 0 0 0 1.0 tooth24.dat 1 16 19.12 19.12 0 .7071 .7071 0 -.7071 .7071 0 0 0 1.0 tooth24.dat 1 16 13.52 23.4166 0 .866 .5 0 -.5 .866 0 0 0 1.0 tooth24.dat 1 16 6.998 26.1179 0 .9659 .2588 0 -.2588 .9659 0 0 0 1.0 tooth24.dat 0 0 // Outer Cylinder 0 1 16 -4.1582 26.6836 0 0 0 -.6288 0 -1 -.1251 4.75 0 0 rect3.dat 1 16 -10.9227 24.6982 0 0 0 -.575 0 -1 -.2835 4.75 0 0 rect3.dat 1 16 -16.9429 21.0296 0 0 0 -.482 0 -1 -.4227 4.75 0 0 rect3.dat 1 16 -21.8084 15.9279 0 0 0 -.3562 0 -1 -.533 4.75 0 0 rect3.dat 1 16 -25.1878 9.7407 0 0 0 -.2061 0 -1 -.6071 4.75 0 0 rect3.dat 1 16 -26.8506 2.8897 0 0 0 -.0419 0 -1 -.6397 4.75 0 0 rect3.dat 1 16 -26.6836 -4.1582 0 0 0 .1251 0 1 -.6288 4.75 0 0 rect3.dat 1 16 -24.6982 -10.9227 0 0 0 .2835 0 1 -.575 4.75 0 0 rect3.dat 1 16 -21.0296 -16.9429 0 0 0 .4227 0 1 -.482 4.75 0 0 rect3.dat 1 16 -15.9279 -21.8084 0 0 0 .533 0 1 -.3562 4.75 0 0 rect3.dat 1 16 -9.7407 -25.1878 0 0 0 .6071 0 1 -.2061 4.75 0 0 rect3.dat 1 16 -2.8897 -26.8506 0 0 0 .6397 0 1 -.0419 4.75 0 0 rect3.dat 1 16 4.1582 -26.6836 0 0 0 .6288 0 1 .1251 4.75 0 0 rect3.dat 1 16 10.9227 -24.6982 0 0 0 .575 0 1 .2835 4.75 0 0 rect3.dat 1 16 16.9429 -21.0296 0 0 0 .482 0 1 .4227 4.75 0 0 rect3.dat 1 16 21.8084 -15.9279 0 0 0 .3562 0 1 .533 4.75 0 0 rect3.dat 1 16 25.1878 -9.7407 0 0 0 .2061 0 1 .6071 4.75 0 0 rect3.dat 1 16 26.8506 -2.8897 0 0 0 .0419 0 1 .6397 4.75 0 0 rect3.dat 1 16 26.6836 4.1582 0 0 0 -.1251 0 -1 .6288 4.75 0 0 rect3.dat 1 16 24.6982 10.9227 0 0 0 -.2835 0 -1 .575 4.75 0 0 rect3.dat 1 16 21.0296 16.9429 0 0 0 -.4227 0 -1 .482 4.75 0 0 rect3.dat 1 16 15.9279 21.8084 0 0 0 -.533 0 -1 .3562 4.75 0 0 rect3.dat 1 16 9.7407 25.1878 0 0 0 -.6071 0 -1 .2061 4.75 0 0 rect3.dat 1 16 2.8897 26.8506 0 0 0 -.6397 0 -1 .0419 4.75 0 0 rect3.dat 0 1 16 -2.8897 26.8506 0 0 0 .6397 0 -1 .0419 4.75 0 0 rect3.dat 1 16 -9.7407 25.1878 0 0 0 .6071 0 -1 .2061 4.75 0 0 rect3.dat 1 16 -15.9279 21.8084 0 0 0 .533 0 -1 .3562 4.75 0 0 rect3.dat 1 16 -21.0296 16.9429 0 0 0 .4227 0 -1 .482 4.75 0 0 rect3.dat 1 16 -24.6982 10.9227 0 0 0 .2835 0 -1 .575 4.75 0 0 rect3.dat 1 16 -26.6836 4.1582 0 0 0 .1251 0 -1 .6288 4.75 0 0 rect3.dat 1 16 -26.8506 -2.8897 0 0 0 -.0419 0 1 .6397 4.75 0 0 rect3.dat 1 16 -25.1878 -9.7407 0 0 0 -.2061 0 1 .6071 4.75 0 0 rect3.dat 1 16 -21.8084 -15.9279 0 0 0 -.3562 0 1 .533 4.75 0 0 rect3.dat 1 16 -16.9429 -21.0296 0 0 0 -.482 0 1 .4227 4.75 0 0 rect3.dat 1 16 -10.9227 -24.6982 0 0 0 -.575 0 1 .2835 4.75 0 0 rect3.dat 1 16 -4.1582 -26.6836 0 0 0 -.6288 0 1 .1251 4.75 0 0 rect3.dat 1 16 2.8897 -26.8506 0 0 0 -.6397 0 1 -.0419 4.75 0 0 rect3.dat 1 16 9.7407 -25.1878 0 0 0 -.6071 0 1 -.2061 4.75 0 0 rect3.dat 1 16 15.9279 -21.8084 0 0 0 -.533 0 1 -.3562 4.75 0 0 rect3.dat 1 16 21.0296 -16.9429 0 0 0 -.4227 0 1 -.482 4.75 0 0 rect3.dat 1 16 24.6982 -10.9227 0 0 0 -.2835 0 1 -.575 4.75 0 0 rect3.dat 1 16 26.6836 -4.1582 0 0 0 -.1251 0 1 -.6288 4.75 0 0 rect3.dat 1 16 26.8506 2.8897 0 0 0 .0419 0 -1 -.6397 4.75 0 0 rect3.dat 1 16 25.1878 9.7407 0 0 0 .2061 0 -1 -.6071 4.75 0 0 rect3.dat 1 16 21.8084 15.9279 0 0 0 .3562 0 -1 -.533 4.75 0 0 rect3.dat 1 16 16.9429 21.0296 0 0 0 .482 0 -1 -.4227 4.75 0 0 rect3.dat 1 16 10.9227 24.6982 0 0 0 .575 0 -1 -.2835 4.75 0 0 rect3.dat 1 16 4.1582 26.6836 0 0 0 .6288 0 -1 -.1251 4.75 0 0 rect3.dat 0 5 24 -3.5294 26.8087 -4.75 -3.5294 26.8087 4.75 0.0000 27.0400 4.75 -6.9985 26.1186 4.75 5 24 -10.3478 24.9817 -4.75 -10.3478 24.9817 4.75 -6.9985 26.1186 4.75 -13.5200 23.4173 4.75 5 24 -16.4609 21.4523 -4.75 -16.4609 21.4523 4.75 -13.5200 23.4173 4.75 -19.1202 19.1202 4.75 5 24 -21.4523 16.4609 -4.75 -21.4523 16.4609 4.75 -19.1202 19.1202 4.75 -23.4173 13.5200 4.75 5 24 -24.9817 10.3478 -4.75 -24.9817 10.3478 4.75 -23.4173 13.5200 4.75 -26.1186 6.9985 4.75 5 24 -26.8087 3.5294 -4.75 -26.8087 3.5294 4.75 -26.1186 6.9985 4.75 -27.0400 0.0000 4.75 5 24 -26.8087 -3.5294 -4.75 -26.8087 -3.5294 4.75 -27.0400 0.0000 4.75 -26.1186 -6.9985 4.75 5 24 -24.9817 -10.3478 -4.75 -24.9817 -10.3478 4.75 -26.1186 -6.9985 4.75 -23.4173 -13.5200 4.75 5 24 -21.4523 -16.4609 -4.75 -21.4523 -16.4609 4.75 -23.4173 -13.5200 4.75 -19.1202 -19.1202 4.75 5 24 -16.4609 -21.4523 -4.75 -16.4609 -21.4523 4.75 -19.1202 -19.1202 4.75 -13.5200 -23.4173 4.75 5 24 -10.3478 -24.9817 -4.75 -10.3478 -24.9817 4.75 -13.5200 -23.4173 4.75 -6.9985 -26.1186 4.75 5 24 -3.5294 -26.8087 -4.75 -3.5294 -26.8087 4.75 -6.9985 -26.1186 4.75 0.0000 -27.0400 4.75 5 24 3.5294 -26.8087 -4.75 3.5294 -26.8087 4.75 0.0000 -27.0400 4.75 6.9985 -26.1186 4.75 5 24 10.3478 -24.9817 -4.75 10.3478 -24.9817 4.75 6.9985 -26.1186 4.75 13.5200 -23.4173 4.75 5 24 16.4609 -21.4523 -4.75 16.4609 -21.4523 4.75 13.5200 -23.4173 4.75 19.1202 -19.1202 4.75 5 24 21.4523 -16.4609 -4.75 21.4523 -16.4609 4.75 19.1202 -19.1202 4.75 23.4173 -13.5200 4.75 5 24 24.9817 -10.3478 -4.75 24.9817 -10.3478 4.75 23.4173 -13.5200 4.75 26.1186 -6.9985 4.75 5 24 26.8087 -3.5294 -4.75 26.8087 -3.5294 4.75 26.1186 -6.9985 4.75 27.0400 0.0000 4.75 5 24 26.8087 3.5294 -4.75 26.8087 3.5294 4.75 27.0400 0.0000 4.75 26.1186 6.9985 4.75 5 24 24.9817 10.3478 -4.75 24.9817 10.3478 4.75 26.1186 6.9985 4.75 23.4173 13.5200 4.75 5 24 21.4523 16.4609 -4.75 21.4523 16.4609 4.75 23.4173 13.5200 4.75 19.1202 19.1202 4.75 5 24 16.4609 21.4523 -4.75 16.4609 21.4523 4.75 19.1202 19.1202 4.75 13.5200 23.4173 4.75 5 24 10.3478 24.9817 -4.75 10.3478 24.9817 4.75 13.5200 23.4173 4.75 6.9985 26.1186 4.75 5 24 3.5294 26.8087 -4.75 3.5294 26.8087 4.75 6.9985 26.1186 4.75 0.0000 27.0400 4.75 0 0 // Ring Surfaces 0 1 16 0 0 -4.75 2.08 0 0 0 0 2.08 0 1 0 48\4-4ring12.dat 1 16 0 0 4.75 2.08 0 0 0 0 2.08 0 -1 0 48\4-4ring12.dat 0 0 // Inner Cylinder 0 0 BFC INVERTNEXT 1 16 0 0 1.75 0 0 24.96 24.96 0 0 0 3 0 48\4-4cyli.dat 1 16 0 0 1.75 0 0 24.96 24.96 0 0 0 1 0 48\4-4edge.dat 1 16 0 0 4.75 0 0 24.96 24.96 0 0 0 1 0 48\4-4edge.dat 0 BFC INVERTNEXT 1 16 0 0 -4.75 0 0 24.96 24.96 0 0 0 3 0 48\4-4cyli.dat 1 16 0 0 -4.75 0 0 24.96 24.96 0 0 0 1 0 48\4-4edge.dat 1 16 0 0 -1.75 0 0 24.96 24.96 0 0 0 1 0 48\4-4edge.dat 0
  • Numbers cannot have trailing zeros
    Line 16: 1 16 -6.998 26.1179 0 .9659 -.2588 0 .2588 .9659 0 0 0 1.0 tooth24.dat
    Line 17: 1 16 -13.52 23.4166 0 .866 -.5 0 0.5 .866 0 0 0 1.0 tooth24.dat
    Line 18: 1 16 -19.12 19.12 0 .7071 -.7071 0 .7071 .7071 0 0 0 1.0 tooth24.dat
    Line 19: 1 16 -23.4166 13.52 0 .5 -.866 0 .866 .5 0 0 0 1.0 tooth24.dat
    Line 20: 1 16 -26.1179 6.998 0 .2588 -.9659 0 .9659 .2588 0 0 0 1.0 tooth24.dat
    Line 21: 1 16 -27.04 0 0 0 -1.0 0 1.0 0 0 0 0 1.0 tooth24.dat
    Line 22: 1 16 -26.1179 -6.998 0 -.2588 -.9659 0 .9659 -.2588 0 0 0 1.0 tooth24.dat
    Line 23: 1 16 -23.4166 -13.52 0 -.5 -.866 0 .866 -.5 0 0 0 1.0 tooth24.dat
    Line 24: 1 16 -19.12 -19.12 0 -.7071 -.7071 0 .7071 -.7071 0 0 0 1.0 tooth24.dat
    Line 25: 1 16 -13.52 -23.4166 0 -.866 -.5 0 .5 -.866 0 0 0 1.0 tooth24.dat
    Line 26: 1 16 -6.998 -26.1179 0 -.9659 -.2588 0 .2588 -.9659 0 0 0 1.0 tooth24.dat
    Line 27: 1 16 0 -27.04 0 -1.0 0 0 0 -1.0 0 0 0 1.0 tooth24.dat
    Line 28: 1 16 6.998 -26.1179 0 -.9659 .2588 0 -.2588 -.9659 0 0 0 1.0 tooth24.dat
    Line 29: 1 16 13.52 -23.4166 0 -.866 .5 0 -.5 -.866 0 0 0 1.0 tooth24.dat
    Line 30: 1 16 19.12 -19.12 0 -.7071 .7071 0 -.7071 -.7071 0 0 0 1.0 tooth24.dat
    Line 31: 1 16 23.4166 -13.52 0 -.5 .866 0 -.866 -.5 0 0 0 1.0 tooth24.dat
    Line 32: 1 16 26.1179 -6.998 0 -.2588 .9659 0 -.9659 -.2588 0 0 0 1.0 tooth24.dat
    Line 33: 1 16 27.04 0 0 0 1.0 0 -1.0 0 0 0 0 1.0 tooth24.dat
    Line 34: 1 16 26.1179 6.998 0 .2588 .9659 0 -.9659 0.2588 0 0 0 1.0 tooth24.dat
    Line 35: 1 16 23.4166 13.52 0 .5 .866 0 -.866 0.5 0 0 0 1.0 tooth24.dat
    Line 36: 1 16 19.12 19.12 0 .7071 .7071 0 -.7071 .7071 0 0 0 1.0 tooth24.dat
    Line 37: 1 16 13.52 23.4166 0 .866 .5 0 -.5 .866 0 0 0 1.0 tooth24.dat
    Line 38: 1 16 6.998 26.1179 0 .9659 .2588 0 -.2588 .9659 0 0 0 1.0 tooth24.dat
    Line 92: 5 24 -3.5294 26.8087 -4.75 -3.5294 26.8087 4.75 0.0000 27.0400 4.75 -6.9985 26.1186 4.75
    Line 93: 5 24 -10.3478 24.9817 -4.75 -10.3478 24.9817 4.75 -6.9985 26.1186 4.75 -13.5200 23.4173 4.75
    Line 94: 5 24 -16.4609 21.4523 -4.75 -16.4609 21.4523 4.75 -13.5200 23.4173 4.75 -19.1202 19.1202 4.75
    Line 95: 5 24 -21.4523 16.4609 -4.75 -21.4523 16.4609 4.75 -19.1202 19.1202 4.75 -23.4173 13.5200 4.75
    Line 96: 5 24 -24.9817 10.3478 -4.75 -24.9817 10.3478 4.75 -23.4173 13.5200 4.75 -26.1186 6.9985 4.75
    Line 97: 5 24 -26.8087 3.5294 -4.75 -26.8087 3.5294 4.75 -26.1186 6.9985 4.75 -27.0400 0.0000 4.75
    Line 98: 5 24 -26.8087 -3.5294 -4.75 -26.8087 -3.5294 4.75 -27.0400 0.0000 4.75 -26.1186 -6.9985 4.75
    Line 99: 5 24 -24.9817 -10.3478 -4.75 -24.9817 -10.3478 4.75 -26.1186 -6.9985 4.75 -23.4173 -13.5200 4.75
    Line 100: 5 24 -21.4523 -16.4609 -4.75 -21.4523 -16.4609 4.75 -23.4173 -13.5200 4.75 -19.1202 -19.1202 4.75
    Line 101: 5 24 -16.4609 -21.4523 -4.75 -16.4609 -21.4523 4.75 -19.1202 -19.1202 4.75 -13.5200 -23.4173 4.75
    Line 102: 5 24 -10.3478 -24.9817 -4.75 -10.3478 -24.9817 4.75 -13.5200 -23.4173 4.75 -6.9985 -26.1186 4.75
    Line 103: 5 24 -3.5294 -26.8087 -4.75 -3.5294 -26.8087 4.75 -6.9985 -26.1186 4.75 0.0000 -27.0400 4.75
    Line 104: 5 24 3.5294 -26.8087 -4.75 3.5294 -26.8087 4.75 0.0000 -27.0400 4.75 6.9985 -26.1186 4.75
    Line 105: 5 24 10.3478 -24.9817 -4.75 10.3478 -24.9817 4.75 6.9985 -26.1186 4.75 13.5200 -23.4173 4.75
    Line 106: 5 24 16.4609 -21.4523 -4.75 16.4609 -21.4523 4.75 13.5200 -23.4173 4.75 19.1202 -19.1202 4.75
    Line 107: 5 24 21.4523 -16.4609 -4.75 21.4523 -16.4609 4.75 19.1202 -19.1202 4.75 23.4173 -13.5200 4.75
    Line 108: 5 24 24.9817 -10.3478 -4.75 24.9817 -10.3478 4.75 23.4173 -13.5200 4.75 26.1186 -6.9985 4.75
    Line 109: 5 24 26.8087 -3.5294 -4.75 26.8087 -3.5294 4.75 26.1186 -6.9985 4.75 27.0400 0.0000 4.75
    Line 110: 5 24 26.8087 3.5294 -4.75 26.8087 3.5294 4.75 27.0400 0.0000 4.75 26.1186 6.9985 4.75
    Line 111: 5 24 24.9817 10.3478 -4.75 24.9817 10.3478 4.75 26.1186 6.9985 4.75 23.4173 13.5200 4.75
    Line 112: 5 24 21.4523 16.4609 -4.75 21.4523 16.4609 4.75 23.4173 13.5200 4.75 19.1202 19.1202 4.75
    Line 113: 5 24 16.4609 21.4523 -4.75 16.4609 21.4523 4.75 19.1202 19.1202 4.75 13.5200 23.4173 4.75
    Line 114: 5 24 10.3478 24.9817 -4.75 10.3478 24.9817 4.75 13.5200 23.4173 4.75 6.9985 26.1186 4.75
    Line 115: 5 24 3.5294 26.8087 -4.75 3.5294 26.8087 4.75 6.9985 26.1186 4.75 0.0000 27.0400 4.75
This part is copyright © Lance Hopenwasser
