Official File parts/s/4750s1.dat
0 ~Brick Round 13.667 x 13.667 Fabuland Hollowed - 1/8 Section
0 Name: s\4750s1.dat
0 Author: Svend Eisenhardt [eisenhardt]
0 !LDRAW_ORG Subpart UPDATE 2024-02
0 !HISTORY 2010-04-25 [Steffen] moved studs to parent part, removed duplicate line, fixed bad vertex sequence
0 !HISTORY 2011-02-22 [Philo] BFCed with Windz, closed gaps, added missing lines & condlines
0 // outside ring
1 16 0 4 0 135 0 0 0 12 0 0 0 135 48\1-8cyli.dat
1 16 0 4 0 131 0 0 0 12 0 0 0 131 48\1-8cyli.dat
1 16 0 4 0 135 0 0 0 1 0 0 0 135 48\1-8edge.dat
1 16 0 16 0 135 0 0 0 1 0 0 0 135 48\1-8edge.dat
1 16 0 16 0 131 0 0 0 1 0 0 0 131 48\1-8edge.dat
1 16 0 4 0 131 0 0 0 1 0 0 0 131 48\1-8edge.dat
1 16 0 0 0 128 0 0 0 1 0 0 0 128 48\1-8edge.dat
0 // lower ring between 131 OG 135 LDU
4 16 131 16 0 129.873 16 17.096 133.839 16 17.618 135 16 0
4 16 129.873 16 17.096 126.533 16 33.903 130.397 16 34.938 133.839 16 17.618
4 16 126.533 16 33.903 121.031 16 50.134 124.727 16 51.665 130.397 16 34.938
4 16 121.031 16 50.134 113.239 16 65.5 116.91 16 67.5 124.727 16 51.665
4 16 113.239 16 65.5 103.935 16 79.753 107.109 16 82.188 116.91 16 67.5
4 16 103.935 16 79.753 92.63 16 92.63 95.459 16 95.459 107.109 16 82.188
0 // upper cone-ring between 128 OG 135 LDU
4 16 128 0 0 135 4 0 133.839 4 17.618 126.899 0 16.704
4 16 126.899 0 16.704 133.839 4 17.618 130.397 4 34.938 123.635 0 33.126
4 16 123.635 0 33.126 130.397 4 34.938 124.727 4 51.665 118.259 0 48.986
4 16 118.259 0 48.986 124.727 4 51.665 116.91 4 67.5 110.848 0 64
4 16 110.848 0 64 116.91 4 67.5 107.109 4 82.188 101.555 0 77.926
4 16 101.555 0 77.926 107.109 4 82.188 95.459 4 95.459 90.509 0 90.509
0 // Center area:
0 // LINE LEVEL 0
0 // LINE LEVEL 3.5
2 24 40 4 1.532 40 4 8.5
2 24 40 4 11.5 40 4 29.5
2 24 40 4 31.5 40 4 40
0 // LINE LEVEL 8
0 // LINES LEVEL 16
0 // SURFACES
1 16 20 4 10 0 1 0 -4 0 0 0 0 10 rect3.dat
1 16 30 0 10 10 0 0 0 1 0 0 0 10 rect1.dat
4 16 24 4 0 24 4 24 40 4 40 40 4 0
1 16 76 4 30 -32 0 0 0 -1 0 0 0 6 rect1.dat
1 16 44 10 30 0 -1 0 0 0 6 -6 0 0 rect3.dat
4 16 24 8 0 20 8 0 20 8 20 24 8 24
4 16 40 16 0 40 16 40 44 16 36 44 16 0
1 16 40 10 20 0 1 0 6 0 0 0 0 -20 rect1.dat
1 16 24 6 12.766 0 -1.0098 0 -2 0 0 0 0 -11.234 rect3.dat
0 // Square hole area:
0 // LINES LEVEL 0
1 16 94 0 10 10 0 0 0 1 0 0 0 10 1-4edge.dat
0 // LINES LEVEL 1
0 // LINES LEVEL 3.5
2 24 44 4 24 58.468 4 24
2 24 61.532 4 24 78.468 4 24
2 24 81.532 4 24 94 4 24
1 16 94 4 10 14 0 0 0 1 0 0 0 14 1-4edge.dat
0 // LINES LEVEL 16
1 16 94 16 10 10 0 0 0 1 0 0 0 10 1-4edge.dat
1 16 94 16 10 14 0 0 0 1 0 0 0 14 1-4edge.dat
2 24 44 16 24 58.468 16 24
2 24 61.532 16 24 78.468 16 24
2 24 81.532 16 24 94 16 24
1 16 94 0 10 10 0 0 0 16 0 0 0 10 1-4cyli.dat
1 16 94 4 10 14 0 0 0 12 0 0 0 14 1-4cyli.dat
1 16 94 0 10 10 0 0 0 16 0 0 0 10 1-4ndis.dat
0 // surfaces vertical
4 16 44 4 24 94 4 24 94 16 24 44 16 24
1 16 69 8.5 20 -25 0 0 0 0 7.5 0 1 0 rect2a.dat
1 16 67 0.5 20 0 0 -27 -0.5 0 0 0 1 0 rect2a.dat
1 16 40 0.5 10 0 -1 0 0.5 0 0 0 0 10 rect1.dat
1 16 42 1 10 2 0 0 0 1 0 0 0 10 rect2a.dat
1 16 44 8.5 10 0 -1 0 7.5 0 0 0 0 10 rect1.dat
1 16 104 8 5 0 1 0 0 0 8 5 0 0 rect2p.dat
1 16 108 10 5 0 -1 0 0 0 -6 5 0 0 rect2p.dat
0 // SURFACES LEVEL 16
4 16 44 16 20 44 16 24 94 16 24 94 16 20
4 16 104 16 0 104 16 10 108 16 10 108 16 0
1 16 94 16 10 2 0 0 0 1 0 0 0 2 1-4ring5.dat
1 16 94 16 10 2 0 0 0 1 0 0 0 2 1-4ring6.dat
0 // Triangular area:
0 // LINES LEVEL 0
2 24 90.933 0 52.5 83.302 0 63.92
2 24 83.302 0 63.92 74.246 0 74.246
2 24 90.933 0 52.5 96 0 44
2 24 96 0 44 96.5 0 42.5
1 16 94 0 42.5 0 0 2.5 0 1 0 -2.5 0 0 1-4edge.dat
1 16 50 0 50 0 0 -10 0 -1 0 -10 0 0 1-8edge.dat
2 24 44 4 36 58.468 4 36
2 24 61.532 4 36 78.468 4 36
2 24 81.532 4 36 94 4 36
1 16 94 4 42.5 0 0 6.5 0 1 0 -6.5 0 0 1-4edge.dat
1 16 94 4 42.5 6.5 0 0 0 1 0 0 0 6.5 1-16edge.dat
2 24 94.397 4 54.467 86.521 4 66.357
2 24 86.521 4 66.357 77.075 4 77.075
2 24 100.005 4 44.988 94.397 4 54.467
0 // LINES LEVEL 16
2 24 90.933 16 52.5 83.302 16 63.92
2 24 83.302 16 63.92 74.246 16 74.246
2 24 90.933 16 52.5 96 16 44
2 24 96 16 44 96.5 16 42.5
1 16 94 16 42.5 0 0 2.5 0 1 0 -2.5 0 0 1-4edge.dat
1 16 50 16 50 0 0 -10 0 -1 0 -10 0 0 1-8edge.dat
2 24 44 16 36 58.468 16 36
2 24 40 16 40 40 4 40
2 24 61.532 16 36 78.468 16 36
2 24 81.532 16 36 94 16 36
1 16 94 16 42.5 0 0 6.5 0 1 0 -6.5 0 0 1-4edge.dat
1 16 94 16 42.5 6.5 0 0 0 1 0 0 0 6.5 1-16edge.dat
2 24 94.397 16 54.467 86.476 16 66.355
2 24 86.476 16 66.355 77.075 16 77.075
2 24 100.005 16 44.988 94.397 16 54.467
0 // Surfaces vertical LDU 109
4 16 94.397 16 54.467 86.476 16 66.355 86.521 4 66.357 94.397 4 54.467
4 16 86.476 16 66.355 77.075 16 77.075 77.075 4 77.075 86.521 4 66.357
4 16 100.005 16 44.988 94.397 16 54.467 94.397 4 54.467 100.005 4 44.988
4 16 44 16 36 94 16 36 94 4 36 44 4 36
1 16 94 4 42.5 0 0 6.5 0 12 0 -6.5 0 0 1-4cyli.dat
1 16 94 4 42.5 6.5 0 0 0 12 0 0 0 6.5 1-16cyli.dat
0 // Inside surfaces vertical
1 16 72 8 40 22 0 0 0 0 8 0 -1 0 rect2p.dat
4 16 90.933 0 52.5 83.302 0 63.92 83.302 16 63.92 90.933 16 52.5
4 16 83.302 0 63.92 74.246 0 74.246 74.246 16 74.246 83.302 16 63.92
4 16 90.933 0 52.5 90.933 16 52.5 96 16 44 96 0 44
4 16 96 0 44 96 16 44 96.5 16 42.5 96.5 0 42.5
1 16 94 0 42.5 0 0 2.5 0 16 0 -2.5 0 0 1-4cyli.dat
1 16 50 0 50 -7.07 0 7.07 0 16 0 -7.07 0 -7.07 1-8cyli.dat
4 16 44 16 36 40 16 40 94 16 40 94 16 36
1 16 94 16 42.5 0 0 0.5 0 1 0 -0.5 0 0 1-4ring5.dat
1 16 94 16 42.5 0 0 0.5 0 1 0 -0.5 0 0 1-4ring12.dat
1 16 94 16 42.5 0 0 3 0 1 0 -3 0 0 1-4ring1.dat
1 16 50 16 50 0 0 -10 0 -1 0 -10 0 0 1-8ndis.dat
4 16 83.302 16 63.92 74.246 16 74.246 77.075 16 77.075 86.476 16 66.355
3 16 96.5 0 42.5 104 0 40 96 0 44
3 16 96.5 0 42.5 96.5 0 40 104 0 40
4 16 90.933 16 52.5 83.302 16 63.92 86.476 16 66.355 94.397 16 54.467
4 16 90.933 16 52.5 94.397 16 54.467 100.005 16 44.988 96 16 44
4 16 96.5 16 42.5 96 16 44 100.005 16 44.988 100.5 16 42.5
0 // Surfaces level 0
1 16 50 0 50 0 0 -10 0 -1 0 -10 0 0 1-8ndis.dat
4 16 104 0 0 112.5 0 0 112.5 0 7.5 104 0 7.5
4 16 20 0 20 104 0 20 104 0 40 40 0 40
4 16 104 0 7.5 120 0 7.5 123.635 0 33.126 104 0 40
4 16 96 0 44 104 0 40 123.635 0 33.126 118.259 0 48.986
4 16 120 0 7.5 127.5 0 7.5 126.899 0 16.704 123.635 0 33.126
3 16 127.5 0 0 128 0 0 127.5 0 7.5
4 16 90.933 0 52.5 110.848 0 64 101.555 0 77.926 83.302 0 63.92
4 16 83.302 0 63.92 101.555 0 77.926 90.509 0 90.509 74.246 0 74.246
4 16 90.933 0 52.5 96 0 44 118.259 0 48.986 110.848 0 64
1 16 94 0 42.5 0 0 2.5 0 1 0 -2.5 0 0 1-4ndis.dat
0 // Surfaces level 4 LDU
1 16 120 4 0 10 0 0 0 1 0 0 0 10 2-4ndis.dat
3 16 129.873 4 17.096 131 4 0 130 4 0
4 16 108 4 0 108 4 10 110 4 10 110 4 0
4 16 94.397 4 54.467 86.521 4 66.357 103.935 4 79.753 113.446 4 65.5
4 16 86.521 4 66.357 77.075 4 77.075 92.63 4 92.63 103.935 4 79.753
1 16 94 4 10 14 0 0 0 1 0 0 0 14 1-4ndis.dat
1 16 94 4 42.5 0 0 6.5 0 1 0 -6.5 0 0 1-4ndis.dat
4 16 108 4 10 108 4 24 129.873 4 17.096 130 4 10
4 16 108 4 24 108 4 36 126.533 4 33.903 129.873 4 17.096
3 16 108 4 36 121.031 4 50.134 126.533 4 33.903
4 16 100.005 4 44.988 94.397 4 54.467 113.446 4 65.5 121.031 4 50.134
3 16 100.005 4 44.988 121.031 4 50.134 100.5 4 42.5
4 16 108 4 36 100.5 4 36 100.5 4 42.5 121.031 4 50.134
0 // Hole outermost:
1 16 120 0 0 7.5 0 0 0 9 0 0 0 7.5 2-4cyli.dat
1 16 120 0 0 7.5 0 0 0 1 0 0 0 7.5 2-4edge.dat
1 16 120 0 0 7.5 0 0 0 1 0 0 0 7.5 2-4ndis.dat
1 16 120 4 0 10 0 0 0 1 0 0 0 10 2-4edge.dat
1 16 120 4 0 10 0 0 0 7 0 0 0 10 2-4cyli.dat
1 16 120 9 0 7.5 0 0 0 1 0 0 0 7.5 2-4edge.dat
1 16 120 9 0 6 0 0 0 1 0 0 0 6 2-4edge.dat
1 16 120 9 0 1.5 0 0 0 1 0 0 0 1.5 2-4ring4.dat
1 16 120 11 0 10 0 0 0 1 0 0 0 10 2-4edge.dat
1 16 120 11 0 8 0 0 0 1 0 0 0 8 2-4edge.dat
1 16 120 11 0 2 0 0 0 1 0 0 0 2 2-4ring4.dat
1 16 120 9 0 6 0 0 0 7 0 0 0 6 2-4cyli.dat
1 16 120 11 0 8 0 0 0 5 0 0 0 8 2-4cyli.dat
1 16 120 16 0 2 0 0 0 1 0 0 0 2 2-4ring3.dat
1 16 120 16 0 8 0 0 0 1 0 0 0 8 2-4edge.dat
1 16 120 16 0 6 0 0 0 1 0 0 0 6 2-4edge.dat
0 // STUDS BELOW:
0 // DOWNSIDE STUDS IN CENTER LEVEL 4 TO 8
1 16 38 4 10 0 0 -2 0 4 0 1.5 0 0 box4-1.dat
1 16 38 4 30 0 0 -2 0 4 0 1.5 0 0 box4-1.dat
1 16 30 4 20 1 0 0 0 -1 0 0 0 1 stud3.dat
1 16 25.152 8 0.766 0 0 1.15175 0 -1.17632 0 0.766 0 0 rect1.dat
1 16 25.152 6 1.531 0 -0.00082 1.15165 -2 0 0 0 -1.02369 -0.00092 rect2a.dat
1 16 36.848 8 0.766 0 0 3.152 0 -1.07308 0 0.766 0 0 rect2a.dat
1 16 36.848 6 1.532 -3.152 0 0 0 0 -2 0 -1.00864 0 rect3.dat
1 16 30 8 0 3.696 0 -1.532 0 -1 0 1.532 0 3.696 3-8disc.dat
1 16 30 8 0 3.696 0 -1.532 0 1 0 1.532 0 3.696 3-8edge.dat
1 16 30 4 0 3.696 0 -1.532 0 1 0 1.532 0 3.696 1-4edge.dat
1 16 30 4 0 -1.532 0 -3.696 0 1 0 3.696 0 -1.532 1-8edge.dat
1 16 30 4 0 3.696 0 -1.532 0 4 0 1.532 0 3.696 1-4cyli.dat
1 16 30 4 0 -1.532 0 -3.696 0 4 0 3.696 0 -1.532 1-8cyli.dat
3 16 30 8 0 33.696 8 1.532 33.696 8 0
3 16 30 8 0 26.304 8 0 26.303 8 1.53
0 // DOWNSIDE STUDS IN SPOKE LEVEL 4 TO 16
1 16 60 16 30 1.532 0 3.696 0 -1 0 -3.696 0 1.532 3-8disc.dat
1 16 60 4 30 1.532 0 3.696 0 12 0 -3.696 0 1.532 3-8cyli.dat
1 16 60 16 30 1.532 0 3.696 0 1 0 -3.696 0 1.532 3-8edge.dat
1 16 60 4 30 1.532 0 3.696 0 1 0 -3.696 0 1.532 3-8edge.dat
1 16 60 16 30 -1.532 0 -3.696 0 -1 0 3.696 0 -1.532 3-8disc.dat
1 16 60 4 30 -1.532 0 -3.696 0 12 0 3.696 0 -1.532 3-8cyli.dat
1 16 60 16 30 -1.532 0 -3.696 0 1 0 3.696 0 -1.532 3-8edge.dat
1 16 60 4 30 -1.532 0 -3.696 0 1 0 3.696 0 -1.532 3-8edge.dat
3 16 60 16 30 58.468 16 33.7 61.532 16 33.7
3 16 60 16 30 61.532 16 26.3 58.468 16 26.3
1 16 60 4 34.85 0 0 1.532 0 12 0 -1.15 0 0 box3u4p.dat
1 16 60 4 25.15 0 0 1.532 0 12 0 -1.15 0 0 box3u4p.dat
1 16 80 16 30 1.532 0 3.696 0 -1 0 -3.696 0 1.532 3-8disc.dat
1 16 80 4 30 1.532 0 3.696 0 12 0 -3.696 0 1.532 3-8cyli.dat
1 16 80 16 30 1.532 0 3.696 0 1 0 -3.696 0 1.532 3-8edge.dat
1 16 80 4 30 1.532 0 3.696 0 1 0 -3.696 0 1.532 3-8edge.dat
1 16 80 16 30 -1.532 0 -3.696 0 -1 0 3.696 0 -1.532 3-8disc.dat
1 16 80 4 30 -1.532 0 -3.696 0 12 0 3.696 0 -1.532 3-8cyli.dat
1 16 80 16 30 -1.532 0 -3.696 0 1 0 3.696 0 -1.532 3-8edge.dat
1 16 80 4 30 -1.532 0 -3.696 0 1 0 3.696 0 -1.532 3-8edge.dat
3 16 80 16 30 78.468 16 33.7 81.532 16 33.7
3 16 80 16 30 81.532 16 26.3 78.468 16 26.3
1 16 80 4 34.85 0 0 1.532 0 12 0 -1.15 0 0 box3u4p.dat
1 16 80 4 25.15 0 0 1.532 0 12 0 -1.15 0 0 box3u4p.dat
0 // vertical lines in spoke:
2 24 58.468 4 24 58.468 16 24
2 24 61.532 4 24 61.532 16 24
2 24 78.468 4 24 78.468 16 24
2 24 81.532 4 24 81.532 16 24
2 24 58.468 4 36 58.468 16 36
2 24 61.532 4 36 61.532 16 36
2 24 78.468 4 36 78.468 16 36
2 24 81.532 4 36 81.532 16 36
5 24 133.839 4 17.618 126.899 0 16.704 128 0 0 130.397 4 34.938
5 24 130.397 4 34.938 123.635 0 33.126 126.899 0 16.704 124.727 4 51.665
5 24 124.727 4 51.665 118.259 0 48.986 123.635 0 33.126 116.91 4 67.5
5 24 116.91 4 67.5 110.848 0 64 118.259 0 48.986 107.109 4 82.188
5 24 107.109 4 82.188 101.555 0 77.926 110.848 0 64 95.459 4 95.459
5 24 86.476 16 66.355 86.521 4 66.357 94.397 16 54.467 77.075 16 77.075
5 24 94.397 4 54.467 94.397 16 54.467 86.476 16 66.355 100.005 16 44.988
5 24 100.005 4 44.988 100.005 16 44.988 94.397 16 54.467 100.5 4 42.5
5 24 83.302 0 63.92 83.302 16 63.92 90.933 0 52.5 74.246 0 74.246
5 24 90.933 16 52.5 90.933 0 52.5 83.302 0 63.92 96 16 44
5 24 96 16 44 96 0 44 90.933 0 52.5 96.5 16 42.5
5 24 96.5 16 42.5 96.5 0 42.5 96 0 44 96.31 0 41.543
Official
