Official File parts/s/501s01.dat
0 ~Electric Train Motor 12V with Bottomside Contacts Pushed In
0 Name: s\501s01.dat
0 Author: Thomas Burger [grapeape]
0 !LDRAW_ORG Subpart UPDATE 2025-09
0 !HELP (1)
0 !HELP The wheel position is raised a slight bit to allow for the wheels to
0 !HELP carry tyres and though still keep the motor in a position as if *not*
0 !HELP wearing tyres. This avoids problems e.g. with the famous 7740 train,
0 !HELP where otherwise the locomotive has a "raised-by-tyres" motor and a
0 !HELP "not-raised-by-tyres" pseudo-motor built from bricks.
0 !HELP (2)
0 !HELP The bottomside contacts are pushed in a little.
0 !HELP This is what happens if you put this part onto its 12V train track.
0 !HISTORY 2003-05-23 [Steffen] did some size bugfixes, used primitives
0 !HISTORY 2004-01-28 [cwdee] Removed POV code per LSC decision
0 !HISTORY 2004-04-10 [Steffen] corrected renumbered wheel file reference
0 !HISTORY 2008-12-02 [Steffen] this file was duplicatedly present on the PT, merged the two versions
0 !HISTORY 2009-01-10 [Steffen] subparted, removed T junctions
0 !HISTORY 2009-05-16 [Steffen] added "Needs Work" note about copper color to be able to release this part
0 !HISTORY 2009-06-09 [Steffen] rotated wheels on one side 90 degrees compared to other side on request by [anathema]
0 !HISTORY 2009-10-01 [Steffen] used new official color 495 for copper portions
0 !HISTORY 2009-10-06 [Steffen] adjusted origin to match 2894c01.dat
0 !HISTORY 2009-11-07 [Steffen] made copper cylinders no longer poke through surface, used 4-4cylc.dat
0 !HISTORY 2011-01-08 [Steffen] used u9130.dat, corrected position and size of bottomsize contacts to match x431.dat
0 !HISTORY 2011-12-10 [Steffen] changed color 383 to 494
2 24 -40 16 -100 -40 56 -100
2 24 40 56 -100 -40 56 -100
2 24 40 56 -100 40 16 -100
4 16 -20 16 -100 -40 16 -100 -40 56 -100 -20 40 -100
4 16 20 40 -100 -20 40 -100 -40 56 -100 40 56 -100
4 16 20 16 -100 20 40 -100 40 56 -100 40 16 -100
4 16 -20 16 100 -40 16 100 -40 16 60 -20 16 76
4 16 20 16 76 -20 16 76 -40 16 60 40 16 60
4 16 20 16 100 20 16 76 40 16 60 40 16 100
2 24 40 16 100 40 56 100
2 24 40 56 100 -40 56 100
2 24 -40 56 100 -40 16 100
4 16 40 16 100 40 56 100 -40 56 100 -40 16 100
2 24 -40 16 100 40 16 100
2 24 40 56 100 40 56 -100
2 24 -40 56 100 -40 56 -100
4 16 40 56 100 40 16 100 40 16 60 40 56 6
4 16 40 56 -6 40 16 -60 40 16 -100 40 56 -100
3 16 40 56 -6 40 16 -6 40 16 -60
3 16 40 56 6 40 16 60 40 16 6
4 16 40 17 6 40 16 6 40 16 -6 40 17 -6
4 16 -40 17 -6 -40 16 -6 -40 16 6 -40 17 6
4 16 40 56 6 40 44 6 40 44 -6 40 56 -6
2 24 40 16 -100 40 16 -60
2 24 -40 16 -100 -40 16 -60
4 16 -40 16 -60 -40 16 -96 40 16 -96 40 16 -60
2 24 40 16 60 40 16 100
2 24 -40 16 60 -40 16 100
2 24 -40 16 -60 40 16 -60
2 24 -40 16 60 40 16 60
2 24 40 16 -60 40 8 -60
4 16 40 16 6 40 16 60 40 1 60 40 1 6
4 16 40 16 -6 40 16 6 40 1 6 40 1 -6
4 16 40 16 -60 40 16 -6 40 1 -6 40 1 -60
4 16 -40 56 -100 -40 16 -100 -40 16 -60 -40 56 -6
4 16 -40 56 6 -40 16 60 -40 16 100 -40 56 100
3 16 -40 56 6 -40 16 6 -40 16 60
3 16 -40 56 -6 -40 16 -60 -40 16 -6
4 16 -40 56 -6 -40 44 -6 -40 44 6 -40 56 6
4 16 -40 16 -6 -40 16 -60 -40 1 -60 -40 1 -6
4 16 -40 16 6 -40 16 -6 -40 1 -6 -40 1 6
4 16 -40 16 60 -40 16 6 -40 1 6 -40 1 60
4 16 -40 1 -60 -40 16 -60 40 16 -60 40 1 -60
2 24 -40 16 -60 -40 8 -60
2 24 -40 16 60 -40 8 60
2 24 40 16 60 40 8 60
4 16 40 1 60 40 16 60 -40 16 60 -40 1 60
2 24 -40 1 -60 40 1 -60
2 24 40 1 60 40 1 -60
2 24 -40 1 60 40 1 60
2 24 -40 1 60 -40 1 -60
2 24 40 8 -60 40 1 -60
2 24 -40 8 -60 -40 1 -60
2 24 -40 8 60 -40 1 60
2 24 40 8 60 40 1 60
1 16 0 0 0 6 0 0 0 6 0 0 0 6 4-4edge.dat
1 16 0 0 0 4 0 0 0 4 0 0 0 4 4-4edge.dat
2 24 30 0 -50 30 0 50
2 24 30 0 50 -30 0 50
2 24 -30 0 50 -30 0 -50
2 24 -30 0 -50 30 0 -50
2 24 30 0 -50 40 1 -60
2 24 30 0 50 40 1 60
2 24 -30 0 50 -40 1 60
2 24 -30 0 -50 -40 1 -60
4 16 -30 0 50 -30 0 -50 30 0 -50 30 0 50
4 16 40 1 60 30 0 50 30 0 -50 40 1 -60
4 16 -40 1 60 -30 0 50 30 0 50 40 1 60
4 16 -40 1 -60 -30 0 -50 -30 0 50 -40 1 60
4 16 40 1 -60 30 0 -50 -30 0 -50 -40 1 -60
1 16 -20 16 -80 0 0 1 0 1 0 -1 0 0 stug-2x2.dat
1 16 20 16 -80 0 0 1 0 1 0 -1 0 0 stug-2x2.dat
1 16 30 16 90 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 30 16 70 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 10 16 70 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 -10 16 70 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 -30 16 70 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 -30 16 90 0 0 1 0 1 0 -1 0 0 stud.dat
1 16 0 2 0 0 0 1 0 1 0 1 0 0 connect2.dat
2 24 34 50 -104 26 50 -104
2 24 36 44 -106 24 44 -106
2 24 36 44 -104 24 44 -104
2 24 36 56 -106 36 44 -106
2 24 36 44 -106 36 44 -104
2 24 34 56 -104 26 56 -104
2 24 24 44 -106 24 44 -104
2 24 24 56 -106 24 44 -106
2 24 24 48 -100 24 56 -100
2 24 36 44 -104 36 48 -104
2 24 36 48 -104 36 48 -100
2 24 36 56 -100 36 56 -106
2 24 36 48 -100 24 48 -100
2 24 36 48 -104 24 48 -104
2 24 24 48 -104 24 48 -100
2 24 24 44 -104 24 48 -104
2 24 26 56 -100 24 56 -100
2 24 34 50 -104 34 50 -100
2 24 34 56 -104 34 50 -104
2 24 26 56 -104 26 50 -104
2 24 26 50 -104 26 50 -100
2 24 36 56 -106 24 56 -106
2 24 34 50 -100 26 50 -100
2 24 24 56 -100 24 56 -106
2 24 26 50 -100 26 56 -100
2 24 34 50 -100 34 56 -100
2 24 26 56 -104 26 56 -100
2 24 34 56 -104 34 56 -100
2 24 36 56 -100 34 56 -100
2 24 36 48 -100 36 56 -100
4 16 36 56 -106 36 48 -104 36 44 -104 36 44 -106
4 16 24 44 -106 24 44 -104 24 48 -104 24 56 -106
4 16 36 44 -104 24 44 -104 24 44 -106 36 44 -106
4 16 36 44 -106 24 44 -106 24 56 -106 36 56 -106
4 16 36 48 -100 24 48 -100 24 48 -104 36 48 -104
4 16 34 50 -104 26 50 -104 26 50 -100 34 50 -100
4 16 -26 50 -104 -34 50 -104 -34 50 -100 -26 50 -100
4 16 -34 50 104 -26 50 104 -26 50 100 -34 50 100
4 16 26 50 104 34 50 104 34 50 100 26 50 100
4 16 36 48 -104 24 48 -104 24 44 -104 36 44 -104
4 16 24 48 -100 24 56 -100 24 56 -106 24 48 -104
4 16 36 48 -104 36 56 -106 36 56 -100 36 48 -100
4 16 26 56 -100 26 56 -104 24 56 -106 24 56 -100
4 16 36 56 -106 24 56 -106 26 56 -104 34 56 -104
4 16 34 56 -104 34 56 -100 36 56 -100 36 56 -106
2 24 -34 50 104 -26 50 104
2 24 -36 44 106 -24 44 106
2 24 -36 44 104 -24 44 104
2 24 -36 56 106 -36 44 106
2 24 -36 44 106 -36 44 104
2 24 -34 56 104 -26 56 104
2 24 -24 44 106 -24 44 104
2 24 -24 56 106 -24 44 106
2 24 -24 48 100 -24 56 100
2 24 -36 44 104 -36 48 104
2 24 -36 48 104 -36 48 100
2 24 -36 56 100 -36 56 106
2 24 -36 48 100 -24 48 100
2 24 -36 48 104 -24 48 104
2 24 -24 48 104 -24 48 100
2 24 -24 44 104 -24 48 104
2 24 -26 56 100 -24 56 100
2 24 -34 50 104 -34 50 100
2 24 -34 56 104 -34 50 104
2 24 -26 56 104 -26 50 104
2 24 -26 50 104 -26 50 100
2 24 -36 56 106 -24 56 106
2 24 -34 50 100 -26 50 100
2 24 -24 56 100 -24 56 106
2 24 -26 50 100 -26 56 100
2 24 -34 50 100 -34 56 100
2 24 -26 56 104 -26 56 100
2 24 -34 56 104 -34 56 100
2 24 -36 56 100 -34 56 100
2 24 -36 48 100 -36 56 100
4 16 -36 56 106 -36 48 104 -36 44 104 -36 44 106
4 16 -24 44 106 -24 44 104 -24 48 104 -24 56 106
4 16 -36 44 104 -24 44 104 -24 44 106 -36 44 106
4 16 -36 44 106 -24 44 106 -24 56 106 -36 56 106
4 16 -36 48 100 -24 48 100 -24 48 104 -36 48 104
4 16 -36 48 104 -24 48 104 -24 44 104 -36 44 104
4 16 -24 48 104 -24 48 100 -24 56 100 -24 56 106
4 16 -36 48 104 -36 56 106 -36 56 100 -36 48 100
4 16 -26 56 100 -26 56 104 -24 56 106 -24 56 100
4 16 -36 56 106 -24 56 106 -26 56 104 -34 56 104
4 16 -34 56 104 -34 56 100 -36 56 100 -36 56 106
2 24 26 50 104 34 50 104
4 16 26 56 104 34 56 104 34 50 104 26 50 104
4 16 26 56 100 26 56 104 26 50 104 26 50 100
4 16 34 56 104 34 56 100 34 50 100 34 50 104
4 16 -34 56 100 -34 56 104 -34 50 104 -34 50 100
4 16 -26 56 104 -26 56 100 -26 50 100 -26 50 104
4 16 -26 56 -100 -26 56 -104 -26 50 -104 -26 50 -100
4 16 -34 56 -104 -34 56 -100 -34 50 -100 -34 50 -104
4 16 34 56 -100 34 56 -104 34 50 -104 34 50 -100
4 16 26 56 -104 26 56 -100 26 50 -100 26 50 -104
4 16 -34 56 104 -26 56 104 -26 50 104 -34 50 104
4 16 -26 56 -104 -34 56 -104 -34 50 -104 -26 50 -104
4 16 34 56 -104 26 56 -104 26 50 -104 34 50 -104
2 24 24 44 106 36 44 106
2 24 24 44 104 36 44 104
2 24 24 56 106 24 44 106
2 24 24 44 106 24 44 104
2 24 26 56 104 34 56 104
2 24 36 44 106 36 44 104
2 24 36 56 106 36 44 106
2 24 36 48 100 36 56 100
2 24 24 44 104 24 48 104
2 24 24 48 104 24 48 100
2 24 24 56 100 24 56 106
2 24 24 48 100 36 48 100
2 24 24 48 104 36 48 104
2 24 36 48 104 36 48 100
2 24 36 44 104 36 48 104
2 24 34 56 100 36 56 100
2 24 26 50 104 26 50 100
2 24 26 56 104 26 50 104
2 24 34 56 104 34 50 104
2 24 34 50 104 34 50 100
2 24 24 56 106 36 56 106
2 24 26 50 100 34 50 100
2 24 36 56 100 36 56 106
2 24 34 50 100 34 56 100
2 24 26 50 100 26 56 100
2 24 34 56 104 34 56 100
2 24 26 56 104 26 56 100
2 24 24 56 100 26 56 100
2 24 24 48 100 24 56 100
4 16 24 56 106 24 48 104 24 44 104 24 44 106
4 16 36 44 106 36 44 104 36 48 104 36 56 106
4 16 24 44 104 36 44 104 36 44 106 24 44 106
4 16 24 44 106 36 44 106 36 56 106 24 56 106
4 16 24 48 100 36 48 100 36 48 104 24 48 104
4 16 24 48 104 36 48 104 36 44 104 24 44 104
4 16 36 48 104 36 48 100 36 56 100 36 56 106
4 16 24 48 104 24 56 106 24 56 100 24 48 100
4 16 34 56 100 34 56 104 36 56 106 36 56 100
4 16 26 56 104 26 56 100 24 56 100 24 56 106
4 16 24 56 106 36 56 106 34 56 104 26 56 104
2 24 -26 50 -104 -34 50 -104
2 24 -24 44 -106 -36 44 -106
2 24 -24 44 -104 -36 44 -104
2 24 -24 56 -106 -24 44 -106
2 24 -24 44 -106 -24 44 -104
2 24 -26 56 -104 -34 56 -104
2 24 -36 44 -106 -36 44 -104
2 24 -36 56 -106 -36 44 -106
2 24 -36 48 -100 -36 56 -100
2 24 -24 44 -104 -24 48 -104
2 24 -24 48 -104 -24 48 -100
2 24 -24 56 -100 -24 56 -106
2 24 -24 48 -100 -36 48 -100
2 24 -24 48 -104 -36 48 -104
2 24 -36 48 -104 -36 48 -100
2 24 -36 44 -104 -36 48 -104
2 24 -34 56 -100 -36 56 -100
2 24 -26 50 -104 -26 50 -100
2 24 -26 56 -104 -26 50 -104
2 24 -34 56 -104 -34 50 -104
2 24 -34 50 -104 -34 50 -100
2 24 -24 56 -106 -36 56 -106
2 24 -26 50 -100 -34 50 -100
2 24 -36 56 -100 -36 56 -106
2 24 -34 50 -100 -34 56 -100
2 24 -26 50 -100 -26 56 -100
2 24 -34 56 -104 -34 56 -100
2 24 -26 56 -104 -26 56 -100
2 24 -24 56 -100 -26 56 -100
2 24 -24 48 -100 -24 56 -100
4 16 -24 56 -106 -24 48 -104 -24 44 -104 -24 44 -106
4 16 -36 44 -106 -36 44 -104 -36 48 -104 -36 56 -106
4 16 -24 44 -104 -36 44 -104 -36 44 -106 -24 44 -106
4 16 -24 44 -106 -36 44 -106 -36 56 -106 -24 56 -106
4 16 -24 48 -100 -36 48 -100 -36 48 -104 -24 48 -104
4 16 -24 48 -104 -36 48 -104 -36 44 -104 -24 44 -104
4 16 -36 48 -100 -36 56 -100 -36 56 -106 -36 48 -104
4 16 -24 48 -104 -24 56 -106 -24 56 -100 -24 48 -100
4 16 -34 56 -100 -34 56 -104 -36 56 -106 -36 56 -100
4 16 -26 56 -104 -26 56 -100 -24 56 -100 -24 56 -106
4 16 -24 56 -106 -36 56 -106 -34 56 -104 -26 56 -104
1 16 40 40 0 0 -4 0 0 0 4 -4 0 0 2-4ndis.dat
1 16 40 40 0 0 4 0 0 0 4 4 0 0 2-4edge.dat
1 16 36 40 0 0 4 0 0 0 4 4 0 0 2-4edge.dat
1 16 40 40 0 0 -4 0 0 0 4 4 0 0 2-4cyli.dat
1 16 40 23 0 0 -6 0 0 0 -6 6 0 0 2-4ndis.dat
1 16 40 23 0 0 6 0 0 0 -6 -6 0 0 2-4edge.dat
1 16 36 23 0 0 6 0 0 0 -6 -6 0 0 2-4edge.dat
1 16 40 23 0 0 -4 0 0 0 -6 -6 0 0 2-4cyli.dat
4 16 40 40 6 40 23 6 40 27 3.5 40 40 4
2 24 40 23 6 40 27 3.5
2 24 40 27 3.5 40 40 4
2 24 36 23 6 36 27 3.5
2 24 36 27 3.5 36 40 4
4 16 36 23 6 36 27 3.5 40 27 3.5 40 23 6
4 16 40 40 4 40 27 3.5 36 27 3.5 36 40 4
4 16 40 27 -3.5 40 23 -6 40 40 -6 40 40 -4
4 16 40 44 -6 40 44 -4 40 40 -4 40 40 -6
4 16 40 44 4 40 44 6 40 40 6 40 40 4
2 24 40 23 -6 40 27 -3.5
2 24 36 23 -6 36 27 -3.5
2 24 40 27 -3.5 40 40 -4
2 24 36 27 -3.5 36 40 -4
4 16 40 23 -6 40 27 -3.5 36 27 -3.5 36 23 -6
4 16 36 40 -4 36 27 -3.5 40 27 -3.5 40 40 -4
4 16 36 17 6 36 16 6 36 16 -6 36 17 -6
1 16 36 40 0 0 4 0 0 0 4 4 0 0 2-4ndis.dat
1 16 36 23 0 0 6 0 0 0 -6 -6 0 0 2-4ndis.dat
3 16 36 40 4 36 27 3.5 36 23 6
3 16 36 40 4 36 40 6 36 23 6
3 16 36 40 -4 36 40 -6 36 23 -6
4 16 36 44 -6 36 44 -4 36 40 -4 36 40 -6
4 16 36 44 6 36 44 4 36 40 4 36 40 6
3 16 36 40 -4 36 27 -3.5 36 23 -6
1 16 -40 40 0 0 4 0 0 0 4 4 0 0 2-4ndis.dat
1 16 -40 40 0 0 -4 0 0 0 4 -4 0 0 2-4edge.dat
1 16 -36 40 0 0 -4 0 0 0 4 -4 0 0 2-4edge.dat
1 16 -40 40 0 0 4 0 0 0 4 -4 0 0 2-4cyli.dat
1 16 -40 23 0 0 6 0 0 0 -6 -6 0 0 2-4ndis.dat
1 16 -40 23 0 0 -6 0 0 0 -6 6 0 0 2-4edge.dat
1 16 -36 23 0 0 -6 0 0 0 -6 6 0 0 2-4edge.dat
1 16 -40 23 0 0 4 0 0 0 -6 6 0 0 2-4cyli.dat
4 16 -40 40 -6 -40 23 -6 -40 27 -3.5 -40 40 -4
2 24 -40 23 -6 -40 27 -3.5
2 24 -40 27 -3.5 -40 40 -4
2 24 -36 23 -6 -36 27 -3.5
2 24 -36 27 -3.5 -36 40 -4
4 16 -36 23 -6 -36 27 -3.5 -40 27 -3.5 -40 23 -6
4 16 -40 40 -4 -40 27 -3.5 -36 27 -3.5 -36 40 -4
4 16 -40 27 3.5 -40 23 6 -40 40 6 -40 40 4
4 16 -40 44 6 -40 44 4 -40 40 4 -40 40 6
4 16 -40 44 -4 -40 44 -6 -40 40 -6 -40 40 -4
2 24 -40 23 6 -40 27 3.5
2 24 -36 23 6 -36 27 3.5
2 24 -40 27 3.5 -40 40 4
2 24 -36 27 3.5 -36 40 4
4 16 -40 23 6 -40 27 3.5 -36 27 3.5 -36 23 6
4 16 -36 40 4 -36 27 3.5 -40 27 3.5 -40 40 4
4 16 -36 17 -6 -36 16 -6 -36 16 6 -36 17 6
1 16 -36 40 0 0 -4 0 0 0 4 -4 0 0 2-4ndis.dat
1 16 -36 23 0 0 -6 0 0 0 -6 6 0 0 2-4ndis.dat
3 16 -36 40 -4 -36 27 -3.5 -36 23 -6
3 16 -36 40 -4 -36 40 -6 -36 23 -6
3 16 -36 40 4 -36 40 6 -36 23 6
4 16 -36 44 6 -36 44 4 -36 40 4 -36 40 6
4 16 -36 44 -6 -36 44 -4 -36 40 -4 -36 40 -6
3 16 -36 40 4 -36 27 3.5 -36 23 6
0 // in reality, these 4 wheels are different from 867.dat, but you can't disassemble them,
0 // so we don't need to design a separate wheel variant, instead can "abuse" 867.dat:
1 16 38 40 -60 0 0 -1 1 0 0 0 -1 0 867.dat
1 16 38 40 60 0 0 -1 1 0 0 0 -1 0 867.dat
1 16 -38 40 60 0 0 1 0 1 0 -1 0 0 867.dat
1 16 -38 40 -60 0 0 1 0 1 0 -1 0 0 867.dat
1 494 39 31 -4 0 -10 0 -15 0 0 0 0 -4 box4-7a.dat
1 494 39 31 4 0 -10 0 -15 0 0 0 0 4 box4-7a.dat
1 494 -39 31 4 0 10 0 -15 0 0 0 0 4 box4-7a.dat
1 494 -39 31 -4 0 10 0 -15 0 0 0 0 -4 box4-7a.dat
1 495 11.5 50.5 -80 -1 0 0 0 1 0 0 0 -1 u9130.dat
1 495 -11.5 50.5 -80 -1 0 0 0 1 0 0 0 -1 u9130.dat
1 495 -11.5 50.5 80 1 0 0 0 1 0 0 0 1 u9130.dat
1 495 11.5 50.5 80 1 0 0 0 1 0 0 0 1 u9130.dat
1 16 11.5 56 -80 9 0 0 0 1 0 0 0 9 4-4edge.dat
1 16 -11.5 56 -80 9 0 0 0 1 0 0 0 9 4-4edge.dat
1 16 11.5 56 -80 9 0 0 0 -1 0 0 0 9 4-4ndis.dat
1 16 -11.5 56 -80 9 0 0 0 -1 0 0 0 9 4-4ndis.dat
4 16 2.5 56 -71 2.5 56 -89 -2.5 56 -89 -2.5 56 -71
4 16 40 56 -62 20.5 56 -71 -20.5 56 -71 -40 56 -62
4 16 -40 56 -62 -20.5 56 -71 -20.5 56 -89 -40 56 -100
4 16 -40 56 -100 -20.5 56 -89 20.5 56 -89 40 56 -100
4 16 40 56 -100 20.5 56 -89 20.5 56 -71 40 56 -62
1 16 11.5 56 80 9 0 0 0 1 0 0 0 9 4-4edge.dat
1 16 -11.5 56 80 9 0 0 0 1 0 0 0 9 4-4edge.dat
1 16 11.5 56 80 9 0 0 0 -1 0 0 0 9 4-4ndis.dat
1 16 -11.5 56 80 9 0 0 0 -1 0 0 0 9 4-4ndis.dat
4 16 2.5 56 89 2.5 56 71 -2.5 56 71 -2.5 56 89
4 16 40 56 100 20.5 56 89 -20.5 56 89 -40 56 100
4 16 -40 56 100 -20.5 56 89 -20.5 56 71 -40 56 62
4 16 -40 56 62 -20.5 56 71 20.5 56 71 40 56 62
4 16 -40 56 -62 -40 56 62 40 56 62 40 56 -62
4 16 40 56 62 20.5 56 71 20.5 56 89 40 56 100
Official
