Official File parts/22969.dat
0 ~Wheel 56 x 46 Technic Racing (Obsolete)
0 Name: 22969.dat
0 Author: Marc Klein [marckl]
0 !CATEGORY Obsolete
0 !HISTORY 2004-10-26 [sbliss] Reorg'ed and substituted primitives for polygons/edges to eliminate 1 subfile and reduce filesize; BFC'ed
0 !HISTORY 2007-11-17 [mikeheide] converted to hi-res, some minor changes
0 !HISTORY 2011-11-06 [MagFors] renamed, moved loose conditional lines to subfile
0 !HISTORY 2022-02-01 [MagFors] Reworked axleholes, removed edgeline
0 !HISTORY 2022-04-14 [MagFors] obsoleted due to bad geometry
1 16 0 0 0 0 0 1 0 1 0 -1 0 0 s\22969s01.dat
1 16 0 0 0 0 -.86603 -.5 0 -.5 .86603 -1 0 0 s\22969s01.dat
1 16 0 0 0 0 .86603 -.5 0 -.5 -.86603 -1 0 0 s\22969s01.dat
1 16 0 0 0 0 0 -1 0 1 0 -1 0 0 s\22969s01.dat
1 16 0 0 0 0 .86603 .5 0 -.5 .86603 -1 0 0 s\22969s01.dat
1 16 0 0 0 0 -.86603 .5 0 -.5 -.86603 -1 0 0 s\22969s01.dat
1 16 0 20 -12 1 0 0 0 0 -1 0 1 0 connhole.dat
1 16 17.3205 -10 -12 -.5 0 -.866 -.866 0 .5 0 1 0 connhole.dat
1 16 -17.3205 -10 -12 -.5 0 .866 .866 0 .5 0 1 0 connhole.dat
0 // center axlehole
1 16 0 0 -22 7.7942 0 -4.5 4.5 0 7.7942 0 -8 0 4-4cylo.dat
1 16 0 0 -15 -3 0 -5.1962 5.1962 0 -3 0 -15 0 4-4cyli.dat
1 16 0 0 -30 -3 0 -5.1962 5.1962 0 -3 0 -1 0 4-4edge.dat
1 16 0 0 -30 1.5 0 2.5981 -2.5981 0 1.5 0 1 0 4-4ring2.dat
1 16 0 0 -15 7.7942 0 4.5 4.5 0 -7.7942 0 25 0 4-4cylo.dat
1 16 0 0 10 .866 0 -.5 .5 0 .866 0 -1 0 axl2hol2.dat
1 16 0 0 -15 .866 0 -.5 .5 0 .866 0 -1 0 axl2hol3.dat
1 16 0 0 10 .866 0 -.5 .5 0 .866 0 -1 0 axl2hol9.dat
1 16 0 0 -15 .866 0 -.5 .5 0 .866 0 -1 0 axl2hol9.dat
1 16 0 0 10 .866 0 -.5 .5 0 .866 0 -25 0 axl2hol8.dat
1 16 0 0 10 .866 0 -.5 .5 0 .866 0 -1 0 axl2ho10.dat
1 16 0 0 -15 .866 0 -.5 .5 0 .866 0 1 0 axl2ho10.dat
1 16 0 0 10 5.196 0 -3 3 0 5.196 0 -1 0 4-4ering.dat
1 16 0 0 10 1.5 0 -2.5981 -2.5981 0 -1.5 0 -1 0 4-4ring2.dat
0 // outer edge rings
1 16 0 0 -58 51.9615 0 30 30 0 -51.9615 0 1 0 48\4-4edge.dat
1 16 0 0 -34.32 51.9615 0 30 30 0 -51.9615 0 1 0 48\4-4edge.dat
1 16 0 0 -27.92 45.0333 0 26 26 0 -45.0333 0 1 0 48\4-4edge.dat
1 16 0 0 -2 45.0333 0 26 26 0 -45.0333 0 1 0 48\4-4edge.dat
1 16 0 0 -2 49.3634 0 28.5 28.5 0 -49.3634 0 1 0 48\4-4edge.dat
1 16 0 0 58 51.9615 0 30 30 0 -51.9615 0 1 0 48\4-4edge.dat
1 16 0 0 -58 58.8897 0 34 34 0 -58.8897 0 1 0 48\4-4edge.dat
1 16 0 0 -53 58.8897 0 34 34 0 -58.8897 0 1 0 48\4-4edge.dat
1 16 0 0 -53 55.4256 0 32 32 0 -55.4256 0 1 0 48\4-4edge.dat
1 16 0 0 -48 55.4256 0 32 32 0 -55.4256 0 1 0 48\4-4edge.dat
1 16 0 0 -48 65.8179 0 38 38 0 -65.8179 0 1 0 48\4-4edge.dat
1 16 0 0 -44 65.8179 0 38 38 0 -65.8179 0 1 0 48\4-4edge.dat
1 16 0 0 -44 57.1577 0 33 33 0 -57.1577 0 1 0 48\4-4edge.dat
1 16 0 0 -34 57.1577 0 33 33 0 -57.1577 0 1 0 48\4-4edge.dat
1 16 0 0 -26 48.4974 0 28 28 0 -48.4974 0 1 0 48\4-4edge.dat
1 16 0 0 -6 48.4974 0 28 28 0 -48.4974 0 1 0 48\4-4edge.dat
1 16 0 0 -6 51.9615 0 30 30 0 -51.9615 0 1 0 48\4-4edge.dat
1 16 0 0 44 57.1577 0 33 33 0 -57.1577 0 1 0 48\4-4edge.dat
1 16 0 0 44 65.8179 0 38 38 0 -65.8179 0 1 0 48\4-4edge.dat
1 16 0 0 48 65.8179 0 38 38 0 -65.8179 0 1 0 48\4-4edge.dat
1 16 0 0 48 55.4256 0 32 32 0 -55.4256 0 1 0 48\4-4edge.dat
1 16 0 0 53 55.4256 0 32 32 0 -55.4256 0 1 0 48\4-4edge.dat
1 16 0 0 53 58.8897 0 34 34 0 -58.8897 0 1 0 48\4-4edge.dat
1 16 0 0 58 58.8897 0 34 34 0 -58.8897 0 1 0 48\4-4edge.dat
0 // inside cylinder wall
1 16 0 0 -58 51.9615 0 30 30 0 -51.9615 0 23.68 0 48\4-4cyli.dat
0 // inlined cone goes here - part of s\22969s01.dat
1 16 0 0 -2 45.0333 0 26 26 0 -45.0333 0 -25.92 0 48\4-4cyli.dat
1 16 0 0 -2 3.4641 0 2 2 0 -3.4641 0 -1 0 48\4-4ring13.dat
1 16 0 0 -2 2.9037 0 1.6764 1.6764 0 -2.9037 0 -1 0 48\4-4ring16.dat
1 16 0 0 58 51.9615 0 30 30 0 -51.9615 0 -32 0 48\4-4cyli.dat
0 // front edge
1 16 0 0 -58 3.4641 0 2 2 0 -3.4641 0 1 0 48\1-4ring15.dat
1 16 0 0 -58 2 0 -3.4641 -3.4641 0 -2 0 1 0 48\1-4ring15.dat
1 16 0 0 -58 -3.4641 0 -2 -2 0 3.4641 0 1 0 48\1-4ring15.dat
1 16 0 0 -58 -2 0 3.4641 3.4641 0 2 0 1 0 48\1-4ring15.dat
1 16 0 0 -58 3.4641 0 2 2 0 -3.4641 0 1 0 48\4-4ring16.dat
0 // back edge
1 16 0 0 58 -3.4641 0 -2 2 0 -3.4641 0 -1 0 48\1-4ring15.dat
1 16 0 0 58 -2 0 3.4641 -3.4641 0 -2 0 -1 0 48\1-4ring15.dat
1 16 0 0 58 3.4641 0 2 -2 0 3.4641 0 -1 0 48\1-4ring15.dat
1 16 0 0 58 2 0 -3.4641 3.4641 0 2 0 -1 0 48\1-4ring15.dat
1 16 0 0 58 -3.4641 0 -2 2 0 -3.4641 0 -1 0 48\4-4ring16.dat
0 // outside cylinder wall
1 16 0 0 -53 58.8897 0 34 34 0 -58.8897 0 -5 0 48\4-4cyli.dat
1 16 0 0 -53 3.4641 0 -2 2 0 3.4641 0 -1 0 48\4-4ring16.dat
1 16 0 0 -48 55.4256 0 32 32 0 -55.4256 0 -5 0 48\4-4cyli.dat
1 16 0 0 -48 6.9282 0 4 4 0 -6.9282 0 1 0 48\1-4ring8.dat
1 16 0 0 -48 3.4641 0 2 2 0 -3.4641 0 1 0 48\1-4ring18.dat
1 16 0 0 -48 4 0 -6.9282 -6.9282 0 -4 0 1 0 48\1-4ring8.dat
1 16 0 0 -48 2 0 -3.4641 -3.4641 0 -2 0 1 0 48\1-4ring18.dat
1 16 0 0 -48 -6.9282 0 -4 -4 0 6.9282 0 1 0 48\1-4ring8.dat
1 16 0 0 -48 -3.4641 0 -2 -2 0 3.4641 0 1 0 48\1-4ring18.dat
1 16 0 0 -48 -4 0 6.9282 6.9282 0 4 0 1 0 48\1-4ring8.dat
1 16 0 0 -48 -2 0 3.4641 3.4641 0 2 0 1 0 48\1-4ring18.dat
1 16 0 0 -44 65.8179 0 38 38 0 -65.8179 0 -4 0 48\4-4cyli.dat
1 16 0 0 -44 5.1962 0 -3 3 0 5.1962 0 -1 0 48\1-4ring11.dat
1 16 0 0 -44 3.4641 0 -2 2 0 3.4641 0 -1 0 48\1-4ring18.dat
1 16 0 0 -44 3 0 5.1962 -5.1962 0 3 0 -1 0 48\1-4ring11.dat
1 16 0 0 -44 2 0 3.4641 -3.4641 0 2 0 -1 0 48\1-4ring18.dat
1 16 0 0 -44 -5.1962 0 3 -3 0 -5.1962 0 -1 0 48\1-4ring11.dat
1 16 0 0 -44 -3.4641 0 2 -2 0 -3.4641 0 -1 0 48\1-4ring18.dat
1 16 0 0 -44 -3 0 -5.1962 5.1962 0 -3 0 -1 0 48\1-4ring11.dat
1 16 0 0 -44 -2 0 -3.4641 3.4641 0 -2 0 -1 0 48\1-4ring18.dat
1 16 0 0 -34 57.1577 0 33 33 0 -57.1577 0 -10 0 48\4-4cyli.dat
1 16 0 0 -34 1.7321 0 -1 1 0 1.7321 0 1.6 0 48\1-4con32.dat
1 16 0 0 -34 -1 0 -1.7321 1.7321 0 -1 0 1.6 0 48\1-4con32.dat
1 16 0 0 -34 -1.7321 0 1 -1 0 -1.7321 0 1.6 0 48\1-4con32.dat
1 16 0 0 -34 1 0 1.7321 -1.7321 0 1 0 1.6 0 48\1-4con32.dat
1 16 0 0 -32.4 6.9282 0 -4 4 0 6.9282 0 6.4 0 48\4-4con7.dat
1 16 0 0 -6 48.4974 0 28 28 0 -48.4974 0 -20 0 48\4-4cyli.dat
1 16 0 0 -6 3.4641 0 2 2 0 -3.4641 0 1 0 48\1-4ring14.dat
1 16 0 0 -6 2 0 -3.4641 -3.4641 0 -2 0 1 0 48\1-4ring14.dat
1 16 0 0 -6 -3.4641 0 -2 -2 0 3.4641 0 1 0 48\1-4ring14.dat
1 16 0 0 -6 -2 0 3.4641 3.4641 0 2 0 1 0 48\1-4ring14.dat
1 16 0 0 2 3.4641 0 2 2 0 -3.4641 0 -8 0 48\1-4con15.dat
1 16 0 0 2 -2 0 3.4641 3.4641 0 2 0 -8 0 48\1-4con15.dat
1 16 0 0 2 -3.4641 0 -2 -2 0 3.4641 0 -8 0 48\1-4con15.dat
1 16 0 0 2 2 0 -3.4641 -3.4641 0 -2 0 -8 0 48\1-4con15.dat
1 16 0 0 26 1.7321 0 1 1 0 -1.7321 0 -24 0 48\1-4con32.dat
1 16 0 0 26 -1 0 1.7321 1.7321 0 1 0 -24 0 48\1-4con32.dat
1 16 0 0 26 -1.7321 0 -1 -1 0 1.7321 0 -24 0 48\1-4con32.dat
1 16 0 0 26 1 0 -1.7321 -1.7321 0 -1 0 -24 0 48\1-4con32.dat
1 16 0 0 44 57.1577 0 33 33 0 -57.1577 0 -18 0 48\4-4cyli.dat
1 16 0 0 44 5.1962 0 3 3 0 -5.1962 0 1 0 48\1-4ring11.dat
1 16 0 0 44 3.4641 0 2 2 0 -3.4641 0 1 0 48\1-4ring18.dat
1 16 0 0 44 -3 0 5.1962 5.1962 0 3 0 1 0 48\1-4ring11.dat
1 16 0 0 44 -2 0 3.4641 3.4641 0 2 0 1 0 48\1-4ring18.dat
1 16 0 0 44 -5.1962 0 -3 -3 0 5.1962 0 1 0 48\1-4ring11.dat
1 16 0 0 44 -3.4641 0 -2 -2 0 3.4641 0 1 0 48\1-4ring18.dat
1 16 0 0 44 3 0 -5.1962 -5.1962 0 -3 0 1 0 48\1-4ring11.dat
1 16 0 0 44 2 0 -3.4641 -3.4641 0 -2 0 1 0 48\1-4ring18.dat
1 16 0 0 48 65.8179 0 38 38 0 -65.8179 0 -4 0 48\4-4cyli.dat
1 16 0 0 48 6.9282 0 -4 4 0 6.9282 0 -1 0 48\1-4ring8.dat
1 16 0 0 48 3.4641 0 -2 2 0 3.4641 0 -1 0 48\1-4ring18.dat
1 16 0 0 48 -4 0 -6.9282 6.9282 0 -4 0 -1 0 48\1-4ring8.dat
1 16 0 0 48 -2 0 -3.4641 3.4641 0 -2 0 -1 0 48\1-4ring18.dat
1 16 0 0 48 -6.9282 0 4 -4 0 -6.9282 0 -1 0 48\1-4ring8.dat
1 16 0 0 48 -3.4641 0 2 -2 0 -3.4641 0 -1 0 48\1-4ring18.dat
1 16 0 0 48 4 0 6.9282 -6.9282 0 4 0 -1 0 48\1-4ring8.dat
1 16 0 0 48 2 0 3.4641 -3.4641 0 2 0 -1 0 48\1-4ring18.dat
1 16 0 0 53 55.4256 0 32 32 0 -55.4256 0 -5 0 48\4-4cyli.dat
1 16 0 0 53 3.4641 0 2 2 0 -3.4641 0 1 0 48\4-4ring16.dat
1 16 0 0 58 58.8897 0 34 34 0 -58.8897 0 -5 0 48\4-4cyli.dat
5 24 .0008 63.9986 2 -8.3534 63.4541 2 -7.8313 59.4882 -6 0 66 26
5 24 38.9613 50.7762 2 31.9986 55.4248 2 30 51.9616 -6 40.1808 52.3644 26
5 24 63.4541 8.3534 2 61.8172 16.5647 2 65.4324 8.613 26 57.9556 15.5291 -6
5 24 66 0 26 65.4324 8.613 26 63.4541 8.3534 2 66 0 44
5 24 52.3644 -40.1808 26 57.156 -33 26 52.3644 -40.1808 44 55.4248 -31.9986 2
5 24 -24.4918 59.1249 2 -32 55.4256 2 -30 51.9615 -6 -25.2582 60.9774 26
5 24 -50.7729 -38.9578 2 -45.254 -45.2529 2 -52.3644 -40.1808 26 -42.4256 -42.4246 -6
5 24 -8.613 65.4324 26 -17.0808 63.7494 26 -8.613 65.4324 44 -16.5647 61.8172 2
5 24 -24.4931 -59.1319 2 -16.5642 -61.8186 2 -15.529 -57.955 -6 -25.2582 -60.9774 26
5 24 -40.1808 -52.3644 26 -33 -57.156 26 -31.9986 -55.4248 2 -40.1808 -52.3644 44
5 24 24.4918 -59.1249 2 32 -55.4256 2 30 -51.9615 -6 25.2582 -60.9774 26
5 24 -61.8186 16.5642 2 -63.4563 8.3543 2 -59.4866 7.8315 -6 -63.7494 17.0808 26
5 24 -63.7494 -17.0808 26 -60.9774 -25.2582 26 -63.7494 -17.0808 44 -59.1249 -24.4918 2
5 24 0 -66 26 8.613 -65.4324 26 8.3534 -63.4541 2 0 -66 44
5 24 24.4931 59.1319 2 16.5642 61.8186 2 25.2582 60.9774 26 15.5291 57.9555 -6
5 24 -8.613 -65.4324 26 0 -66 26 -8.613 -65.4324 44 -.0008 -63.9986 2
5 24 -57.156 -33 26 -52.3644 -40.1808 26 -57.156 -33 44 -50.7729 -38.9578 2
5 24 65.4324 -8.613 26 66 0 26 63.9986 -.0008 2 65.4324 -8.613 44
5 24 -33 57.156 26 -40.1808 52.3644 26 -33 57.156 44 -38.9578 50.7729 2
5 24 -65.4324 8.613 26 -66 0 26 -63.9986 .0008 2 -65.4324 8.613 44
5 24 -50.7762 38.9613 2 -55.4248 31.9986 2 -51.9608 29.9987 -6 -52.3644 40.1808 26
5 24 63.9986 -.0008 2 63.4541 8.3534 2 66 0 26 59.4882 7.8313 -6
5 24 63.7494 17.0808 26 60.9774 25.2582 26 63.7494 17.0808 44 59.1265 24.4916 2
5 24 55.4248 -31.9986 2 59.1319 -24.4931 2 55.4362 -22.9623 -6 57.156 -33 26
5 24 65.4324 8.613 26 63.7494 17.0808 26 61.8172 16.5647 2 65.4324 8.613 44
5 24 -52.3644 -40.1808 26 -46.6686 -46.6686 26 -52.3644 -40.1808 44 -45.254 -45.2529 2
5 24 -.0008 -63.9986 2 8.3534 -63.4541 2 7.8314 -59.4868 -6 0 -66 26
5 24 -46.6686 46.6686 26 -52.3644 40.1808 26 -50.7762 38.9613 2 -46.6686 46.6686 44
5 24 25.2582 -60.9774 26 33 -57.156 26 32 -55.4256 2 25.2582 -60.9774 44
5 24 52.3644 40.1808 26 46.6686 46.6686 26 45.254 45.2529 2 52.3644 40.1808 44
5 24 63.4563 -8.3543 2 63.9986 -.0008 2 60 .0001 -6 65.4324 -8.613 26
5 24 -59.1319 24.4931 2 -61.8186 16.5642 2 -57.955 15.529 -6 -60.9774 25.2582 26
5 24 17.0808 -63.7494 26 25.2582 -60.9774 26 24.4918 -59.1249 2 17.0808 -63.7494 44
5 24 16.5642 61.8186 2 8.3543 63.4563 2 17.0808 63.7494 26 7.8322 59.4903 -6
5 24 60.9774 25.2582 26 57.156 33 26 60.9774 25.2582 44 55.4256 32 2
5 24 50.7729 38.9578 2 45.254 45.2529 2 42.4264 42.4265 -6 52.3644 40.1808 26
5 24 33 57.156 26 25.2582 60.9774 26 24.4931 59.1319 2 33 57.156 44
5 24 8.3534 -63.4541 2 16.5647 -61.8172 2 15.5294 -57.9536 -6 8.613 -65.4324 26
5 24 -32 55.4256 2 -38.9578 50.7729 2 -36.523 47.5996 -6 -33 57.156 26
5 24 32 -55.4256 2 38.958 -50.7745 2 36.5258 -47.6013 -6 33 -57.156 26
5 24 55.4256 32 2 50.7729 38.9578 2 47.6013 36.5258 -6 57.156 33 26
5 24 -63.4563 8.3543 2 -63.9986 .0008 2 -59.9987 .0008 -6 -65.4324 8.613 26
5 24 8.613 65.4324 26 0 66 26 .0008 63.9986 2 8.613 65.4324 44
5 24 25.2582 60.9774 26 17.0808 63.7494 26 16.5642 61.8186 2 25.2582 60.9774 44
5 24 -45.254 -45.2529 2 -38.9613 -50.7762 2 -46.6686 -46.6686 26 -36.5256 -47.6014 -6
5 24 -63.4541 -8.3534 2 -61.8172 -16.5647 2 -65.4324 -8.613 26 -57.9536 -15.5294 -6
5 24 -25.2582 -60.9774 26 -17.0808 -63.7494 26 -25.2582 -60.9774 44 -16.5642 -61.8186 2
5 24 46.6686 -46.6686 26 52.3644 -40.1808 26 50.7762 -38.9613 2 46.6686 -46.6686 44
5 24 -40.1808 52.3644 26 -46.6686 46.6686 26 -40.1808 52.3644 44 -45.2529 45.254 2
5 24 -45.2529 45.254 2 -50.7762 38.9613 2 -47.6014 36.5256 -6 -46.6686 46.6686 26
5 24 -38.9613 -50.7762 2 -31.9986 -55.4248 2 -40.1808 -52.3644 26 -29.9987 -51.9608 -6
5 24 -17.0808 63.7494 26 -25.2582 60.9774 26 -17.0808 63.7494 44 -24.4918 59.1249 2
5 24 50.7762 -38.9613 2 55.4248 -31.9986 2 52.3644 -40.1808 26 51.9616 -30 -6
5 24 -63.9986 .0008 2 -63.4541 -8.3534 2 -59.4868 -7.8314 -6 -66 0 26
5 24 59.1319 -24.4931 2 61.8186 -16.5642 2 57.9555 -15.5291 -6 60.9774 -25.2582 26
5 24 -60.9774 25.2582 26 -63.7494 17.0808 26 -61.8186 16.5642 2 -60.9774 25.2582 44
5 24 8.3543 63.4563 2 .0008 63.9986 2 8.613 65.4324 26 -.0001 60 -6
5 24 61.8172 16.5647 2 59.1265 24.4916 2 63.7494 17.0808 26 55.4329 22.961 -6
5 24 46.6686 46.6686 26 40.1808 52.3644 26 38.9613 50.7762 2 46.6686 46.6686 44
5 24 -16.5647 61.8172 2 -24.4918 59.1249 2 -22.961 55.4296 -6 -17.0808 63.7494 26
5 24 40.1808 52.3644 26 33 57.156 26 31.9986 55.4248 2 40.1808 52.3644 44
5 24 60.9774 -25.2582 26 63.7494 -17.0808 26 61.8186 -16.5642 2 60.9774 -25.2582 44
5 24 -60.9774 -25.2582 26 -57.156 -33 26 -60.9774 -25.2582 44 -55.4256 -32 2
5 24 8.613 -65.4324 26 17.0808 -63.7494 26 16.5647 -61.8172 2 8.613 -65.4324 44
5 24 -8.3543 -63.4563 2 -.0008 -63.9986 2 -.0008 -59.9987 -6 -8.613 -65.4324 26
5 24 33 -57.156 26 40.1808 -52.3644 26 38.958 -50.7745 2 33 -57.156 44
5 24 17.0808 63.7494 26 8.613 65.4324 26 8.3543 63.4563 2 17.0808 63.7494 44
5 24 45.254 45.2529 2 38.9613 50.7762 2 36.5262 47.6027 -6 46.6686 46.6686 26
5 24 63.7494 -17.0808 26 65.4324 -8.613 26 63.4563 -8.3543 2 63.7494 -17.0808 44
5 24 -59.1249 -24.4918 2 -55.4256 -32 2 -60.9774 -25.2582 26 -51.9615 -30 -6
5 24 57.156 33 26 52.3644 40.1808 26 57.156 33 44 50.7729 38.9578 2
5 24 59.1265 24.4916 2 55.4256 32 2 51.9615 30 -6 60.9774 25.2582 26
5 24 61.8186 -16.5642 2 63.4563 -8.3543 2 59.4903 -7.8322 -6 63.7494 -17.0808 26
5 24 -38.9578 50.7729 2 -45.2529 45.254 2 -42.4246 42.4256 -6 -40.1808 52.3644 26
5 24 -57.156 33 26 -60.9774 25.2582 26 -59.1319 24.4931 2 -57.156 33 44
5 24 -17.0808 -63.7494 26 -8.613 -65.4324 26 -17.0808 -63.7494 44 -8.3543 -63.4563 2
5 24 40.1808 -52.3644 26 46.6686 -46.6686 26 45.2529 -45.254 2 40.1808 -52.3644 44
5 24 31.9986 55.4248 2 24.4931 59.1319 2 22.9623 55.4362 -6 33 57.156 26
5 24 -33 -57.156 26 -25.2582 -60.9774 26 -33 -57.156 44 -24.4931 -59.1319 2
5 24 -55.4248 31.9986 2 -59.1319 24.4931 2 -55.4327 22.961 -6 -57.156 33 26
5 24 -55.4256 -32 2 -50.7729 -38.9578 2 -57.156 -33 26 -47.5996 -36.523 -6
5 24 -25.2582 60.9774 26 -33 57.156 26 -25.2582 60.9774 44 -32 55.4256 2
5 24 -31.9986 -55.4248 2 -24.4931 -59.1319 2 -33 -57.156 26 -22.961 -55.4327 -6
5 24 -16.5642 -61.8186 2 -8.3543 -63.4563 2 -7.8315 -59.4866 -6 -17.0808 -63.7494 26
5 24 16.5647 -61.8172 2 24.4918 -59.1249 2 22.961 -55.4329 -6 17.0808 -63.7494 26
5 24 0 66 26 -8.613 65.4324 26 0 66 44 -8.3534 63.4541 2
5 24 -8.3534 63.4541 2 -16.5647 61.8172 2 -15.5291 57.9556 -6 -8.613 65.4324 26
5 24 -46.6686 -46.6686 26 -40.1808 -52.3644 26 -46.6686 -46.6686 44 -38.9613 -50.7762 2
5 24 -61.8172 -16.5647 2 -59.1249 -24.4918 2 -63.7494 -17.0808 26 -55.4296 -22.961 -6
5 24 -52.3644 40.1808 26 -57.156 33 26 -55.4248 31.9986 2 -52.3644 40.1808 44
5 24 -63.7494 17.0808 26 -65.4324 8.613 26 -63.4563 8.3543 2 -63.7494 17.0808 44
5 24 38.958 -50.7745 2 45.2529 -45.254 2 40.1808 -52.3644 26 42.4265 -42.4264 -6
5 24 -65.4324 -8.613 26 -63.7494 -17.0808 26 -65.4324 -8.613 44 -61.8172 -16.5647 2
5 24 -66 0 26 -65.4324 -8.613 26 -66 0 44 -63.4541 -8.3534 2
5 24 45.2529 -45.254 2 50.7762 -38.9613 2 46.6686 -46.6686 26 47.6027 -36.5262 -6
5 24 57.156 -33 26 60.9774 -25.2582 26 59.1319 -24.4931 2 57.156 -33 44
Official
