Official File parts/244.dat
0 ~Train Wheel Spoked with Conical Rim
0 Name: 244.dat
0 !KEYWORDS Motor
0 !HISTORY 2011-07-10 [MagFors] Closed gaps around the base of the spokes
0 !HISTORY 2018-03-14 [Holly-Wood] Changed description, fixed flat-scaled primitives, fixed comments, inverted winding to CCW, fixed spokes
0 !HISTORY 2019-08-30 [cwdee] Corrected diameter of axle hole
0 // Axle connector
1 16 0 0 -8 -4 0 0 0 0 4 0 -1 0 4-4disc.dat
1 16 0 0 10 4 0 0 0 0 4 0 -18 0 4-4cyli.dat
1 16 0 0 10 8 0 0 0 0 8 0 -2 0 4-4cyli.dat
1 16 0 0 10 -4 0 0 0 0 4 0 -1 0 4-4ring1.dat
1 16 0 0 -8 4 0 0 0 0 4 0 1 0 4-4edge.dat
1 16 0 0 10 4 0 0 0 0 4 0 1 0 4-4edge.dat
1 16 0 0 10 8 0 0 0 0 8 0 1 0 4-4edge.dat
0 // Wheel flange rear
1 16 0 0 8 -4 0 0 0 0 4 0 -1 0 4-4ring2.dat
1 16 0 0 8 -2 0 0 0 0 2 0 -1 0 4-4ring6.dat
1 16 0 0 8 -14 0 0 0 0 14 0 -1 0 4-4ring1.dat
1 16 0 0 8 8 0 0 0 0 8 0 1 0 4-4edge.dat
1 16 0 0 8 28 0 0 0 0 28 0 1 0 4-4edge.dat
0 // Wheel flange edge
1 16 0 0 8 28 0 0 0 0 28 0 -2 0 4-4cyli.dat
1 16 0 0 6 28 0 0 0 0 28 0 1 0 4-4edge.dat
1 16 0 0 5 4 0 0 0 0 4 0 -1 0 4-4con5.dat
1 16 0 0 6 4 0 0 0 0 4 0 -1 0 4-4con6.dat
0 // Wheel edge
1 16 0 0 4 18 0 0 0 0 18 0 1 0 4-4edge.dat
1 16 0 0 4 20 0 0 0 0 20 0 1 0 4-4edge.dat
1 16 0 0 4 2 0 0 0 0 2 0 1 0 4-4ring9.dat
1 16 0 0 -12 -2 0 0 0 0 2 0 16 0 4-4con9.dat
0 // Wheel front
1 16 0 0 -12 1 0 0 0 0 1 0 1 0 4-4ring19.dat
1 16 0 0 -12 1 0 0 0 0 1 0 1 0 4-4ring18.dat
1 16 0 0 -12 18 0 0 0 0 18 0 1 0 4-4edge.dat
1 16 0 0 -12 20 0 0 0 0 20 0 1 0 4-4edge.dat
1 16 0 0 -12 2 0 0 0 0 2 0 4 0 4-4con8.dat
0 // Wheel inside
1 16 0 0 3 16 0 0 0 0 16 0 -11 0 4-4cyli.dat
1 16 0 0 3 8 0 0 0 0 8 0 1 0 4-4ring1.dat
1 16 0 0 3 8 0 0 0 0 8 0 -15 0 4-4cyli.dat
1 16 0 0 -12 8 0 0 0 0 8 0 1 0 4-4disc.dat
1 16 0 0 -8 16 0 0 0 0 16 0 1 0 4-4edge.dat
1 16 0 0 3 16 0 0 0 0 16 0 1 0 4-4edge.dat
1 16 0 0 3 8 0 0 0 0 8 0 1 0 4-4edge.dat
1 16 0 0 -12 8 0 0 0 0 8 0 1 0 4-4edge.dat
1 16 0 0 -12 0 0 1 1 0 0 0 1 0 stud.dat
0 // Spokes
1 16 -1 -11.801 -2.5 0 1 0 -4 0 0 0 0 5.5 rect.dat
1 16 1 -11.801 -2.5 0 -1 0 0 0 4 -5.5 0 0 rect.dat
1 16 .5 -11.9005 -8 0 0 .5 4 0 .0995 0 1 0 rect1.dat
1 16 -.5 -11.9005 -8 0 0 .5 4 0 -.0995 0 1 0 rect1.dat
1 16 6.091 -10.085 -2.5 2.308 0 0 -3.176 1 0 0 0 5.5 rect.dat
1 16 7.7555 -8.973 -2.5 0 0 -2.3075 0 -1 3.176 -5.5 0 0 rect.dat
4 16 10.063 -12.149 -8 8.399 -13.261 -8 3.783 -6.909 -8 5.448 -5.797 -8
2 24 8.399 -13.261 -8 10.063 -12.149 -8
2 24 5.448 -5.797 -8 3.783 -6.909 -8
1 16 11.0045 -4.627 -2.5 0 0 -3.8285 0 1 1.244 5.5 0 0 rect.dat
4 16 7.711 -1.454 -8 15.225 -3.896 -8 14.833 -5.871 -8 7.391 -3.062 -8
3 16 7.391 -3.062 -8 14.833 -5.871 -8 7.176 -3.383 -8
1 16 11.468 -2.675 -2.5 3.757 0 0 -1.221 -1 0 0 0 -5.5 rect.dat
2 24 14.833 -5.871 -8 15.225 -3.896 -8
2 24 7.176 -3.383 -8 7.391 -3.062 -8
2 24 7.711 -1.454 -8 7.391 -3.062 -8
1 16 11.0045 4.627 -2.5 3.8285 0 0 1.244 -1 0 0 0 -5.5 rect.dat
4 16 14.833 5.871 -8 15.225 3.896 -8 7.711 1.454 -8 7.391 3.062 -8
3 16 14.833 5.871 -8 7.391 3.062 -8 7.176 3.383 -8
1 16 11.468 2.675 -2.5 0 0 -3.757 0 1 -1.221 5.5 0 0 rect.dat
2 24 14.833 5.871 -8 15.225 3.896 -8
2 24 7.176 3.383 -8 7.391 3.062 -8
2 24 7.711 1.454 -8 7.391 3.062 -8
1 16 6.091 10.085 -2.5 0 0 -2.308 0 -1 -3.176 -5.5 0 0 rect.dat
1 16 7.7555 8.973 -2.5 2.3075 0 0 3.176 1 0 0 0 5.5 rect.dat
4 16 3.783 6.909 -8 8.399 13.261 -8 10.063 12.149 -8 5.448 5.797 -8
2 24 8.399 13.261 -8 10.063 12.149 -8
2 24 5.448 5.797 -8 3.783 6.909 -8
1 16 1 11.801 -2.5 0 -1 0 4 0 0 0 0 5.5 rect.dat
1 16 -1 11.801 -2.5 0 1 0 0 0 -4 -5.5 0 0 rect.dat
1 16 -.5 11.9005 -8 0 0 -.5 -4 0 -.0995 0 1 0 rect1.dat
1 16 .5 11.9005 -8 0 0 -.5 -4 0 .0995 0 1 0 rect1.dat
1 16 -6.091 10.085 -2.5 -2.308 0 0 3.176 -1 0 0 0 5.5 rect.dat
1 16 -7.7555 8.973 -2.5 0 0 2.3075 0 1 -3.176 -5.5 0 0 rect.dat
4 16 -10.063 12.149 -8 -8.399 13.261 -8 -3.783 6.909 -8 -5.448 5.797 -8
2 24 -8.399 13.261 -8 -10.063 12.149 -8
2 24 -5.448 5.797 -8 -3.783 6.909 -8
1 16 -11.0045 4.627 -2.5 0 0 3.8285 0 -1 -1.244 5.5 0 0 rect.dat
4 16 -7.711 1.454 -8 -15.225 3.896 -8 -14.833 5.871 -8 -7.391 3.062 -8
3 16 -7.391 3.062 -8 -14.833 5.871 -8 -7.176 3.383 -8
1 16 -11.468 2.675 -2.5 -3.757 0 0 1.221 1 0 0 0 -5.5 rect.dat
2 24 -14.833 5.871 -8 -15.225 3.896 -8
2 24 -7.176 3.383 -8 -7.391 3.062 -8
2 24 -7.711 1.454 -8 -7.391 3.062 -8
1 16 -11.0045 -4.627 -2.5 -3.8285 0 0 -1.244 1 0 0 0 -5.5 rect.dat
4 16 -14.833 -5.871 -8 -15.225 -3.896 -8 -7.711 -1.454 -8 -7.391 -3.062 -8
3 16 -14.833 -5.871 -8 -7.391 -3.062 -8 -7.176 -3.383 -8
1 16 -11.468 -2.675 -2.5 0 0 3.757 0 -1 1.221 5.5 0 0 rect.dat
2 24 -14.833 -5.871 -8 -15.225 -3.896 -8
2 24 -7.176 -3.383 -8 -7.391 -3.062 -8
2 24 -7.711 -1.454 -8 -7.391 -3.062 -8
1 16 -6.091 -10.085 -2.5 0 0 2.308 0 1 3.176 -5.5 0 0 rect.dat
1 16 -7.7555 -8.973 -2.5 -2.3075 0 0 -3.176 -1 0 0 0 5.5 rect.dat
4 16 -3.783 -6.909 -8 -8.399 -13.261 -8 -10.063 -12.149 -8 -5.448 -5.797 -8
2 24 -8.399 -13.261 -8 -10.063 -12.149 -8
2 24 -5.448 -5.797 -8 -3.783 -6.909 -8
Official
