Official File parts/54562.dat
~Motor Inertia Flywheel  4 x  9 x  3.667 Housing
0 ~Motor Inertia Flywheel  4 x  9 x  3.667 Housing
0 Name: 54562.dat
0 !LDRAW_ORG Part UPDATE 2023-02
0 !CATEGORY Vehicle
0 !HISTORY 2007-09-23 [NXTbesu] BFC errors fixed, cleaning and better use of subparts
0 !HISTORY 2009-05-25 [NXTbesu] Subpart Filenames and filename changed, simplification, Rectified used axleholes
0 !HISTORY 2012-11-19 [MagFors] Moved content to separate parts, used stud groups
0 !HISTORY 2014-05-31 [MagFors] Added a fake lid on the far side
0 !HISTORY 2023-03-12 [GeraldLasser] Seperated Lid, added missing geometry, adjusted pin and axlehole positions, removed "needs Work"
0 !HISTORY 2023-04-17 [OrionP] Official Update 2023-02
0 // inside structure partially modeled
1 16 10 64 -70 0 0 -1 0 1 0 1 0 0 stug2-1x2.dat
1 16 -10 64 -70 0 0 -1 0 1 0 1 0 0 stug2-1x2.dat
1 16 10 64 60 0 0 -1 0 1 0 1 0 0 stud2.dat
1 16 -10 64 60 0 0 -1 0 1 0 1 0 0 stud2.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\54562s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\54562s01.dat
0 // Bottom
1 16 0 74 -82 2 0 0 0 0 10 0 4 0 box3u8p.dat
4 16 -2 76 -82 -2 84 -82 2 84 -82 2 76 -82
4 16 -2 76 -82 2 76 -82 2 72 -82 -2 72 -82
4 16 -2 72 -82 2 72 -82 2 64 -82 -2 64 -82
1 16 0 74 -50 0 0 2 10 0 0 0 1 0 rect1.dat
3 16 2 84 -50 -2 84 -50 0 84 -44
3 16 16 84 8 0 84 -42 -16 84 8
1 16 0 84 -50 0 0 1 0 -1 0 -1 0 0 stud21a.dat
1 16 0 84 -70 0 0 1 0 -1 0 -1 0 0 stud22a.dat
1 16 0 84 -30 0 0 1 0 -1 0 -1 0 0 stud4.dat
1 16 0 84 -10 0 0 1 0 -1 0 -1 0 0 stud4.dat
1 16 0 86 8 0 0 16 2 0 0 0 1 0 rect.dat
4 16 4 88 12 16 88 8 -16 88 8 -4 88 12
1 16 0 88 15.6967 -4 0 0 0 -4.3935 0 0 0 -3.6967 box4-4a.dat
1 16 0 88 44.30325 -4 0 0 0 -4.3935 0 0 0 3.6967 box4-4a.dat
1 16 -4 73 30 0 8 0 15 0 0 0 0 -15 1-8cylo.dat
1 16 -4 73 30 0 8 0 15 0 0 0 0 15 1-8cylo.dat
2 24 -4 83.6065 19.3934 4 83.6065 19.3934
2 24 -4 83.6065 40.6065 4 83.6065 40.6065
4 16 2 88 52 4 88 48 -4 88 48 -2 88 52
1 16 0 86 52 0 0 -2 2 0 0 0 -1 0 rect1.dat
1 16 0 74 50 2 0 0 0 0 10 0 -1 0 rect3.dat
1 16 0 84 51 2 0 0 0 1 0 0 0 1 rect3.dat
4 16 2 64 50 -2 64 50 -40 0 50 40 0 50
1 16 0 32 50 -40 0 0 0 0 -32 0 -1 0 recte3.dat
1 16 0 32 -50 -40 0 0 0 0 -32 0 -1 0 recte3.dat
4 16 40 0 -50 -40 0 -50 -2 64 -50 2 64 -50
0 // Top
1 16 -30 0 20 0 0 -6 0 1 0 6 0 0 4-4ndis.dat
1 16 -30 0 -20 0 0 -6 0 1 0 6 0 0 4-4ndis.dat
1 16 -30 0 20 0 0 -6 0 1 0 6 0 0 4-4edge.dat
1 16 -30 0 -20 0 0 -6 0 1 0 6 0 0 4-4edge.dat
4 16 -24 0 14 -30 0 14 -30 0 -14 -24 0 -14
4 16 -36 0 14 -36 0 -14 -30 0 -14 -30 0 14
3 16 -36 0 26 -40 0 50 -36 0 20
3 16 -36 0 20 -40 0 50 -36 0 14
4 16 -36 0 -14 -36 0 14 -40 0 50 -40 0 -50
3 16 -36 0 -14 -40 0 -50 -36 0 -20
3 16 -36 0 -20 -40 0 -50 -36 0 -26
3 16 -30 0 -26 -36 0 -26 -40 0 -50
4 16 -24 0 -26 -30 0 -26 -40 0 -50 40 0 -50
3 16 -24 0 -20 -24 0 -26 40 0 -50
3 16 -24 0 -20 40 0 -50 -24 0 -14
4 16 -24 0 14 -24 0 -14 40 0 -50 40 0 50
3 16 -24 0 14 40 0 50 -24 0 20
3 16 -24 0 26 -24 0 20 40 0 50
3 16 -36 0 26 -30 0 26 -40 0 50
4 16 -40 0 50 -30 0 26 -24 0 26 40 0 50
2 24 -40 0 50 -40 0 -50
2 24 40 0 50 40 0 -50
1 16 0 0 -40 0 0 -1 0 1 0 1 0 0 stug2-4x1.dat
1 16 10 0 -20 0 0 -1 0 1 0 1 0 0 stug2-3x1.dat
1 16 0 0 0 0 0 -1 0 1 0 1 0 0 stug2-4x1.dat
1 16 10 0 20 0 0 -1 0 1 0 1 0 0 stug2-3x1.dat
1 16 0 0 40 0 0 -1 0 1 0 1 0 0 stug2-4x1.dat
1 16 -30 0 20 0 0 -1 0 1 0 1 0 0 stud2a.dat
1 16 -30 0 -20 0 0 -1 0 1 0 1 0 0 stud2a.dat
0 // Closed Side
1 16 40 60.7 0 0 -1 0 0 0 6 6 0 0 4-4ndis.dat
1 16 40 60.7 0 0 2 0 0 0 6 6 0 0 bump5000.dat
1 16 39.5 74 30 0 -3.5 0 0 0 8.1 8.1 0 0 4-4cylo.dat
1 16 39.5 74 30 0 -1 0 0 0 1.35 1.35 0 0 4-4ring6.dat
1 16 40 74 30 0 -.5 0 0 0 9.45 9.45 0 0 4-4cylo.dat
1 16 40 74 30 0 -1 0 0 0 -9.45 9.45 0 0 4-4ndis.dat
4 16 40 83.6065 40.6065 40 82 41.6802 40 74 39.45 40 83.45 39.45
4 16 40 83.6065 40.6065 40 83.45 39.45 40 83.45 30 40 88 30
4 16 40 88 30 40 83.45 30 40 83.45 20.55 40 83.6065 19.3935
4 16 40 82 18.3198 40 83.6065 19.3935 40 83.45 20.55 40 74 20.55
4 16 40 73 -49.75 40 82 -48 40 82 18.3198 40 74 20.55
4 16 40 74 20.55 40 66.7 6 40 66.7 0 40 73 -49.75
4 16 40 60.7 6 40 66.7 6 40 74 20.55 40 64.55 20.55
4 16 40 60.7 -6 40 64 -49.75 40 73 -49.75 40 66.7 -6
3 16 40 64 -49.75 40 60.7 -6 40 54.7 -6
3 16 40 0 -50 40 54.7 -6 40 54.7 0
3 16 40 0 -50 40 54.7 0 40 54.7 6
4 16 40 0 -50 40 54.7 6 40 64.55 20.55 40 0 50
3 16 40 64.55 20.55 40 54.7 6 40 60.7 6
3 16 40 64.55 20.55 40 64.55 30 40 0 50
3 16 40 66.7 0 40 66.7 -6 40 73 -49.75
4 16 40 54.7 -6 40 0 -50 40 64 -50 40 64 -49.75
4 16 40 64.55 30 40 64.55 39.45 40 64 49.75 40 0 50
3 16 40 64 49.75 40 64 50 40 0 50
4 16 40 64 49.75 40 64.55 39.45 40 74 39.45 40 73 49.75
4 16 40 82 48 40 73 49.75 40 74 39.45 40 82 41.6802
2 24 40 82 18.3198 40 82 -48
2 24 20 82 -48 20 82 18.3198
4 16 40 82 18.3198 40 82 -48 20 82 -48 20 82 18.3198
0 // Lip
1 16 -40 3 25 0 0 1 -1 0 0 0 -10 0 tri3u1.dat
1 16 -40 3 -15 0 0 1 -1 0 0 0 -10 0 tri3u1.dat
4 16 -40 3 -25 -40 3 -46 -40 0 -50 -40 2 -25
4 16 -40 2 -15 -40 0 -50 -40 0 50 -40 2 15
4 16 -40 3 -15 -40 2 -15 -40 2 15 -40 3 15
3 16 -40 2 -15 -40 2 -25 -40 0 -50
3 16 -40 2 25 -40 2 15 -40 0 50
4 16 -40 0 50 -40 3 46 -40 3 25 -40 2 25
2 24 -40 3 25 -40 3 46
2 24 -40 3 -15 -40 3 15
2 24 -40 3 -46 -40 3 -25
4 16 -40 71 -46 -40 78 -44.5 -40 82 -48 -40 73 -49.75
3 16 -40 71 -46 -40 73 -49.75 -40 64 -49.75
4 16 -40 0 -50 -40 3 -46 -40 64 -49.75 -40 64 -50
3 16 -40 3 -46 -40 71 -46 -40 64 -49.75
4 16 -40 73 49.75 -40 82 48 -40 78 44.5 -40 71 46
3 16 -40 71 46 -40 64 49.75 -40 73 49.75
3 16 -40 64 49.75 -40 71 46 -40 3 46
4 16 -40 3 46 -40 0 50 -40 64 50 -40 64 49.75
1 16 -40 78 6 0 0 1 1 0 0 0 -10 0 tri3u1.dat
1 16 -40 78 -15 0 0 1 1 0 0 0 -10 0 tri3u1.dat
4 16 -40 78 -15 -40 78 -4 -40 79 -4 -40 79 -15
4 16 -40 78 6 -40 78 19.7754 -40 82 18.3198 -40 79 6
4 16 -40 78 -44.5 -40 78 -25 -40 79 -25 -40 82 -48
3 16 -40 82 -48 -40 79 -25 -40 79 -15
4 16 -40 79 -15 -40 79 -4 -40 82 18.3198 -40 82 -48
3 16 -40 82 18.3198 -40 79 -4 -40 79 6
4 16 -40 81.13165 38.13165 -40 78 40.2246 -40 82 41.6802 -40 83.6066 40.6066
4 16 -40 83.6066 19.3934 -40 82 18.3198 -40 78 19.7754 -40 81.13165 21.86835
4 16 -40 78 44.5 -40 82 48 -40 82 41.6802 -40 78 40.2246
1 16 -40 73 30 0 1 0 11.5 0 0 0 0 11.5 1-8tndis.dat
1 16 -40 73 30 0 1 0 11.5 0 0 0 0 -11.5 1-8tndis.dat
3 16 -40 81.13165 38.13165 -40 83.6065 40.6065 -40 84.5 38.13165
3 16 -40 84.5 38.13165 -40 83.6065 40.6065 -40 88 30
3 16 -40 84.5 30 -40 84.5 38.13165 -40 88 30
3 16 -40 84.5 30 -40 88 30 -40 84.5 21.86835
3 16 -40 84.5 21.86835 -40 88 30 -40 83.6065 19.3935
3 16 -40 83.6065 19.3935 -40 81.13165 21.86835 -40 84.5 21.86835
0 // Open Inside
1 16 -2 37 -46 -38 0 0 0 0 -34 0 -1 0 rect.dat
1 16 -2 37 46 38 0 0 0 0 -34 0 1 0 rect.dat
1 16 -2 78 42.3623 0 0 -38 0 1 0 2.1377 0 0 rect.dat
1 16 -2 74.5 45.25 0 0 -38 -3.5 1 0 .75 0 0 rect2p.dat
1 16 -2 74.5 -45.25 0 0 38 -3.5 1 0 -.75 0 0 rect2p.dat
1 16 -30 78 -20 0 0 -4 0 4 0 4 0 0 4-4cylo.dat
1 16 -30 78 2 0 0 -4 0 4 0 4 0 0 4-4cylo.dat
1 16 -30 82 2 0 0 -4 0 -1 0 4 0 0 4-4ndis.dat
1 16 -30 82 -20 0 0 -4 0 -1 0 4 0 0 4-4ndis.dat
1 16 -30 78 2 0 0 -4 0 1 0 4 0 0 4-4ndis.dat
1 16 -30 78 -20 0 0 -4 0 1 0 4 0 0 4-4ndis.dat
4 16 -39 78 -4 -40 78 -4 -40 78 -15 -39 78 -15
4 16 -34 78 -2 -39 78 -4 -39 78 -15 -34 78 -16
4 16 -34 78 -2 -34 78 -16 -30 78 -16 -30 78 -2
4 16 -26 78 -2 -30 78 -2 -30 78 -16 -26 78 -16
4 16 36 78 19.7754 -26 78 -2 -26 78 -16 36 78 -44.5
3 16 -26 78 -16 -26 78 -20 36 78 -44.5
3 16 36 78 -44.5 -26 78 -20 -26 78 -24
3 16 -30 78 -24 -34 78 -24 -40 78 -44.5
3 16 -34 78 -24 -39 78 -25 -40 78 -44.5
3 16 -40 78 -44.5 -39 78 -25 -40 78 -25
3 16 -39 78 -25 -34 78 -24 -34 78 -20
3 16 -39 78 -25 -34 78 -20 -39 78 -15
3 16 -39 78 -15 -34 78 -20 -34 78 -16
4 16 -26 78 -24 -30 78 -24 -40 78 -44.5 36 78 -44.5
3 16 -26 78 -2 36 78 19.7754 -26 78 2
3 16 -26 78 2 36 78 19.7754 -26 78 6
4 16 -30 78 6 -26 78 6 36 78 19.7754 -40 78 19.7754
3 16 -30 78 6 -40 78 19.7754 -34 78 6
3 16 -34 78 6 -40 78 19.7754 -39 78 6
3 16 -39 78 6 -40 78 19.7754 -40 78 6
3 16 -34 78 6 -39 78 6 -34 78 2
3 16 -34 78 2 -39 78 6 -39 78 -4
3 16 -34 78 2 -39 78 -4 -34 78 -2
1 16 -40 73 30 0 76 0 11.5 0 0 0 0 11.5 1-8cylo.dat
1 16 -40 73 30 0 76 0 11.5 0 0 0 0 -11.5 1-8cylo.dat
1 16 -2 79.565825 39.178125 0 0 38 1.565825 1 0 -1.046475 0 0 rect2p.dat
1 16 -2 79.565825 20.821875 0 0 -38 1.565825 1 0 1.046475 0 0 rect2p.dat
5 24 36 81.13165 21.86835 -40 81.13165 21.86835 -40 78 19.7754 -40 83.62485 25.59895
5 24 36 81.13165 38.13165 -40 81.13165 38.13165 -40 78 40.2246 -40 83.62485 34.40105
1 16 -30 3 20 0 0 -4 0 -1 0 4 0 0 4-4ndis.dat
1 16 -30 3 -20 0 0 -4 0 -1 0 4 0 0 4-4ndis.dat
1 16 -30 3 20 0 0 -4 0 -3 0 4 0 0 4-4cyli.dat
1 16 -30 3 -20 0 0 -4 0 -3 0 4 0 0 4-4cyli.dat
1 16 -30 3 20 0 0 -4 0 -1 0 4 0 0 4-4edge.dat
1 16 -30 3 -20 0 0 -4 0 -1 0 4 0 0 4-4edge.dat
2 24 36 3 -46 36 3 46
4 16 -34 3 16 -30 3 16 -30 3 -16 -34 3 -16
4 16 -26 3 -16 -30 3 -16 -30 3 16 -26 3 16
4 16 -34 3 -16 -39 3 -15 -39 3 15 -34 3 16
4 16 -39 3 -15 -40 3 -15 -40 3 15 -39 3 15
3 16 -39 3 -15 -34 3 -16 -34 3 -20
3 16 -34 3 -24 -39 3 -25 -34 3 -20
3 16 -39 3 -15 -34 3 -20 -39 3 -25
4 16 -40 3 46 36 3 46 -26 3 24 -30 3 24
3 16 -30 3 24 -34 3 24 -40 3 46
3 16 -39 3 25 -40 3 25 -40 3 46
4 16 -34 3 20 -39 3 25 -40 3 46 -34 3 24
4 16 -39 3 25 -34 3 20 -34 3 16 -39 3 15
3 16 -40 3 -25 -39 3 -25 -40 3 -46
4 16 -39 3 -25 -34 3 -24 -30 3 -24 -40 3 -46
4 16 36 3 -46 -40 3 -46 -30 3 -24 -26 3 -24
3 16 36 3 -46 -26 3 -24 -26 3 -20
3 16 36 3 -46 -26 3 -20 -26 3 -16
3 16 -26 3 20 -26 3 24 36 3 46
3 16 -26 3 20 36 3 46 -26 3 16
4 16 -26 3 -16 -26 3 16 36 3 46 36 3 -46
1 16 36 74 30 0 1 0 0 0 -8.1 8.1 0 0 2-4ndis.dat
1 16 36 74 30 0 1 0 0 0 8.1 8.1 0 0 1-8tndis.dat
1 16 36 74 30 0 1 0 0 0 8.1 -8.1 0 0 1-8tndis.dat
1 16 36 74 30 0 1 0 8.1 0 0 0 0 8.1 1-8tndis.dat
1 16 36 74 30 0 1 0 8.1 0 0 0 0 -8.1 1-8tndis.dat
3 16 36 78 -44.5 36 71 -46 36 78 19.7754
4 16 36 65.9 21.9 36 74 21.9 36 78 19.7754 36 71 -46
4 16 36 65.9 21.9 36 71 -46 36 3 -46 36 3 46
3 16 36 65.9 30 36 65.9 21.9 36 3 46
3 16 36 78 40.2246 36 79.72751 38.1 36 74 38.1
4 16 36 71 46 36 78 44.5 36 78 40.2246 36 74 38.1
3 16 36 71 46 36 74 38.1 36 65.9 38.1
3 16 36 78 19.7754 36 74 21.9 36 79.72751 21.9
3 16 36 3 46 36 65.9 38.1 36 65.9 30
3 16 36 79.72751 38.1 36 78 40.2246 36 81.13165 38.13165
3 16 36 79.72751 21.9 36 81.13165 21.86835 36 78 19.7754
4 16 36 81.13165 21.86835 36 79.72751 21.9 36 79.72751 24.27249 36 82.1 24.27249
4 16 36 79.72751 35.72751 36 79.72751 38.1 36 81.13165 38.13165 36 82.1 35.72751
3 16 36 71 46 36 65.9 38.1 36 3 46
1 16 36 73 30 0 1 0 11.5 0 0 0 0 11.5 1-8ering.dat
1 16 36 73 30 0 1 0 11.5 0 0 0 0 -11.5 1-8ering.dat
3 16 36 82.1 35.72751 36 81.13165 38.13165 36 83.62485 34.40105
3 16 36 81.13165 21.86835 36 82.1 24.27249 36 83.62485 25.59895
4 16 36 84.5 30 36 83.62485 25.59895 36 82.1 24.27249 36 82.1 30
4 16 36 83.62485 34.40105 36 84.5 30 36 82.1 30 36 82.1 35.72751
2 24 -40 78 6 -40 78 19.7754
2 24 -40 78 19.7754 36 78 19.7754
2 24 36 78 19.7754 36 78 -44.5
2 24 36 78 -44.5 -40 78 -44.5
2 24 -40 78 -44.5 -40 78 -25
2 24 -40 78 -15 -40 78 -4
2 24 -40 82 18.3198 -40 82 -48
2 24 -20 82 -48 -20 82 18.3198
4 16 -26 82 6 -30 82 6 -40 82 18.3198 -20 82 18.3198
3 16 -26 82 6 -20 82 18.3198 -26 82 2
3 16 -26 82 2 -20 82 18.3198 -26 82 -2
4 16 -20 82 -48 -26 82 -16 -26 82 -2 -20 82 18.3198
3 16 -26 82 -20 -26 82 -16 -20 82 -48
3 16 -30 82 -24 -26 82 -24 -20 82 -48
3 16 -26 82 -24 -26 82 -20 -20 82 -48
4 16 -30 82 -24 -20 82 -48 -40 82 -48 -34 82 -24
4 16 -30 82 -16 -34 82 -16 -34 82 -2 -30 82 -2
4 16 -30 82 -2 -26 82 -2 -26 82 -16 -30 82 -16
3 16 -34 82 -24 -40 82 -48 -34 82 -20
3 16 -34 82 -20 -40 82 -48 -34 82 -16
3 16 -34 82 -16 -40 82 -48 -34 82 -2
4 16 -34 82 2 -34 82 -2 -40 82 -48 -40 82 18.3198
3 16 -40 82 18.3198 -30 82 6 -34 82 6
3 16 -40 82 18.3198 -34 82 6 -34 82 2
    Line 216: 1 16 -2 79.565825 39.178125 0 0 38 1.565825 1 0 -1.046475 0 0 rect2p.dat
    Line 217: 1 16 -2 79.565825 20.821875 0 0 -38 1.565825 1 0 1.046475 0 0 rect2p.dat
