Unofficial File parts/6217b.dat
Arm Piece with Pin with Friction and  3 Fingers with Ribs
0 Arm Piece with Pin with Friction and  3 Fingers with Ribs
0 Name: 6217b.dat
0 !CATEGORY Arm
0 !KEYWORDS Brickowl 646889
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6217bs01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\6217bs01.dat
1 16 0 6 12 .5 0 0 0 -.5 0 0 0 -.5 4-4con5.dat
1 16 0 6 12 3 0 0 0 1 0 0 0 3 4-4edge.dat
1 16 0 5.5 12 -2.5 0 0 0 1 0 0 0 2.5 4-4disc.dat
1 16 0 5.5 12 -2.5 0 0 0 -1 0 0 0 -2.5 4-4edge.dat
1 16 0 0 0 -1 0 0 0 -1 0 0 0 1 s\6217bs01.dat
1 16 0 0 0 1 0 0 0 -1 0 0 0 1 s\6217bs01.dat
1 16 0 -6 12 -.5 0 0 0 .5 0 0 0 -.5 4-4con5.dat
1 16 0 -6 12 -3 0 0 0 -1 0 0 0 3 4-4edge.dat
1 16 0 -5.5 12 2.5 0 0 0 -1 0 0 0 2.5 4-4disc.dat
1 16 0 -5.5 12 2.5 0 0 0 1 0 0 0 -2.5 4-4edge.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6217bs02.dat
1 16 0 0 0 1 0 0 0 -1 0 0 0 1 s\6217bs02.dat
1 16 0 2 12 9.2388 0 -3.82683 0 -4 0 3.82683 0 9.2388 3-8cylo.dat
1 16 0 0 -2 1 0 0 0 0 1 0 1 0 confric.dat
1 16 0 0 -2 4 0 0 0 0 4 0 -1 0 4-4edge.dat
1 16 0 0 -2 8 0 0 0 0 8 0 -1 0 4-4edge.dat
1 16 0 0 -2 10 0 0 0 0 10 0 4 0 4-4cylo.dat
1 16 0 0 2 10 0 0 0 0 10 0 -1 0 4-4disc.dat
1 16 0 0 -2 2 0 0 0 0 2 0 1 0 4-4ring4.dat
3 16 9.602 -2 13 9.5 0 12.5 9.602 2 13
4 16 9.602 -2 14 9.602 -2 13 9.602 2 13 9.602 2 14
4 16 9.2388 2 15.8268 9.2388 -2 15.8268 9.602 -2 14 9.602 2 14
4 16 -9.602 2 14 -9.602 -2 14 -9.239 -2 15.827 -9.239 2 15.827
4 16 -9.602 2 14 -9.602 2 13 -9.602 -2 13 -9.602 -2 14
3 16 -9.602 2 13 -9.5 0 12.5 -9.602 -2 13
5 24 10 0 11.75 10 0 11.05 9.602 2 11.05 9.602 -2 11.05
5 24 -9.5 0 6.65 -9.5 0 6.4 -9.102 2 6.4 -9.102 -2 6.4
5 24 -9.5 0 4.45 -10 0 3.95 -9.602 -2 3.95 -9.602 2 3.95
5 24 10 0 3.25 9.5 0 2.75 9.102 2 2.75 9.102 -2 2.75
5 24 -10 0 9.1 -9.5 0 8.6 -9.102 -2 8.6 -9.102 2 8.6
5 24 10 0 7.85 10 0 7.15 9.602 2 7.15 9.602 -2 7.15
2 24 9.602 -2 14 9.602 -2 13
5 24 -9.5 0 6.4 -10 0 5.9 -9.602 2 5.9 -9.602 -2 5.9
5 24 9.5 0 8.35 10 0 7.85 9.602 2 7.85 9.602 -2 7.85
5 24 10 0 11.05 9.5 0 10.55 9.102 2 10.55 9.102 -2 10.55
2 24 9.102 -2 12.5 9.602 -2 13
5 24 -9.602 -2 13 -9.602 2 13 -9.602 -2 14 -9.5 0 12.5
2 24 10 0 5.2 9.5 0 4.7
5 24 -9.5 0 4.7 -9.5 0 4.45 -9.102 -2 4.45 -9.102 2 4.45
5 24 -10 0 5.2 -9.5 0 4.7 -9.102 -2 4.7 -9.102 2 4.7
5 24 9.5 0 10.3 10 0 9.8 9.602 -2 9.8 9.602 2 9.8
5 24 10 0 9.1 9.5 0 8.6 9.102 -2 8.6 9.102 2 8.6
2 24 9.102 2 12.5 9.602 2 13
5 24 -9.5 0 8.6 -9.5 0 8.35 -9.102 -2 8.35 -9.102 2 8.35
2 24 -9.602 2 14 -9.602 2 13
5 24 10 0 7.15 9.5 0 6.65 9.102 2 6.65 9.102 -2 6.65
5 24 9.5 0 12.5 9.602 2 13 9.602 -2 13 9.102 2 12.5
5 24 -9.602 -2 13 -9.5 0 12.5 -9.602 2 13 -9.102 -2 12.5
5 24 9.5 0 8.6 9.5 0 8.35 9.102 -2 8.35 9.102 2 8.35
5 24 10 0 9.8 10 0 9.1 9.602 -2 9.1 9.602 2 9.1
2 24 9.2388 -2 15.8268 9.602 -2 14
5 24 -10 0 9.8 -10 0 9.1 -9.602 -2 9.1 -9.602 2 9.1
5 24 -9.5 0 12.5 -9.5 0 12.25 -9.102 -2 12.25 -9.102 2 12.25
5 24 9.602 2 13 9.602 -2 13 9.5 0 12.5 9.602 2 14
2 24 -9.102 2 12.5 -9.602 2 13
5 24 -9.602 2 14 -9.602 -2 14 -9.602 2 13 -9.239 -2 15.827
5 24 -10 0 3.95 -10 0 3.25 -9.602 -2 3.25 -9.602 2 3.25
5 24 -10 0 3.25 -9.5 0 2.75 -9.102 -2 2.75 -9.102 2 2.75
5 24 9.5 0 4.45 10 0 3.95 9.602 2 3.95 9.602 -2 3.95
5 24 -10 0 7.85 -10 0 7.15 -9.602 2 7.15 -9.602 -2 7.15
5 24 -10 0 11.75 -10 0 11.05 -9.602 -2 11.05 -9.602 2 11.05
5 24 10 0 3.95 10 0 3.25 9.602 2 3.25 9.602 -2 3.25
5 24 -9.5 0 12.25 -10 0 11.75 -9.602 -2 11.75 -9.602 2 11.75
5 24 -10 0 7.15 -9.5 0 6.65 -9.102 2 6.65 -9.102 -2 6.65
5 24 9.602 -2 13 9.5 0 12.5 9.602 2 13 9.102 -2 12.5
5 24 9.5 0 12.5 9.5 0 12.25 9.102 2 12.25 9.102 -2 12.25
5 24 9.5 0 4.7 9.5 0 4.45 9.102 2 4.45 9.102 -2 4.45
5 24 -9.5 0 10.55 -9.5 0 10.3 -9.102 -2 10.3 -9.102 2 10.3
5 24 9.5 0 2.75 9.5 0 2.5 9.102 2 2.5 9.102 -2 2.5
5 24 9.602 2 14 9.602 -2 14 9.602 -2 13 9.2388 2 15.8268
2 24 -9.602 -2 13 -9.602 -2 14
2 24 -9.602 -2 14 -9.239 -2 15.827
5 24 -9.5 0 10.3 -10 0 9.8 -9.602 -2 9.8 -9.602 2 9.8
5 24 9.5 0 2.5 10 0 2 9.602 -2 2 9.602 2 2
2 24 -9.102 -2 12.5 -9.602 -2 13
5 24 -9.5 0 2.75 -9.5 0 2.5 -9.102 -2 2.5 -9.102 2 2.5
2 24 9.602 2 14 9.2388 2 15.8268
5 24 9.5 0 10.55 9.5 0 10.3 9.102 2 10.3 9.102 -2 10.3
5 24 9.5 0 6.65 9.5 0 6.4 9.102 2 6.4 9.102 -2 6.4
5 24 -9.602 2 13 -9.5 0 12.5 -9.602 -2 13 -9.102 2 12.5
5 24 9.5 0 12.25 10 0 11.75 9.602 2 11.75 9.602 -2 11.75
5 24 9.5 0 6.4 10 0 5.9 9.602 -2 5.9 9.602 2 5.9
5 24 -10 0 11.05 -9.5 0 10.55 -9.102 -2 10.55 -9.102 2 10.55
5 24 -9.5 0 2.5 -10 0 2 -9.602 -2 2 -9.602 2 2
5 24 10 0 5.9 10 0 5.2 9.602 2 5.2 9.602 -2 5.2
2 24 9.602 2 13 9.602 2 14
5 24 -9.5 0 8.35 -10 0 7.85 -9.602 -2 7.85 -9.602 2 7.85
5 24 -10 0 5.9 -10 0 5.2 -9.602 -2 5.2 -9.602 2 5.2
2 24 -9.239 2 15.827 -9.602 2 14
Not releaseable Errors Found (HN) Errors Found (HN)
Hold
Evert-Jan Boer [ejboer]
Part Reviewer
2022-01-18 20:30:01
made the following comment.
2022-01-23 10:05:01
If this arm design is uniqe to this part, I don't think we need a primitve.
2022-01-28 16:50:01
The old file should be subfiled, reworked, renumbered and recycled.
Orion Pobursky [OrionP]
posted a vote of Hold
2024-09-25 20:54:21
I agree. Prim not needed (yet).
Part Reviewer
2024-09-26 13:52:36
inlined arm4 prim which can be removed now
Willy Tschager [Holly-Wood]
2025-03-22 13:03:42
* Should use a:
instead of a disc.
* Missing all complementaries on cones and rings:
2 422 -7.07107 -7.07107 13 -6.7185 -6.718 12.5
2 422 7.071 -7.071 13 6.71725 -6.71775 12.5
2 422 6.71725 -6.71775 12.5 6.71725 -6.71775 12.25
2 422 -6.7185 -6.718 12.5 -6.7185 -6.718 12.25
2 422 -3 0 10 -3 2 10
* Arms should be split in half and subbed
* I don't linke rotated rects. Zoom in at the meaating point of these and you'll see why:
1 16 -9.421 0 14.914 -.18165 1 0 0 0 2 -.9135 0 0 rect2p.dat
Rene Rechthaler [Blechtaler]
2026-03-28 10:29:01
also should use any kind of prim adapter from the cyl/cone sections to the polygon sections
(quartering would be even more effective, especially when using 1-8prims then)
Part Reviewer
2026-08-05 10:34:25
Subfiled arm pieces. Not optimal yet, work needed
2026-08-05 11:49:52
Some kind of left-over on the middle finger.
2026-08-05 15:30:16
Missing surface inside the pin.
The left-over is in the s02-subfile.
