Official File parts/65130k01.dat
~Strap  2 x 16 with End Rings - Ring End Segment
0 ~Strap  2 x 16 with End Rings - Ring End Segment
0 Name: 65130k01.dat
0 !LDRAW_ORG Part Flexible_Section UPDATE 2024-09
0 !CATEGORY Sheet Plastic
0 !KEYWORDS Band, carrier, VIDIYO
0 // O-Ring
1 16 0 0 0 20.7 0 0 0 5 0 0 0 20.7 48\4-4cylo.dat
1 16 0 0 0 6.9 0 0 0 1 0 0 0 6.9 48\4-4ring3.dat
1 16 0 5 0 6.9 0 0 0 -1 0 0 0 6.9 48\4-4ring3.dat
1 16 0 2.5 0 0 0 -27.6 0 -27.77778 0 -27.6 0 0 48\tm08o0900.dat
1 16 0 2.5 0 0 0 -27.6 0 27.77778 0 -27.6 0 0 48\tm08o0900.dat
1 16 0 2.5 0 0 0 -27.6 0 -27.77778 0 27.6 0 0 48\tm08o0900.dat
1 16 0 2.5 0 0 0 -27.6 0 27.77778 0 27.6 0 0 48\tm08o0900.dat
1 16 0 2.5 0 0 0 27.6 0 -27.77778 0 -27.6 0 0 48\tm08o0900.dat
1 16 0 2.5 0 0 0 27.6 0 27.77778 0 -27.6 0 0 48\tm08o0900.dat
1 16 0 2.5 0 0 0 27.6 0 -27.77778 0 27.6 0 0 48\tm08o0900.dat
1 16 0 2.5 0 0 0 27.6 0 27.77778 0 27.6 0 0 48\tm08o0900.dat
1 16 0 2.5 0 27.6 0 0 0 -27.77778 0 0 0 27.6 48\tm08o0900.dat
1 16 0 2.5 0 27.6 0 0 0 27.77778 0 0 0 27.6 48\tm08o0900.dat
1 16 0 2.5 0 27.6 0 0 0 -27.77778 0 0 0 -27.6 48\tm08o0900.dat
1 16 0 2.5 0 27.6 0 0 0 27.77778 0 0 0 -27.6 48\tm08o0900.dat
1 16 0 5 0 -27.6 0 0 0 -1 0 0 0 -27.6 48\1-16tang.dat
1 16 0 5 0 -27.6 0 0 0 -1 0 0 0 27.6 48\1-16tang.dat
1 16 0 0 0 -27.6 0 0 0 1 0 0 0 -27.6 48\1-16tang.dat
1 16 0 0 0 -27.6 0 0 0 1 0 0 0 27.6 48\1-16tang.dat
0 // Adapter to Strip
4 16 -22.3034 1.5433 19.8098 -21.1388 1.5444 21.1388 -21.2713 2.5 21.2713 -22.3873 2.5 20
4 16 -22.0623 .7323 19.2678 -20.758 .7333 20.758 -21.1388 1.5444 21.1388 -22.3034 1.5433 19.8098
4 16 -21.6983 .1903 18.4568 -20.1894 .1917 20.1894 -20.758 .7333 20.758 -22.0623 .7323 19.2678
4 16 -21.2858 0 17.5 -19.516 0 19.516 -20.1894 .1917 20.1894 -21.6983 .1903 18.4568
4 16 -21.2858 5 -17.5 -19.516 5 -19.516 -20.1894 4.8083 -20.1894 -21.6983 4.8098 -18.4568
4 16 -22.3873 0 -17.5 -22.3873 .1903 -18.4568 -21.6983 .1903 -18.4568 -21.2858 0 -17.5
4 16 -22.3873 .1903 -18.4568 -22.3873 .7323 -19.2678 -22.0623 .7323 -19.2678 -21.6983 .1903 -18.4568
4 16 -22.3873 .7323 -19.2678 -22.3873 1.5433 -19.8098 -22.3034 1.5433 -19.8098 -22.0623 .7323 -19.2678
4 16 -22.3034 3.4568 -19.8098 -22.3873 3.4568 -19.8098 -22.3873 4.2678 -19.2678 -22.0623 4.2678 -19.2678
4 16 -22.0623 4.2678 -19.2678 -22.3873 4.2678 -19.2678 -22.3873 4.8098 -18.4568 -21.6983 4.8098 -18.4568
4 16 -21.6983 4.8098 -18.4568 -22.3873 4.8098 -18.4568 -22.3873 5 -17.5 -21.2858 5 -17.5
3 16 -22.3873 2.5 -20 -22.3873 3.4568 -19.8098 -22.3034 3.4568 -19.8098
3 16 -22.3873 1.5433 -19.8098 -22.3873 2.5 -20 -22.3034 1.5433 -19.8098
3 16 -22.3873 2.5 20 -22.3873 1.5433 19.8098 -22.3034 1.5433 19.8098
3 16 -22.3873 3.4568 19.8098 -22.3873 2.5 20 -22.3034 3.4568 19.8098
4 16 -22.3873 4.2678 19.2678 -22.3873 3.4568 19.8098 -22.3034 3.4568 19.8098 -22.0623 4.2678 19.2678
4 16 -22.3873 4.8098 18.4568 -22.3873 4.2678 19.2678 -22.0623 4.2678 19.2678 -21.6983 4.8098 18.4568
4 16 -22.3873 5 17.5 -22.3873 4.8098 18.4568 -21.6983 4.8098 18.4568 -21.2858 5 17.5
4 16 -22.3034 1.5433 19.8098 -22.3873 1.5433 19.8098 -22.3873 .7323 19.2678 -22.0623 .7323 19.2678
4 16 -22.0623 .7323 19.2678 -22.3873 .7323 19.2678 -22.3873 .1903 18.4568 -21.6983 .1903 18.4568
4 16 -21.6983 .1903 18.4568 -22.3873 .1903 18.4568 -22.3873 0 17.5 -21.2858 0 17.5
4 16 -21.2713 2.5 21.2713 -21.1388 3.4556 21.1388 -22.3034 3.4568 19.8098 -22.3873 2.5 20
4 16 -21.1388 3.4556 21.1388 -20.758 4.2667 20.758 -22.0623 4.2678 19.2678 -22.3034 3.4568 19.8098
4 16 -20.758 4.2667 20.758 -20.1894 4.8083 20.1894 -21.6983 4.8098 18.4568 -22.0623 4.2678 19.2678
4 16 -20.1894 4.8083 20.1894 -19.516 5 19.516 -21.2858 5 17.5 -21.6983 4.8098 18.4568
4 16 -21.2713 2.5 -21.2713 -21.1388 1.5444 -21.1388 -22.3034 1.5433 -19.8098 -22.3873 2.5 -20
4 16 -21.1388 1.5444 -21.1388 -20.758 .7333 -20.758 -22.0623 .7323 -19.2678 -22.3034 1.5433 -19.8098
4 16 -20.758 .7333 -20.758 -20.1894 .1917 -20.1894 -21.6983 .1903 -18.4568 -22.0623 .7323 -19.2678
4 16 -20.1894 .1917 -20.1894 -19.516 0 -19.516 -21.2858 0 -17.5 -21.6983 .1903 -18.4568
4 16 -22.3034 3.4568 -19.8098 -21.1388 3.4556 -21.1388 -21.2713 2.5 -21.2713 -22.3873 2.5 -20
4 16 -22.0623 4.2678 -19.2678 -20.758 4.2667 -20.758 -21.1388 3.4556 -21.1388 -22.3034 3.4568 -19.8098
4 16 -21.6983 4.8098 -18.4568 -20.1894 4.8083 -20.1894 -20.758 4.2667 -20.758 -22.0623 4.2678 -19.2678
5 24 -21.6983 .1903 18.4568 -20.758 .7333 20.758 -20.1894 .1917 20.1894 -22.0623 .7323 19.2678
5 24 -21.6983 4.8098 -18.4568 -20.758 4.2667 -20.758 -20.1894 4.8083 -20.1894 -22.0623 4.2678 -19.2678
5 24 -22.0623 .7323 19.2678 -22.3873 .73225 19.26775 -22.3034 1.5433 19.8098 -22.3873 .1903 18.4568
5 24 -21.1388 1.5444 -21.1388 -22.3034 1.5433 -19.8098 -20.758 .7333 -20.758 -22.3873 2.5 -20
5 24 -21.6983 .1903 18.4568 -22.0623 .7323 19.2678 -22.3873 .7323 19.2678 -20.1894 .1917 20.1894
5 24 -22.3873 5 17.5 -21.2858 5 17.5 -22.3873 4.8098 18.4568 -21.8978 5 16.8029
5 24 -21.2713 2.5 21.2713 -21.1388 3.4556 21.1388 -18.3126 2.5 23.8685 -22.3034 3.4568 19.8098
5 24 -22.3034 1.5433 19.8098 -22.3873 2.5 20 -22.3873 1.5433 19.8098 -21.1388 1.5444 21.1388
5 24 -22.0623 4.2678 19.2678 -20.758 4.2667 20.758 -22.3034 3.4568 19.8098 -20.1894 4.8083 20.1894
5 24 -22.0623 .7323 -19.2678 -21.6983 .1903 -18.4568 -20.758 .7333 -20.758 -22.3873 .1903 -18.4568
5 24 -20.1894 .1917 20.1894 -19.516 0 19.516 -16.8029 0 21.8978 -21.6983 .1903 18.4568
5 24 -21.2858 0 17.5 -22.3873 0 17.5 -21.6983 .1903 18.4568 -21.8978 0 16.8029
5 24 -20.758 4.2667 20.758 -20.1894 4.8083 20.1894 -17.871 4.2667 23.2889 -21.6983 4.8098 18.4568
5 24 -19.516 0 -19.516 -20.1894 .1917 -20.1894 -17.3797 .1917 -22.6513 -21.2858 0 -17.5
5 24 -22.3873 4.80975 -18.45675 -21.6983 4.8098 -18.4568 -22.3873 5 -17.5 -22.0623 4.2678 -19.2678
5 24 -22.3034 1.5433 19.8098 -21.1388 1.5444 21.1388 -22.0623 .7323 19.2678 -21.2713 2.5 21.2713
5 24 -21.2858 5 -17.5 -21.6983 4.8098 -18.4568 -19.516 5 -19.516 -22.3873 4.8098 -18.4568
5 24 -22.0623 .7323 -19.2678 -20.758 .7333 -20.758 -22.3034 1.5433 -19.8098 -20.1894 .1917 -20.1894
5 24 -21.1388 1.5444 -21.1388 -21.2713 2.5 -21.2713 -22.3034 1.5433 -19.8098 -18.3126 2.5 -23.8685
5 24 -21.2713 2.5 -21.2713 -21.1388 3.4556 -21.1388 -18.1994 3.4556 -23.7167 -22.3873 2.5 -20
5 24 -20.758 .7333 -20.758 -21.1388 1.5444 -21.1388 -22.0623 .7323 -19.2678 -18.1994 1.5444 -23.7167
5 24 -20.1894 4.8083 -20.1894 -21.6983 4.8098 -18.4568 -20.758 4.2667 -20.758 -21.2858 5 -17.5
5 24 -22.3873 4.80975 18.45675 -21.6983 4.8098 18.4568 -22.3873 4.2678 19.2678 -21.2858 5 17.5
5 24 -22.0623 .7323 19.2678 -22.3034 1.5433 19.8098 -22.3873 1.5433 19.8098 -20.758 .7333 20.758
5 24 -22.3034 1.5433 -19.8098 -22.0623 .7323 -19.2678 -21.1388 1.5444 -21.1388 -22.3873 .7323 -19.2678
5 24 -21.1388 3.4556 -21.1388 -20.758 4.2667 -20.758 -17.871 4.2667 -23.2889 -22.3034 3.4568 -19.8098
5 24 -22.3034 3.4568 -19.8098 -21.1388 3.4556 -21.1388 -21.2713 2.5 -21.2713 -22.0623 4.2678 -19.2678
5 24 -22.3034 3.4568 -19.8098 -22.3873 2.5 -20 -21.1388 3.4556 -21.1388 -22.3873 3.4568 -19.8098
5 24 -20.1894 .1917 -20.1894 -21.6983 .1903 -18.4568 -22.0623 .7323 -19.2678 -19.516 0 -19.516
5 24 -21.6983 .1903 -18.4568 -21.2858 0 -17.5 -20.1894 .1917 -20.1894 -22.3873 0 -17.5
5 24 -21.2713 2.5 -21.2713 -22.3873 2.5 -20 -22.3034 3.4568 -19.8098 -21.1388 1.5444 -21.1388
5 24 -22.0623 .7323 19.2678 -20.758 .7333 20.758 -21.1388 1.5444 21.1388 -21.6983 .1903 18.4568
5 24 -22.0623 4.2678 19.2678 -22.3034 3.4568 19.8098 -22.3873 4.2678 19.2678 -21.1388 3.4556 21.1388
5 24 -22.3873 .19025 -18.45675 -21.6983 .1903 -18.4568 -22.3873 .7323 -19.2678 -21.2858 0 -17.5
5 24 -22.3034 1.5433 -19.8098 -22.3873 1.54325 -19.80975 -22.0623 .7323 -19.2678 -22.3873 2.5 -20
5 24 -20.1894 4.8083 20.1894 -21.6983 4.8098 18.4568 -22.0623 4.2678 19.2678 -19.516 5 19.516
5 24 -20.1894 4.8083 20.1894 -19.516 5 19.516 -17.3797 4.8083 22.6513 -21.2858 5 17.5
5 24 -22.0623 .7323 -19.2678 -22.3873 .73225 -19.26775 -21.6983 .1903 -18.4568 -22.3873 1.5433 -19.8098
5 24 -22.3873 0 -17.5 -21.2858 0 -17.5 -21.8978 0 -16.8029 -22.3873 .1903 -18.4568
5 24 -21.6983 4.8098 18.4568 -22.0623 4.2678 19.2678 -22.3873 4.8098 18.4568 -20.758 4.2667 20.758
5 24 -21.2858 5 17.5 -21.6983 4.8098 18.4568 -22.3873 5 17.5 -20.1894 4.8083 20.1894
5 24 -21.1388 3.4556 21.1388 -20.758 4.2667 20.758 -22.0623 4.2678 19.2678 -18.1994 3.4556 23.7167
5 24 -21.1388 3.4556 21.1388 -22.3034 3.4568 19.8098 -20.758 4.2667 20.758 -22.3873 2.5 20
5 24 -22.0623 4.2678 -19.2678 -22.3873 4.26775 -19.26775 -22.3034 3.4568 -19.8098 -22.3873 4.8098 -18.4568
5 24 -20.1894 .1917 20.1894 -21.6983 .1903 18.4568 -20.758 .7333 20.758 -21.2858 0 17.5
5 24 -22.3873 2.5 -20 -22.3034 1.5433 -19.8098 -21.2713 2.5 -21.2713 -22.3873 1.5433 -19.8098
5 24 -22.3873 2.5 20 -22.3034 3.4568 19.8098 -22.3873 3.4568 19.8098 -21.2713 2.5 21.2713
5 24 -21.2713 2.5 21.2713 -22.3873 2.5 20 -22.3034 1.5433 19.8098 -21.1388 3.4556 21.1388
5 24 -22.3873 .19025 18.45675 -21.6983 .1903 18.4568 -22.0623 .7323 19.2678 -22.3873 0 17.5
5 24 -21.1388 1.5444 21.1388 -20.758 .7333 20.758 -17.871 .7333 23.2889 -22.3034 1.5433 19.8098
5 24 -20.758 4.2667 -20.758 -20.1894 4.8083 -20.1894 -22.0623 4.2678 -19.2678 -17.3797 4.8083 -22.6513
5 24 -21.6983 4.8098 -18.4568 -22.0623 4.2678 -19.2678 -20.1894 4.8083 -20.1894 -22.3873 4.2678 -19.2678
5 24 -20.1894 .1917 -20.1894 -20.758 .7333 -20.758 -21.6983 .1903 -18.4568 -17.871 .7333 -23.2889
5 24 -21.2858 0 17.5 -21.6983 .1903 18.4568 -19.516 0 19.516 -22.3873 .1903 18.4568
5 24 -22.3034 3.4568 19.8098 -22.3873 3.45675 19.80975 -22.0623 4.2678 19.2678 -22.3873 2.5 20
5 24 -21.2858 5 -17.5 -22.3873 5 -17.5 -21.8978 5 -16.8029 -21.6983 4.8098 -18.4568
5 24 -19.516 5 -19.516 -20.1894 4.8083 -20.1894 -21.6983 4.8098 -18.4568 -16.8029 5 -21.8978
5 24 -22.3873 1.54325 19.80975 -22.3034 1.5433 19.8098 -22.3873 2.5 20 -22.3873 .7323 19.2678
5 24 -20.758 4.2667 -20.758 -22.0623 4.2678 -19.2678 -21.1388 3.4556 -21.1388 -21.6983 4.8098 -18.4568
5 24 -22.0623 4.2678 -19.2678 -22.3034 3.4568 -19.8098 -20.758 4.2667 -20.758 -22.3873 3.4568 -19.8098
5 24 -20.758 .7333 20.758 -20.1894 .1917 20.1894 -17.3797 .1917 22.6513 -22.0623 .7323 19.2678
5 24 -21.1388 1.5444 21.1388 -21.2713 2.5 21.2713 -18.1994 1.5444 23.7167 -22.3873 2.5 20
5 24 -22.0623 4.2678 19.2678 -22.3873 4.26775 19.26775 -21.6983 4.8098 18.4568 -22.3873 3.4568 19.8098
5 24 -22.3873 3.45675 -19.80975 -22.3034 3.4568 -19.8098 -22.3873 2.5 -20 -22.3873 4.2678 -19.2678
0 // Strip Bottom
3 16 -21.8978 5 16.8029 -22.3873 5 17.5 -21.2858 5 17.5
3 16 -22.3873 5 -17.5 -21.8978 5 -16.8029 -21.2858 5 -17.5
3 16 -32 5 17.5 -22.3873 5 17.5 -23.9016 5 13.8
3 16 -23.9016 5 13.8 -22.3873 5 17.5 -21.8978 5 16.8029
3 16 -32 5 17.5 -23.9016 5 13.8 -25.4996 5 10.5625
3 16 -32 5 17.5 -25.4996 5 10.5625 -27.6 5 5.4896
3 16 -32 5 17.5 -27.6 5 5.4896 -27.6 5 0
3 16 -32 5 17.5 -27.6 5 0 -32 5 -17.5
3 16 -32 5 -17.5 -27.6 5 -5.4896 -25.4996 5 -10.5625
3 16 -32 5 -17.5 -25.4996 5 -10.5625 -23.9016 5 -13.8
3 16 -32 5 -17.5 -27.6 5 0 -27.6 5 -5.4896
3 16 -32 5 -17.5 -23.9016 5 -13.8 -22.3873 5 -17.5
3 16 -23.9016 5 -13.8 -21.8978 5 -16.8029 -22.3873 5 -17.5
0 // Strip Top
1 16 -22.3873 2.5 17.5 0 -9.61272 0 2.5 0 0 0 0 2.5 2-4cyli.dat
1 16 -22.3873 2.5 -17.5 0 -9.61272 0 2.5 0 0 0 0 -2.5 2-4cyli.dat
1 16 -32 0 6.75 0 0 3 0 1.5 0 -3 0 0 2-8sphe.dat
1 16 -28 0 13.5 3 0 0 0 2.5 0 0 0 3 4-8sphe.dat
1 16 -28 0 -13.5 3 0 0 0 2.5 0 0 0 3 4-8sphe.dat
1 16 -28 0 -13.5 3 0 0 0 1 0 0 0 3 4-4edge.dat
1 16 -28 0 13.5 3 0 0 0 1 0 0 0 3 3-4ndis.dat
1 16 -28 0 -13.5 3 0 0 0 1 0 0 0 -3 3-4ndis.dat
1 16 -32 0 -6.75 0 0 3 0 1.5 0 -3 0 0 2-8sphe.dat
1 16 -28 0 13.5 3 0 0 0 1 0 0 0 3 4-4edge.dat
1 16 -32 0 6.75 0 0 3 0 1 0 -3 0 0 2-4edge.dat
1 16 -32 0 -6.75 0 0 3 0 1 0 -3 0 0 2-4edge.dat
1 16 -32 0 6.75 0 0 3 0 1 0 -3 0 0 2-4ndis.dat
1 16 -32 0 -6.75 0 0 3 0 1 0 -3 0 0 2-4ndis.dat
4 16 -29 0 3.75 -32 0 3.75 -32 0 -3.75 -29 0 -3.75
1 16 -28 0 -13.5 3 0 0 0 1 0 0 0 3 1-4tang.dat
1 16 -28 0 13.5 3 0 0 0 1 0 0 0 -3 1-4tang.dat
4 16 -27.6 0 5.4896 -29 0 3.75 -29 0 -3.75 -27.6 0 0
4 16 -27.6 0 0 -29 0 -3.75 -29 0 -6.75 -27.6 0 -5.4896
4 16 -29 0 -6.75 -29 0 -9.75 -28 0 -10.5 -27.6 0 -5.4896
3 16 -25 0 -13.5 -25 0 -16.5 -22.3873 0 -17.5
4 16 -22.3873 0 -17.5 -21.8978 0 -16.8029 -23.9016 0 -13.8 -25 0 -13.5
3 16 -29 0 3.75 -27.6 0 5.4896 -29 0 6.75
4 16 -29 0 6.75 -27.6 0 5.4896 -28 0 10.5 -29 0 9.75
4 16 -21.8978 0 16.8029 -22.3873 0 17.5 -25 0 16.5 -25 0 13.5
4 16 -25 0 12.9033 -23.9016 0 13.8 -21.8978 0 16.8029 -25 0 13.5
3 16 -28 0 10.5 -27.6 0 5.4896 -27.4033 0 10.5
3 16 -27.4033 0 10.5 -27.6 0 5.4896 -26.8519 0 10.7283
3 16 -26.8519 0 10.7283 -27.6 0 5.4896 -26.3005 0 10.9566
4 16 -25.8787 0 11.3787 -26.3005 0 10.9566 -27.6 0 5.4896 -25.4996 0 10.5625
3 16 -25.8787 0 11.3787 -25.4996 0 10.5625 -25.4566 0 11.8005
3 16 -25.4566 0 11.8005 -25.4996 0 10.5625 -25.2283 0 12.3519
4 16 -25.4996 0 10.5625 -23.9016 0 13.8 -25 0 12.9033 -25.2283 0 12.3519
3 16 -27.6 0 -5.4896 -28 0 -10.5 -27.4033 0 -10.5
4 16 -32 0 9.75 -29 0 9.75 -28 0 10.5 -31 0 10.5
3 16 -32 0 9.75 -31 0 10.5 -31 0 13.5
4 16 -32 0 9.75 -31 0 13.5 -31 0 16.5 -32 0 17.5
4 16 -31 0 16.5 -28 0 16.5 -22.3873 0 17.5 -32 0 17.5
3 16 -22.3873 0 17.5 -28 0 16.5 -25 0 16.5
3 16 -22.3873 0 17.5 -21.8978 0 16.8029 -21.2858 0 17.5
3 16 -21.8978 0 -16.8029 -22.3873 0 -17.5 -21.2858 0 -17.5
3 16 -27.6 0 -5.4896 -27.4033 0 -10.5 -26.8519 0 -10.7283
4 16 -25.4996 0 -10.5625 -27.6 0 -5.4896 -26.8519 0 -10.7283 -26.3005 0 -10.9566
3 16 -25.4996 0 -10.5625 -26.3005 0 -10.9566 -25.8787 0 -11.3787
3 16 -25.4996 0 -10.5625 -25.8787 0 -11.3787 -25.4566 0 -11.8005
3 16 -25.4996 0 -10.5625 -25.4566 0 -11.8005 -25.2283 0 -12.3519
4 16 -25.4996 0 -10.5625 -25.2283 0 -12.3519 -25 0 -12.9033 -23.9016 0 -13.8
3 16 -25 0 -12.9033 -25 0 -13.5 -23.9016 0 -13.8
4 16 -32 0 -9.75 -31 0 -10.5 -28 0 -10.5 -29 0 -9.75
3 16 -31 0 -10.5 -32 0 -9.75 -31 0 -13.5
4 16 -32 0 -9.75 -32 0 -17.5 -31 0 -16.5 -31 0 -13.5
3 16 -31 0 -16.5 -32 0 -17.5 -28 0 -16.5
4 16 -32 0 -17.5 -22.3873 0 -17.5 -25 0 -16.5 -28 0 -16.5
5 24 -19.516 5 -19.516 -21.2858 5 -17.5 -21.6983 4.8098 -18.4568 -16.42338 5 -12.60216
5 24 -19.516 5 19.516 -21.2858 5 17.5 -21.6983 4.8098 18.4568 -16.42338 5 12.60216
5 24 -19.516 0 19.516 -21.2858 0 17.5 -21.6983 .1903 18.4568 -16.42338 0 12.60216
5 24 -21.2858 0 -17.5 -19.516 0 -19.516 -21.6983 .1903 -18.4568 -16.42338 0 -12.60216
