Unofficial File parts/71944-f1.dat
Technic Ribbed Hose  6L (Formed  2.8 x  3.95 Bent 90 Degrees)
0 Technic Ribbed Hose 6L (Formed 2.8 x 3.95 Bent 90 Degrees) 0 Name: 71944-f1.dat 0 Author: Ulrich Röder [UR] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP Delete "0 //" of the 3 lines in front of the code to see it in action. 0 BFC CERTIFY CCW 0 !KEYWORDS 19 Ribs, 48 mm, 7 mm D., Model Team, Set 5563 0 !CMDLINE -c0
0 // 1 7 0 -26 0 0 0 1 0 1 0 -1 0 0 3941.dat 0 // 1 7 0 -2 0 0 0 1 -1 0 0 0 -1 0 3749.dat 0 // 1 7 0 46 91 1 0 0 0 1 0 0 0 1 2458.dat 0 // Main 1 16 0 2.5 0 -1 0 0 0 -1 0 0 0 1 71944k01.dat 1 16 0 9.1 0 -1 0 0 0 1 0 0 0 1 71944k02.dat 1 16 0 15.26 .19 -1 0 0 0 .998135 -.061048 0 .061048 .998135 71944k02.dat 1 16 0 20.5 1 -1 0 0 0 .970296 -.241921 0 .241921 .970296 71944k02.dat 1 16 0 25.3 2.74 -1 0 0 0 .898795 -.438371 0 .438371 .898795 71944k02.dat 1 16 0 29.68 5.46 -1 0 0 0 .793353 -.608761 0 .608761 .793353 71944k02.dat 1 16 0 33.69 9.1 -1 0 0 0 .681999 -.731353 0 .731353 .681999 71944k02.dat 1 16 0 37.49 13.39 -1 0 0 0 .649446 -.760406 0 .760406 .649446 71944k02.dat 1 16 0 41.4 18.24 -1 0 0 0 .60876 -.793354 0 .793354 .60876 71944k02.dat 1 16 0 44.84 23.15 -1 0 0 0 .537298 -.843391 0 .843391 .537298 71944k02.dat 1 16 0 47.83 28.33 -1 0 0 0 .461748 -.887011 0 .887011 .461748 71944k02.dat 1 16 0 50.31 33.7 -1 0 0 0 .374606 -.927183 0 .927183 .374606 71944k02.dat 1 16 0 52.3 39.35 -1 0 0 0 .292371 -.956304 0 .956304 .292371 71944k02.dat 1 16 0 53.84 45.18 -1 0 0 0 .216439 -.976295 0 .976295 .216439 71944k02.dat 1 16 0 54.99 51.25 -1 0 0 0 .156434 -.987688 0 .987688 .156434 71944k02.dat 1 16 0 55.67 57.19 -1 0 0 0 .069756 -.997564 0 .997564 .069756 71944k02.dat 1 16 0 55.94 63.42 -1 0 0 0 .017452 -.999848 0 .999848 .017452 71944k02.dat 1 16 0 56 69.9 -1 0 0 0 0 -1 0 1 0 71944k02.dat 1 16 0 56 76.5 -1 0 0 0 0 -1 0 1 0 71944k01.dat
Not releaseable Errors Found (HHN) Errors Found (HHN)
User Vote
Holly-Wood Hold
MagFors Hold
[PTadmin]
Part Author
renamed the part.
2020-11-14 14:31:35
"parts/71944-f1.dat" to "parts/71944c01.dat."
Ulrich Röder [UR]
2020-11-14 14:45:02
Sticking to studs as the unit of measurement, like the original length of the part, is probably the more harmonious decision ...
...looks pretty well in the model with those new subparts.
made the following comment.
2020-11-14 17:05:01
I think we should use the -f1 suffix here, and not -c01suffix.
We already have these, for example:
30191-f1, Bar Flexible H-shaped with Holders
30191-f2, Bar Flexible H-shaped with Holders (Formed as Vehicle Rollcage)
30191-f3, Bar Flexible H-shaped with Holders (Formed for 93140 Stretcher)
30191-f4, Bar Flexible H-shaped with Holders (Formed for Engine Compartment)
85543, Rubber Belt Round 15 / 1.6
85543-f1, Rubber Belt Round 15 / 1.6 (Formed for Crane Jaw Curved Closed)
85543-f2, Rubber Belt Round 15 / 1.6 (Formed for 2 Plates 2 x 2 with Hinge - Loaded)
85543-f3, Rubber Belt Round 15 / 1.6 (Formed for 2 Plates 2 x 2 with Hinge - Unloaded)
85543-f4, Rubber Belt Round 15 / 1.6 (Formed) for 2 Technic Bushes
85543-f5, Rubber Belt Round 15 / 1.6 (Formed) for Technic Bush - Wheel Rim 8 x 11.2 with Centre Groove
Please also note the difference in the numbering and the content inside the brackets.
posted a vote of Hold.
2020-11-14 17:30:02
Hold-voting because there are now 2 versions of this file.
Chris Dee [cwdee]
2020-11-14 18:15:01
Why is this named 'Hose Ribbed 6l ' when the unformed part is 'Technic Ribbed Hose 6L'?
Ulrich Röder [UR]
2020-11-15 11:30:01
Oh, yes - sorry, chris ...
.. probably a relic when I started with it.
Existing certification-votes were deleted.
2020-11-15 16:35:02
IMO we should not have the set number in the description.
It could be present as a keyword, as it already is in this part.
[PTadmin]
Part Author
edited the part header.
2020-11-15 17:25:01
2021-05-20 16:20:01
If we should have shortcuts like these in the library we need to first standardize both the position of the part and the description of the shape.
Willy Tschager [Holly-Wood]
2025-05-08 16:57:29
* Agree with Magnus. Should be deleted
2025-08-15 08:20:13
Bump
This part is copyright © Ulrich Röder
LDraw.org Parts Tracker,
