0 Sail 6 x 12 Triangular with Blue "8", Horizontal Grey Stripes, and Vertical Blue Stripe Pattern (Formed Left Convex)
0 Name: u66p02c02.dat
0 !CATEGORY Sheet Plastic
0 !KEYWORDS boat, BrickLink 6351pls01, Rebrickable upn0306pr0003, Sail, Set 6351
0 !KEYWORDS Yacht
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\u66c01s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\u66c01s03.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\u66p02c02s01.dat
0 BFC NOCLIP
1 1 0 0 0 1 0 0 0 1 0 0 0 1 s\u66p02c02s02.dat
Has uncertified subfiles
| User | Vote |
| Holly-Wood | Certify |
The underside of the 8 is wider than the top at the real part and the grey stripes are smaller.
description:
Sheet Plastic 6 x 12 Triangular with Blue "8", Horizontal Gray Stripes, and Vertical Blue Stripe Pattern (Formed Left Convex)
to
Sheet Plastic 6 x 12 Triangular with Blue "8", Horizontal Grey Stripes, and Vertical Blue Stripe Pattern (Formed Left Convex)
Gray => Grey
https://www.bricklink.com/TL/65598.jpg?0
for the template? Unfortunately, an unfortunate choice as this is a misprint. Most images show this version instead:
https://www.bricklink.com/PL/6351pls01.jpg?0
https://thumbs.worthpoint.com/zoom/images2/1/0710/26/lego-6351-surf-sail-camper-box_1_bba43846fc84c77ac11ddd10c7d2f11c.jpg
https://i.pinimg.com/originals/1b/00/ac/1b00acb8283f7bc2210132e0e9641d27.jpg
The configuration used in your pattern wouldn't work as the bottom batten would collide with the boom IRL.
description:
to
LDraw.org Parts Tracker,
