Unofficial File parts/s/2587s01.dat
0 ~Minifig Armour Plate without Front
0 Name: s\2587s01.dat
0 Author: Bernd Broich [bbroich]
0 !HISTORY 2009-12-08 [Philo] Subparted for patterned parts
0 !HISTORY 2021-10-15 [Lasse_Deleuran] Updated after correction of 1-4ring5.dat
0 !HISTORY 2022-03-10 [MagFors] Closed some thin gaps
0 !HISTORY 2025-08-18 [WUIt] Subfiled for symmetry, removed T-junctions, fixed gaps, aligned edges
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\2587s02.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\2587s02.dat
0 // Inner Back Plane
2 24 -16 32 10 16 32 10
2 24 -19 29 10 -15.379 8 10
2 24 14 0 10 -14 0 10
4 16 -16 32 10 -16 32 11.5 16 32 11.5 16 32 10
4 16 19 29 10 -19 29 10 -16 32 10 16 32 10
4 16 -14 0 10 -15.379 8 10 15.376 8 10 14 0 10
4 16 -15.379 8 10 -19 29 10 19 29 10 15.376 8 10
0 // Outer Back Plane
2 24 -11.7 11 14 -13.483 -3 12
2 24 -11.7 11 14 11.7 11 14
2 24 -13.483 -3 12 13.48 -3 12
2 24 -14 19 14 -19 29 12.067
2 24 -14 19 14 14 19 14
2 24 -16 32 11.5 16 32 11.5
4 16 -11.7 11 14 -13.483 -3 12 13.48 -3 12 11.7 11 14
4 16 -14 19 14 -11.7 11 14 11.7 11 14 14 19 14
4 16 14 19 14 19 29 12.067 -19 29 12.067 -14 19 14
4 16 16 32 11.5 -16 32 11.5 -19 29 12.067 19 29 12.067
5 24 19 29 12.067 -19 29 12.067 -14 19 14 16 32 11.5
0 // Top
1 16 0 -3 0 6 0 0 0 1 0 0 0 -6 4-4edge.dat
1 16 0 -3 0 6 0 0 0 1 0 0 0 -6 4-4ndis.dat
1 16 0 -3 0 6 0 0 0 3 0 0 0 -6 4-4cyli.dat
1 16 0 0 0 6 0 0 0 1 0 0 0 -6 4-4edge.dat
1 16 0 0 0 6 0 0 0 -1 0 0 0 -6 4-4ndis.dat
3 16 13.48 -3 -12 -13.483 -3 -12 0 -3 -15
4 16 -14 0 -10 -6 0 -6 6 0 -6 14 0 -10
4 16 -14 0 10 14 0 10 6 0 6 -6 0 6
4 16 6 -3 -6 -6 -3 -6 -13.483 -3 -12 13.48 -3 -12
4 16 6 -3 6 13.48 -3 12 -13.483 -3 12 -6 -3 6
0 // Outer Front Lines
2 24 -13.483 -3 -12 0 -3 -15
2 24 0 -3 -15 0 4.22 -18.7
2 24 0 11.37 -20.28 0 17.5 -20.36
2 24 0 26 -19 0 17.5 -20.36
2 24 0 4.22 -18.7 0 11.37 -20.28
0 // Inner Front
2 24 14 0 -10 -14 0 -10
3 16 -6.9 0 -10 6.9 0 -10 0 23.5 -13
5 24 0 27 -17.5 0 23.5 -13 6.9 23.3 -12.3 -6.9 23.3 -12.3
5 24 0 26 -19 0 27 -17.5 1.148 27.114 -17.576 -1.148 27.114 -17.576
Needs 2 More Votes (F)
Has Uncertified Subfiles
Lasse Deleuran [Lasse_Deleuran]
2021-10-16 05:05:01
posted a vote of Certify
2021-11-16 22:20:01
posted a vote of Hold
2021-11-16 22:25:01
Has a lot more small issues. Rounding errors and thin gaps
2022-03-10 21:00:01
General clean-up.
Existing certification-votes were deleted.
Max Martin Richter [MMR1988]
2022-03-17 20:55:01
The bottom areas of all for 2-8sphe prims don't match with the faces and edges next to them. It looks a bit like a point cloud. ;-)
made the following comment.
2022-03-17 21:00:01
Lifted hold, as I'm not sure how much a correction will affect the official files...
Willy Tschager [Holly-Wood]
2023-09-15 06:38:33
* Max is right and there is also a gap, but this part has been official for such a long time and you would have to get rid off of some prims to fix it properly. It is not worth the fuss:
2 24 15.379 8 -12 15.6895572 7.58145 -11.8836592
Peter Blomberg [WUIt]
2025-08-18 01:08:31
Subfiled for symmetry, removed T-junctions, removed gaps, aligned edges
