Official File p/clh7.dat
Click Lock Hinge Half Dual Finger 3-Position Type 1
0 Click Lock Hinge Half Dual Finger 3-Position Type 1
0 Name: clh7.dat
0 Author: Donald Sutter [technog]
0 !LDRAW_ORG Primitive UPDATE 2026-09
0 !HELP Requires 2 halves rotated 180 degrees apart on Z-axis.
0 !HELP Placement on side of bricks; rotate pair accordingly, place 10 Ldu
0 !HELP below top surface and 6 Ldu off side surface, fill as needed -
0 !HELP box4o4a.dat's recommended.
0 !HELP Placement off side of plates and windscreens; rotate pair accordingly,
0 !HELP place center origin 2 Ldu below top surface and 6 Ldu off side surface,
0 !HELP fill as needed.
0 !HISTORY 2017-07-07 [ejboer] Improved design
0 !HISTORY 2021-03-23 [MagFors] More finetuning using lo-res primitives
0 !HISTORY 2026-07-12 [MagFors] used finger primitive
0 !HISTORY 2026-09-30 [OrionP] Official Update 2026-09
1 16 4 0 4 0 -1 0 4 0 0 0 0 4 4-4edge.dat
1 16 4 0 4 0 -1 0 1 0 0 0 0 1 4-4con3.dat
1 16 3 0 4 0 -1 0 3 0 0 0 0 3 4-4edge.dat
1 16 3 0 4 0 1 0 3 0 0 0 0 3 4-4disc.dat
1 16 6.25 0 0 1.125 0 0 0 1 0 0 0 1 clh-base.dat
1 16 8.5 0 4 4.5 0 0 0 1 0 0 0 1 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 0 1 0 -1 0 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 -1 0 0 0 -1 clh-finger.dat
1 16 4 0 4 0 4.5 0 4.8504 0 -2.0091 2.0091 0 4.8504 1-8cylo.dat
1 16 4 0 4 0 4.5 0 -2.0091 0 -4.8504 4.8504 0 -2.0091 1-8cylo.dat
1 16 4 0 4 0 1 0 4.8504 0 -2.0091 2.0091 0 4.8504 1-8ering.dat
1 16 4 0 4 0 1 0 -2.0091 0 -4.8504 4.8504 0 -2.0091 1-8ering.dat
1 16 8.5 0 4 0 -1 0 4.8504 0 -2.0091 2.0091 0 4.8504 1-8ering.dat
1 16 8.5 0 4 0 -1 0 -2.0091 0 -4.8504 4.8504 0 -2.0091 1-8ering.dat
1 16 6.25 -1.5068 8.9503 0 0 2.25 -.5023 1 0 -.1 0 0 rect2p.dat
1 16 6.25 1.5068 8.9503 0 0 -2.25 .5023 -1 0 -.1 0 0 rect2p.dat
1 16 6.25 4.9503 5.5068 0 0 2.25 -.1 -1 0 .5023 0 0 rect2p.dat
1 16 6.25 -4.9503 5.5068 0 0 2.25 -.1 1 0 -.5023 0 0 rect2p.dat
3 16 4 -5.0503 5.0046 4 -4.8504 6.0091 4 -4.2815 6.8608
3 16 4 -4.2815 6.8608 4 -3.7124 7.7124 4 -2.8608 8.2815
3 16 4 -2.8608 8.2815 4 -2.0091 8.8504 4 -1.0046 9.0503
3 16 4 1.0046 9.0503 4 2.0091 8.8503 4 2.8608 8.2815
3 16 4 2.8608 8.2815 4 3.7124 7.7124 4 4.2815 6.8608
3 16 4 4.2815 6.8608 4 4.8504 6.0091 4 5.0503 5.0046
3 16 8.5 5.0503 5.0046 8.5 4.8504 6.0091 8.5 4.2815 6.8608
3 16 8.5 4.2815 6.8608 8.5 3.7124 7.7124 8.5 2.8608 8.2815
3 16 8.5 2.8608 8.2815 8.5 2.0091 8.8503 8.5 1.0046 9.0503
3 16 8.5 -1.0046 9.0503 8.5 -2.0091 8.8504 8.5 -2.8608 8.2815
3 16 8.5 -2.8608 8.2815 8.5 -3.7124 7.7124 8.5 -4.2815 6.8608
3 16 8.5 -4.2815 6.8608 8.5 -4.8504 6.0091 8.5 -5.0503 5.0046
5 24 8.5 4.8504 6.0091 4 4.8504 6.0091 8.5 5.0503 5.0046 8.5 3.7124 7.7124
5 24 8.5 2.0091 8.8503 4 2.0091 8.8503 8.5 3.7124 7.7124 8.5 1.0046 9.0503
5 24 8.5 -2.0091 8.8504 4 -2.0091 8.8504 8.5 -1.0046 9.0503 8.5 -3.7124 7.7124
5 24 8.5 -4.8504 6.0091 4 -4.8504 6.0091 8.5 -3.7124 7.7124 8.5 -5.0503 5.0046
