0 Minifig Cape Cloth (Formed Curtain)
0 Name: 50231c03.dat
0 !HELP This cape has been modelled specifically for 10211 - Grand Emporium
0 !HELP Use the following code to position them properly:
0 !HELP 1 16 20 -120 80 1 0 0 0 1 0 0 0 1 87087.dat
0 !HELP 1 16 -80 -120 -20 0 0 -1 0 1 0 1 0 0 87087.dat
0 !HELP 1 16 20 -108 20 0 0.225 0.974 0 0.974 -0.225 1 0 0 50231c03.dat
0 !HELP 1 16 -20 -108 -20 -1 0 0 0 0.974 -0.225 0 -0.225 -0.974 50231c03.dat
0 !HELP For the rod a Rigid hose 3 mm LDCAD template with the following values has been used:
0 !HELP 0 !LDCAD PATH_POINT [type=bezier] [posOri=0 0 0 0 -1 0 0 0 1 -1 0 0] [prevCPDist=25] [nextCPDist=5] [cirR=25] [cirDir=xyCW] [prevYRoll=0] [nextYRoll=0]
0 !HELP 0 !LDCAD PATH_POINT [type=bezier] [posOri=20 0 0 0 -1 0 0 0 1 -1 0 0] [prevCPDist=5] [nextCPDist=66] [cirR=25] [cirDir=xyCW] [prevYRoll=0] [nextYRoll=0]
0 !HELP 0 !LDCAD PATH_POINT [type=bezier] [posOri=86 0 -66 -1 0 0 0 0 1 0 1 0] [prevCPDist=66] [nextCPDist=5] [cirR=25] [cirDir=xyCW] [prevYRoll=0] [nextYRoll=0]
0 !HELP 0 !LDCAD PATH_POINT [type=bezier] [posOri=86 0 -86 -1 0 0 0 0 1 0 1 0] [prevCPDist=5] [nextCPDist=25] [cirR=25] [cirDir=xyCW] [prevYRoll=0] [nextYRoll=0]
0 !CATEGORY Sheet Fabric
0 !KEYWORDS changing room, Grand Emporium, set 10211
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\50231c03s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\50231c03s01.dat
No recorded votes-
Has Uncertified Subfiles
https://forums.ldraw.org/thread-22624-post-50284.html#pid50284
And great care has been used to avoid collision, so please show me where you find it:
1 0 20 -108 20 0 0.225 0.974 0 0.974 -0.225 1 0 0 10211 - 50231c03.dat
1 71 20 -110 66 0 0 1 0 1 0 -1 0 0 10211 - Ground Floor - Curtain-rod.ldr
1 0 -20 -108 -20 -1 0 0 0 0.974 -0.225 0 -0.225 -0.974 10211 - 50231c03.dat
0 !LDCAD CONTENT [type=path] [addFallBack=default] [looped=false] [displayKind=L] [curveStep=0] [displayLenCor=0]
0 !LDCAD PATH_SKIN [donCol=16] [donOri=-1 0 0 0 -1 0 0 0 1] [donPart=ldcRigid3mmHoseCap.dat] [donYSize=200%] [donCen=absCen] [donCenYOfs=0] [donFinScale=fitDon2Seg] [donPlace=deform] [donYAlign=0] [donInline=false] [segSize=100%] [segSizeTol=5%] [segsCnt=1] [segsGrp=0] [segsMaxMerge=1] [segsMrgAng=0] [segsMrgRollAng=0] [segsEdgeDelKind=keepFirstLeft]
0 !LDCAD PATH_SKIN [donCol=16] [donOri=1 0 0 0 1 0 0 0 1] [donPart=ldcRigid3mmHoseSeg.dat] [donYSize=400%] [donCen=absCen] [donCenYOfs=0] [donFinScale=fitDon2Seg] [donPlace=deform] [donYAlign=0] [donInline=false] [segSize=100%] [segSizeTol=5%] [segsCnt=0] [segsGrp=0] [segsMaxMerge=10] [segsMrgAng=0] [segsMrgRollAng=0] [segsEdgeDelKind=keepFirstLeft]
0 !LDCAD PATH_SKIN [donCol=16] [donOri=1 0 0 0 1 0 0 0 1] [donPart=ldcRigid3mmHoseCap.dat] [donYSize=200%] [donCen=absCen] [donCenYOfs=0] [donFinScale=fitDon2Seg] [donPlace=deform] [donYAlign=0] [donInline=false] [segSize=100%] [segSizeTol=5%] [segsCnt=1] [segsGrp=0] [segsMaxMerge=1] [segsMrgAng=0] [segsMrgRollAng=0] [segsEdgeDelKind=keepFirstLeft]
0 !LDCAD GENERATED [generator=LDCad 1.7 Alpha 2a]
But I also noticed from set photos, or e.g. page 25 of the BI, that the part does take on more of a sweeping shape at the bottom…of course, this is flexible fabric, so there will be endless variations.
Anyway, these are design considerations and necessarily subjective, but I thought it would be helpful to offer feedback as a user in the intended use case.
help:
0 !HELP
to
keywords:
to
Grand Emporium, changing room, set 10211
Added Help
