Unofficial File parts/3068bpm00.dat
Tile 2 x 2 with Bar Code and Time Block Sticker
0 Tile 2 x 2 with Bar Code and Time Block Sticker
0 Name: 3068bpm00.dat
0 !CATEGORY Sticker Shortcut
0 !KEYWORDS Bar Code, Bricklink 3068bpb1347, Mario, Scanner Code, Set 71365
0 !KEYWORDS Set 71369, Super Mario
0 !HISTORY 2022-12-17 {LEGO Instructions App} Original part shape
0 !HISTORY 2023-03-06 [kuramapika1] File preparation for LDraw Parts Tracker
1 16 0 0 0 1 0 0 0 1 0 0 0 1 3068b.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s22.dat
Not releaseable Errors Found (CHN) Errors Found (CHN)
Hold
Orion Pobursky [OrionP]
Certify
Javier Orquera [kuramapika1]
Part Author
2023-03-06 19:34:51
Part Author
2023-03-06 19:36:07
Part Author
2023-03-06 21:09:59
posted a vote of Hold
2023-03-06 21:15:09
Need renumbering. This is a BL number.
Part Author
made the following comment.
2023-03-07 01:52:55
What do you suggest?
2023-03-07 02:19:18
First, this is a not a pattern, it's a sticker shortcut.
Second, unless you can convince me otherwise, this particular shortcut doesn't meet the requirements to be included in the library as outline here (the second bullet point to be specific):
https://www.ldraw.org/article/512.html#sticker_shortcuts
Part Author
2023-03-07 03:55:21
Orion: I never convice you, because I have no words on the subject.
In my comment:"What do you suggest?" I mean a suggestion on the number of the part. In the forums I post a question about it (as a guide to me) but no one answer it.
posted a vote of Certify
2023-03-07 04:03:49
I agree for the renumbering.
In contrast to ordinary tile-with-stickers, these Super Mario barcode tiles are provided in stickered state and the stickers cannot be removed without destruction.
From this reason, these items are in the same category with permanently-assembled print parts like 93085p01 and should exist in the library, I think.
2023-03-07 05:08:41
Renaming is easy. While I feel Takeshi's comments make the case for inclusion, these are definitely sticker shortcuts and not patterns. In this case they will be 3068bdXX. I think we can prolly just start with t0 and spill over into u and v as appropriate.
Part Author
2023-10-30 00:43:02
Since the criteria has been changed here https://library.ldraw.org/tracker/32832, it just need to "adapt"/change the number of this part and their respective texture (and by extension, all the parts and textures), am I right?
renamed the part.
2023-12-09 15:52:41
"parts/3068bpb1347.dat" to "parts/3068bpt00.dat"
renamed the part.
2023-12-09 15:53:38
"parts/3068bpt00.dat" to "parts/3068bptg.dat"
renamed the part.
2023-12-09 19:05:28
"parts/3068bptg.dat" to "parts/3068bpm00.dat"
2023-12-09 19:09:09
We decided in the above referenced part that since this part comes with the sticker already attached, it should be treated as a patterned part. I've renamed this tile to 3068bpm00. The next should be m01 and so on until m99 then go to ma1 and so on.
Part Author
2023-12-09 22:45:14
The number sequence is bpma1 to a99 and then bpmb1 to b99 or bpma1 to a9 and bpmb1 to b9 and so on?
2023-12-09 22:58:07
Disregard what I wrote above my lack of sleep shows apparently. What I meant was mXX starting at 00. Therefore m00 -> m0z, m10 -> m1z, m20 -> m2z, etc.
cancelled their vote.
2024-05-18 16:44:50
I think the hold reason is gone.
Could you lift hold?
2024-05-18 16:45:03
2024-05-19 08:08:02
2026-10-27 19:56:06
2026-10-27 23:32:49
Should those be "69434pXXX(X)"? (First registered ID for the square 2x2s)
Treated as Pattern with:
69434s01 as (3068b + stickerback018x018).
That way we could avoid having every pattern twice (sticker + shortcut)...
2026-10-28 00:48:41
Name still wrong and this whole series needs a discussion.
