Unofficial File parts/u9582ac01.dat
Train Brick  2 x  4 x  1.333 Sliding Wheel Block - Type A with Red Conical Wheels
0 Train Brick  2 x  4 x  1.333 Sliding Wheel Block - Type A with Red Conical Wheels
0 Name: u9582ac01.dat
0 !HELP the origin of this brick is outside the brick itself to allow for proper rotation to fit the tracks
0 !HELP place this brick -26 LDU in the z-direction from the Sliding Brick Holder
0 !HELP e.g.
0 !HELP 1 16 0 0 0 1 0 0 0 1 0 0 0 1 429c02.dat
0 !HELP 1 16 0 0 -26 1 0 0 0 1 0 0 0 1 u9582ac01.dat
0 !HELP to place an engine on a standard LEGO curved track,
0 !HELP rotate the brick by 11.25 degrees on the y-axis when using the standard 12V motor
0 !CATEGORY Train
0 !KEYWORDS set 720
1 16 0 0 0 1 0 0 0 1 0 0 0 1 u9582a.dat
1 4 50 10 76 0 0 -1 0 1 0 1 0 0 244c01.dat
1 4 -50 10 76 0 0 1 0 1 0 -1 0 0 244c01.dat
Not releaseable Errors Found (CHN) Errors Found (CHN)
Certify
Hold
Rene Rechthaler [Blechtaler]
Gerald Lasser [GeraldLasser]
2023-03-16 07:46:15
evolution of x946.dat
posted a vote of Certify
2024-06-07 14:45:28
posted a vote of Hold
2024-06-07 15:25:14
are you sure about conical wheels? both BL and peeron list 4 conical wheels for the motor and 4 standard (cylindrical) wheels for the sliding blocks...
and both call the set 720-2 to distinguish it from the other basic building set.
the set 721 is the same locomotive, but alone (still uses cylindrical wheels)
the 4V Set 182 uses the red conical wheels (buth with black rubber tyre)
made the following comment.
2025-09-23 21:27:30
any ideas here? change the wheels? which ones? cylindrical or conical with black rubber?
