Unofficial File parts/s/76959s01.dat
~Slope Brick 45  2 x  2 Inverted with Round Bottom Pin with Inner Stopper Ring without Front Face
0 ~Slope Brick 45 2 x 2 Inverted with Round Bottom Pin with Inner Stopper Ring without Front Face 0 Name: s\76959s01.dat 0 Author: Florent Faramond [Makou] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2025-03-16 [MagFors] Reworked bottom
0 BFC INVERTNEXT 1 16 0 24 -.5 16 0 0 0 -20 0 0 0 6.5 box5.dat 4 16 16 24 6 -16 24 6 -20 24 10 20 24 10 4 16 -16 24 6 -16 24 -7 -20 24 -10 -20 24 10 4 16 16 24 -7 16 24 6 20 24 10 20 24 -10 1 16 0 24 0 20 0 0 0 -1 0 0 0 -10 recte3.dat 2 24 20 4 -30 20 24 -10 2 24 -20 4 -30 -20 24 -10 2 24 20 0 -30 20 0 10 2 24 -20 0 -30 -20 0 10 2 24 -18 0 -10 -18 0 -26 2 24 18 0 -26 18 0 -10 0 BFC INVERTNEXT 1 16 0 10 -18 18 0 0 0 2 -8 0 0 -8 box2-5.dat 4 16 20 4 -30 20 24 -10 20 24 10 20 0 10 3 16 20 4 -30 20 0 10 20 0 -30 1 16 0 12 10 20 0 0 0 0 12 0 -1 0 rect.dat 4 16 -20 4 -30 -20 0 10 -20 24 10 -20 24 -10 3 16 -20 4 -30 -20 0 -30 -20 0 10 1 16 0 2 -30 20 0 0 0 0 2 0 1 0 rect.dat 4 16 18 0 -10 18 20 -10 18 4 -26 18 0 -26 4 16 -18 0 -10 -18 0 -26 -18 4 -26 -18 20 -10 1 16 0 10 -10 18 0 0 0 0 -10 0 1 0 rect3.dat 4 16 18 0 -10 20 0 10 -20 0 10 -18 0 -10 4 16 -18 0 -10 -20 0 10 -20 0 -30 -18 0 -26 4 16 18 0 -26 20 0 -30 20 0 10 18 0 -10 1 16 10 0 0 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 10 0 -20 1 0 0 0 1 0 0 0 1 stud2a.dat 1 16 10 0 -20 1 0 0 0 4 0 0 0 1 stud2s2e.dat 1 16 10 4 -20 0 0 1 0 6 0 -1 0 0 stud2s2.dat 1 16 -10 0 0 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 -10 0 -20 1 0 0 0 1 0 0 0 1 stud2a.dat 1 16 -10 0 -20 1 0 0 0 4 0 0 0 1 stud2s2e.dat 1 16 -10 4 -20 0 0 1 0 6 0 -1 0 0 stud2s2.dat 0 // hollow stud3 1 16 0 4 0 1 0 0 0 -5 0 0 0 1 stud3.dat 1 16 10 13.75 -7 -1 0 0 0 0 9.75 0 1 0 box4-1.dat 1 16 0 13.75 -7 -1 0 0 0 0 9.75 0 1 0 box4-1.dat 1 16 -10 13.75 -7 1 0 0 0 0 9.75 0 1 0 box4-1.dat 4 16 -20 24 -10 -16 24 -7 16 24 -7 20 24 -10 4 16 -20 0 -30 20 0 -30 18 0 -26 -18 0 -26
Awaiting Admin Review (CCN) Awaiting Admin Review (CCN)
User Vote
Philo Certify
Plastikean Certify
Part Author
2023-04-06 06:06:28
First submit
Philippe Hurbain [Philo]
posted a vote of Hold.
2023-04-06 06:44:50
Many elements are bfc backwards.
Also wondering about inner hole of stud3 and tiny side ribs, these are "traditionally" not modeled.
Part Author
2023-04-06 11:06:33
BFC issues corrected
made the following comment.
2023-04-06 13:58:44
Hey Faramond,
First I thought this is an alias of 3660, but then I saw it isn't. We need this new variant.
Now there are 3 versions of this part. Is it possible to make a common subfile, shared betwen all three designs?
Part Author
2023-04-06 14:44:20
Not really, there are some little differences. We can do a subpart in common just between 3660b and 76959.
Joshua Delahunty [dulcaoin]
Part Reviewer
2023-07-14 22:03:57
It seems really odd to have naming of "hollow bottom tube", and not have the tube actually be hollow. Additionally, that hollow stud3 is the visual clue that makes 76959 user-discernable from other elements in this family. Having it missing looks like an error.
N. W. Perry [Plastikean]
Part Reviewer
2024-03-20 18:54:32
Agreed that if "hollow" appears in the name, it should be included in the part, also as it's a distinguishing characteristic of this mold version. On the other hand, true, we don't usually model hollow pins. I kind of wish we did, but then we'd have to revise many, many parts to be consistent.
But in any event, we do need a variant with a *round* underside pin *and* the internal bar stopper, and the name should reflect this.
Rene Rechthaler [Blechtaler]
2024-03-20 19:24:24
is it worth to mention the 3 bottom ribs instead?
naming also has been discussed here:
https://forums.ldraw.org/thread-18657.html
2025-03-16 07:35:44
Added a hollow bottom stud and simplified/corrected design.
edited the part header.
2025-03-16 07:42:54
Header Edits
description:
~Slope Brick 45 2 x 2 Inverted with Hollow Round Bottom Tube
to
~Slope Brick 45 2 x 2 Inverted with Hollow Round Bottom Pin
Willy Tschager [Holly-Wood]
posted a vote of Certify.
2025-06-24 11:43:26
2026-01-21 08:28:37
I still don't understand why bottom stud should be drilled on this specific part while a gazillion of other parts are (and this is a good thing!) not drilled.
2026-01-21 08:56:23
Removed hollow bottom pin.
2026-01-21 09:16:54
Part Reviewer
2026-01-22 02:04:41
Name should include "with Inner Stopper Ring" (to match 3660b) and "without Front Face" (as this is the subpart). Also 3660b should probably be renamed to reflect the flat pin.
2026-01-22 13:40:45
Header Edits
description:
to
Part Reviewer
2026-01-23 01:59:13
This part is copyright © Florent Faramond
LDraw.org Parts Tracker, Magnus Forsberg,
