Unofficial File parts/s/40145s01.dat
~Plate  2 x  2 Round with Rotation Stem - Quarter
0 ~Plate  2 x  2 Round with Rotation Stem - Quarter
0 Name: s\40145s01.dat
1 16 -1.234 5.125 12.8795 .039 1 0 0 0 -1.375 -6.8675 0 0 rect.dat
1 16 2.416 5.55 12.6445 -.024 -1 0 0 0 .95 -6.8705 0 0 rect.dat
1 16 1.234 4.175 12.8795 0 -1 .039 .425 0 0 0 0 6.8675 rect.dat
3 16 0 0 0 14.142 0 14.142 11.9387 0 15.6145
3 16 0 0 0 11.9387 0 15.6145 7.6537 0 18.4776
3 16 11.9387 0 15.6145 7.654 3.75 18.478 7.6537 0 18.4776
3 16 -14.142 0 14.142 0 0 0 -11.9387 0 15.6145
3 16 -11.9387 0 15.6145 0 0 0 -7.654 0 18.478
3 16 -7.654 3.75 18.478 -1.273 3.75 19.747 -1.195 3.75 6.012
3 16 1.273 3.75 19.747 7.654 3.75 18.478 1.195 3.75 6.012
3 16 -1.195 3.75 6.012 1.195 3.75 6.012 0 3.75 0
4 16 1.195 3.75 6.012 7.654 3.75 18.478 14.142 3.75 14.142 0 3.75 0
4 16 -1.195 3.75 6.012 0 3.75 0 -14.142 3.75 14.142 -7.654 3.75 18.478
4 16 -7.654 0 18.478 0 0 0 7.654 0 18.478 0 0 20
4 16 0 6.5 20 1.273 4.6 19.747 2.44 4.6 19.515 2.44 6.5 19.515
4 16 -1.195 6.5 6.012 -1.273 6.5 19.747 0 6.5 20 0 6.5 6.25
4 16 2.392 6.5 5.774 0 6.5 6.25 0 6.5 20 2.44 6.5 19.515
4 16 2.392 4.6 5.774 2.44 4.6 19.515 1.273 4.6 19.747 1.195 4.6 6.012
4 16 7.654 3.75 18.478 11.9387 0 15.6145 14.142 0 14.142 14.142 3.75 14.142
4 16 0 0 20 7.6537 0 18.4776 7.654 3.75 18.478 1.273 3.75 19.747
4 16 1.273 4.6 19.747 0 6.5 20 0 0 20 1.273 3.75 19.747
4 16 0 0 20 0 6.5 20 -1.273 6.5 19.747 -1.273 3.75 19.747
4 16 -7.654 3.75 18.478 -7.654 0 18.478 0 0 20 -1.273 3.75 19.747
2 24 0 0 20 7.654 0 18.478
2 24 -7.654 0 18.478 0 0 20
2 24 14.142 3.75 14.142 7.654 3.75 18.478
2 24 -7.654 3.75 18.478 -14.142 3.75 14.142
2 24 7.654 3.75 18.478 1.273 3.75 19.747
2 24 -1.273 3.75 19.747 -7.654 3.75 18.478
2 24 0 6.5 20 -1.273 6.5 19.747
2 24 1.273 4.6 19.747 2.44 4.6 19.515
2 24 2.44 6.5 19.515 0 6.5 20
2 24 11.9387 0 15.6145 7.6537 0 18.4776
2 24 -7.654 0 18.478 -11.9387 0 15.6145
5 24 0 0 20 0 6.5 20 1.273 3.75 19.747 -1.273 3.75 19.747
2 24 -1.195 3.75 6.012 1.195 3.75 6.012
2 24 1.195 4.6 6.012 2.392 4.6 5.774
2 24 -1.195 6.5 6.012 0 6.5 6.25
2 24 0 6.5 6.25 2.392 6.5 5.774
5 24 7.654 3.75 18.478 7.6537 0 18.4776 14.142 0 14.142 0 3.75 20
5 24 -7.654 3.75 18.478 -7.654 0 18.478 -14.142 3.75 14.142 0 0 20
5 24 14.142 0 14.142 14.142 3.75 14.142 7.654 3.75 18.478 18.478 0 7.654
5 24 -14.142 3.75 14.142 -14.142 0 14.142 -7.654 0 18.478 -18.478 3.75 7.654
3 16 -7.654 0 18.478 -7.654 3.75 18.478 -11.9387 0 15.6145
4 16 -14.142 3.75 14.142 -14.142 0 14.142 -11.9387 0 15.6145 -7.654 3.75 18.478
Evert-Jan Boer [ejboer]
Part Reviewer
2023-06-04 10:30:19
posted a vote of Hold
2023-06-11 21:16:49
Surface bleeding, in the main part:
2 5 -14.142 0 14.142 -11.9387 0 15.6145
2 5 11.9387 0 15.6145 14.142 0 14.142
Part Reviewer
2023-06-18 19:16:45
Modified the main part as well, unsure about the surface bleeding, if still there, don't know exactly what you are meaning.
2023-06-19 15:55:40
This should be a condline, right?
2 24 0 0 20 0 6.5 20
This "edge" of the triangle is visible, bellow the stud, in some angles.
Could be avoided if you shape the triangles like this:
3 13 11.9387 0 15.6145 0 0 0 12.8284 0 12.8284
Part Reviewer
2023-12-11 18:11:01
Changed line to condline and altered triangles on one side to match the other side
Willy Tschager [Holly-Wood]
made the following comment.
2025-08-04 13:19:27
* Rotated/Slanted rects
