Official File parts/2866.dat
Train Track  9V Points Lever
0 Train Track  9V Points Lever
0 Name: 2866.dat
0 Author: Ludo Soete [ludo]
0 !CMDLINE -c14
0 !HISTORY 2012-09-09 [Steffen] uploaded to PT from LUGNET, BFCed, rotated by 90 degrees
0 !HISTORY 2016-01-02 [MMR1988] Added condlines, used more prims
0 // scharnier punt links
1 16 10 0 0 0 -7.25 0 0 0 6.25 6.25 0 0 4-4cylc.dat
1 16 13.875 0 0 0 -3.875 0 0 0 2.5 2.5 0 0 4-4cylc.dat
0 // scharnier punt rechts
1 16 -10 0 0 0 7.25 0 0 0 -6.25 6.25 0 0 4-4cylc.dat
1 16 -13.875 0 0 0 3.875 0 0 0 -2.5 2.5 0 0 4-4cylc.dat
0 // bovenste rond stuk
1 16 -10 -35 0 0 20 0 0 0 12.5 12.5 0 0 4-4cylc.dat
1 16 10 -35 0 0 -16.5 0 0 0 -4 4 0 0 4-4cyli.dat
1 16 -6.5 -35 0 0 -1 0 0 0 -4 4 0 0 4-4disc.dat
1 16 -6.5 -35 0 0 1 0 0 0 -4 4 0 0 4-4edge.dat
1 16 10 -35 0 0 -1 0 0 0 -6 6 0 0 4-4edge.dat
1 16 10 -35 0 0 -1 0 0 0 1 -1 0 0 stud2a.dat
1 16 10 -35 0 0 -1 0 6 0 0 0 0 6 4-4ring1.dat
1 16 10 -35 0 0 -1 0 0.5 0 0 0 0 0.5 4-4ring24.dat
0 // top vierkantje
1 16 0 -46.754315 0 3.75 0 0 0 -3.49569 0 0 0 3.75 box3u2p.dat
4 16 3.75 -47.5 0 3.75 -46.75431 3.75 3.75 -50.25 3.75 3.75 -50.25 -3.75
4 16 -3.75 -47.5 0 -3.75 -46.75431 -3.75 -3.75 -50.25 -3.75 -3.75 -50.25 3.75
3 16 3.75 -50.25 -3.75 3.75 -46.75431 -3.75 3.75 -47.5 0
3 16 -3.75 -50.25 3.75 -3.75 -46.75431 3.75 -3.75 -47.5 0
2 24 -3.75 -46.75431 -3.75 -3.75 -47.5 0
2 24 -3.75 -47.5 0 -3.75 -46.75431 3.75
2 24 3.75 -47.5 0 3.75 -46.75431 3.75
2 24 3.75 -46.75431 -3.75 3.75 -47.5 0
0 // ronde pin aan zijkant
1 16 -10 -41 0 0 -11 0 0 0 -4 4 0 0 4-4cyli.dat
1 16 -10 -41 0 0 1 0 0 0 -4 4 0 0 4-4edge.dat
1 16 -21 -41 0 0 -4 0 0 0 -4 4 0 0 4-8sphe.dat
0 // ronde top aan onderzijde
1 16 -2.75 18.5 0 0 5.5 0 3.75 0 0 0 0 -3.75 3-16cylo.dat
1 16 -2.75 18.5 0 0 5.5 0 3.75 0 0 0 0 3.75 3-16cylo.dat
1 16 -2.75 18.5 0 0 1 0 3.75 0 0 0 0 -3.75 3-16chrd.dat
1 16 -2.75 18.5 0 0 1 0 3.75 0 0 0 0 3.75 3-16chrd.dat
3 16 -2.75 19.935125 -3.464625 -2.75 19.935125 3.464625 -2.75 22.25 0
1 16 2.75 18.5 0 0 -1 0 3.75 0 0 0 0 -3.75 3-16chrd.dat
1 16 2.75 18.5 0 0 -1 0 3.75 0 0 0 0 3.75 3-16chrd.dat
3 16 2.75 22.25 0 2.75 19.935125 3.464625 2.75 19.935125 -3.464625
0 // verbinding tussen onderste top en scharnierpunten
1 16 0 9.967562 4.857312 0 0 -2.75 -9.967562 0 0 1.392688 -1 0 rect2p.dat
1 16 0 9.967562 -4.857312 0 0 2.75 -9.967562 0 0 -1.392688 1 0 rect2p.dat
4 16 -2.75 19.935125 3.464625 -2.75 19.935125 -3.464625 -2.75 0 -6.25 -2.75 0 6.25
4 16 2.75 0 6.25 2.75 0 -6.25 2.75 19.935125 -3.464625 2.75 19.935125 3.464625
5 24 -2.75 19.935125 -3.464625 2.75 19.935125 -3.464625 2.75 21.151625 -2.651625 2.75 0 -6.25
5 24 -2.75 19.935125 3.464625 2.75 19.935125 3.464625 2.75 21.151625 2.651625 2.75 0 6.25
5 24 -2.75 0 6.25 2.75 0 6.25 2.75 19.935125 3.464625 2.75 -18.6 4.375
5 24 -2.75 0 -6.25 2.75 0 -6.25 2.75 19.935125 -3.464625 2.75 -18.6 -4.375
0 // verbinding tussen bovenste rond stuk en scharnierpunt
4 16 -2.75 -18.6 -4.375 -2.75 -18.6 4.375 -2.75 0 6.25 -2.75 0 -6.25
4 16 2.75 0 6.25 2.75 -18.6 4.375 2.75 -18.6 -4.375 2.75 0 -6.25
1 16 0 -9.3 -5.3125 0 0 2.75 -9.3 0 0 0.9375 1 0 rect2p.dat
1 16 0 -9.3 5.3125 0 0 -2.75 -9.3 0 0 -0.9375 -1 0 rect2p.dat
0 // te controleren lijnen
2 24 -2.75 -18.6 -4.375 -2.75 -20.0351 -4.0897
2 24 -2.75 -20.0351 -4.0897 -2.75 -21.4702 -4.375
2 24 -2.75 -18.6 4.375 -2.75 -20.0351 4.0897
2 24 -2.75 -20.0351 4.0897 -2.75 -21.4702 4.375
2 24 -2.75 -21.4702 -4.375 -2.75 -24.8063 -6.81125
2 24 -2.75 -21.4702 4.375 -2.75 -24.8063 6.81125
5 24 2.75 -24.8063 6.81125 -2.75 -24.8063 6.81125 -2.75 -30.2162 11.5487 -2.75 -21.4702 4.375
4 16 -2.75 -18.6 4.375 -2.75 -20.0351 4.0897 2.75 -20.0351 4.0897 2.75 -18.6 4.375
4 16 -2.75 -20.0351 4.0897 -2.75 -21.4702 4.375 2.75 -21.4702 4.375 2.75 -20.0351 4.0897
4 16 -2.75 -21.4702 4.375 -2.75 -24.8063 6.81125 2.75 -24.8063 6.81125 2.75 -21.4702 4.375
4 16 2.75 -20.0351 4.0897 2.75 -20.0351 -4.0897 2.75 -18.6 -4.375 2.75 -18.6 4.375
4 16 2.75 -21.4702 -4.375 2.75 -20.0351 -4.0897 2.75 -20.0351 4.0897 2.75 -21.4702 4.375
3 16 2.75 -21.4702 -4.375 2.75 -23.4513 -4.7838 2.75 -24.8063 -6.81125
3 16 2.75 -23.4513 4.7838 2.75 -21.4702 4.375 2.75 -24.8063 6.81125
3 16 2.75 -23.4513 -4.7838 2.75 -21.4702 -4.375 2.75 -22.5 0
4 16 2.75 -23.4513 4.7838 2.75 -22.5 0 2.75 -21.4702 -4.375 2.75 -21.4702 4.375
2 24 2.75 -18.6 -4.375 2.75 -20.0351 -4.0897
2 24 2.75 -20.0351 -4.0897 2.75 -21.4702 -4.375
2 24 2.75 -18.6 4.375 2.75 -20.0351 4.0897
2 24 2.75 -20.0351 4.0897 2.75 -21.4702 4.375
2 24 2.75 -21.4702 -4.375 2.75 -24.8063 -6.81125
2 24 2.75 -21.4702 4.375 2.75 -24.8063 6.81125
5 24 2.75 -24.8063 -6.81125 -2.75 -24.8063 -6.81125 -2.75 -30.2162 -11.5487 2.75 -21.4702 -4.375
4 16 2.75 -20.0351 -4.0897 -2.75 -20.0351 -4.0897 -2.75 -18.6 -4.375 2.75 -18.6 -4.375
4 16 2.75 -21.4702 -4.375 -2.75 -21.4702 -4.375 -2.75 -20.0351 -4.0897 2.75 -20.0351 -4.0897
4 16 2.75 -24.8063 -6.81125 -2.75 -24.8063 -6.81125 -2.75 -21.4702 -4.375 2.75 -21.4702 -4.375
4 16 -2.75 -18.6 -4.375 -2.75 -20.0351 -4.0897 -2.75 -20.0351 4.0897 -2.75 -18.6 4.375
4 16 -2.75 -20.0351 4.0897 -2.75 -20.0351 -4.0897 -2.75 -21.4702 -4.375 -2.75 -21.4702 4.375
3 16 -2.75 -23.4513 -4.7838 -2.75 -21.4702 -4.375 -2.75 -24.8063 -6.81125
3 16 -2.75 -21.4702 4.375 -2.75 -23.4513 4.7838 -2.75 -24.8063 6.81125
3 16 -2.75 -22.5 0 -2.75 -21.4702 -4.375 -2.75 -23.4513 -4.7838
4 16 -2.75 -21.4702 4.375 -2.75 -21.4702 -4.375 -2.75 -22.5 0 -2.75 -23.4513 4.7838
2 24 2.75 -24.8063 -6.81125 2.75 -23.4513 -4.7838
2 24 2.75 -23.4513 -4.7838 2.75 -22.5 0
2 24 2.75 -23.4513 4.7838 2.75 -22.5 0
2 24 2.75 -24.8063 6.81125 2.75 -23.4513 4.7838
2 24 -2.75 -24.8063 -6.81125 -2.75 -23.4513 -4.7838
2 24 -2.75 -23.4513 -4.7838 -2.75 -22.5 0
2 24 -2.75 -23.4513 4.7838 -2.75 -22.5 0
2 24 -2.75 -24.8063 6.81125 -2.75 -23.4513 4.7838
5 24 2.75 -20.0351 4.0897 -2.75 -20.0351 4.0897 2.75 -18.6 4.375 2.75 -21.4702 4.375
5 24 -2.75 -18.6 4.375 2.75 -18.6 4.375 2.75 -20.0351 4.0897 2.75 0 6.25
5 24 2.75 -21.4702 4.375 -2.75 -21.4702 4.375 2.75 -20.0351 4.0897 2.75 -24.8063 6.81125
5 24 -2.75 -18.6 -4.375 2.75 -18.6 -4.375 2.75 -20.0351 -4.0897 2.75 0 -6.25
5 24 -2.75 -20.0351 -4.0897 2.75 -20.0351 -4.0897 2.75 -18.6 -4.375 -2.75 -21.4702 -4.375
5 24 -2.75 -21.4702 -4.375 2.75 -21.4702 -4.375 2.75 -20.0351 -4.0897 -2.75 -24.8063 -6.81125
    Line 38: 1 16 0 -46.754315 0 3.75 0 0 0 -3.49569 0 0 0 3.75 box3u2p.dat
    Line 58: 3 16 -2.75 19.935125 -3.464625 -2.75 19.935125 3.464625 -2.75 22.25 0
    Line 61: 3 16 2.75 22.25 0 2.75 19.935125 3.464625 2.75 19.935125 -3.464625
    Line 64: 1 16 0 9.967562 4.857312 0 0 -2.75 -9.967562 0 0 1.392688 -1 0 rect2p.dat
    Line 65: 1 16 0 9.967562 -4.857312 0 0 2.75 -9.967562 0 0 -1.392688 1 0 rect2p.dat
    Line 66: 4 16 -2.75 19.935125 3.464625 -2.75 19.935125 -3.464625 -2.75 0 -6.25 -2.75 0 6.25
    Line 67: 4 16 2.75 0 6.25 2.75 0 -6.25 2.75 19.935125 -3.464625 2.75 19.935125 3.464625
    Line 68: 5 24 -2.75 19.935125 -3.464625 2.75 19.935125 -3.464625 2.75 21.151625 -2.651625 2.75 0 -6.25
    Line 69: 5 24 -2.75 19.935125 3.464625 2.75 19.935125 3.464625 2.75 21.151625 2.651625 2.75 0 6.25
    Line 70: 5 24 -2.75 0 6.25 2.75 0 6.25 2.75 19.935125 3.464625 2.75 -18.6 4.375
    Line 71: 5 24 -2.75 0 -6.25 2.75 0 -6.25 2.75 19.935125 -3.464625 2.75 -18.6 -4.375
