Unofficial File parts/23985.dat
0 Minifig Sword Hilt with Skull
0 Name: 23985.dat
0 !CATEGORY Minifig Accessory
0 !HISTORY 2016-03-18 {LEGO Digital Designer} Original part shape
0 !HISTORY 2023-09-22 [ejboer] File preparation for LDraw Parts Tracker
1 16 0 0 0 -4 0 0 0 -10.2 0 0 0 4 4-4cyli.dat
1 16 0 -10.2 0 0 0 -4 0 -.55 0 -4 0 0 1-4cyls.dat
1 16 0 -10.2 0 0 0 4 0 -.55 0 -4 0 0 1-4cyls.dat
1 16 0 -10.2 0 0 0 4 0 -.55 0 4 0 0 1-4cyls.dat
1 16 0 -10.2 0 0 0 -4 0 -.55 0 4 0 0 1-4cyls.dat
1 16 0 0 0 4 0 0 0 -1 0 0 0 4 4-4disc.dat
1 16 0 0 0 4 0 0 0 1 0 0 0 4 4-4edge.dat
1 16 0 -20 -4.75 1 0 0 0 0 -1 0 1 0 stud2.dat
1 16 0 -20 -4.75 6.9 0 0 0 0 -6.9 0 1 0 4-4disc.dat
1 16 0 -20 0 -3 0 0 0 0 -3 0 4 0 4-4cylo.dat
1 16 0 -20 4 -3 0 0 0 0 -3 0 -1 0 4-4disc.dat
1 16 0 -20 -.55 .6 0 0 0 0 -.6 0 .55 0 4-4con5.dat
1 16 0 -20 -.55 3.6 0 0 0 0 3.6 0 -1 0 4-4edge.dat
1 16 0 -20 -.55 .4 0 0 0 0 .4 0 -1 0 4-4ring9.dat
1 16 0 -20 -.55 1 0 0 0 0 1 0 -1 0 4-4ring4.dat
1 16 0 -20 -.55 5 0 0 0 0 5 0 5.3 0 4-4cylo.dat
1 16 0 -20 4.75 1 0 0 0 0 1 0 -1 0 4-4ring5.dat
1 16 0 -20 4.75 .6 0 0 0 0 .6 0 -1 0 4-4ring10.dat
1 16 0 -20 4.75 .3 0 0 0 0 .3 0 -1 0 4-4ring22.dat
1 16 0 -20 -4.75 6.9 0 0 0 0 6.9 0 9.5 0 4-4cylo.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\23985s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\23985s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\23985s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 -1 s\23985s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\23985s02.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\23985s02.dat
3 16 2.6406 -26.3749 -3.036 1.381 -28.85 -3 0 -26.9 -2.935
3 16 0 -26.9 -2.935 1.381 -28.85 -3 0 -29.316 -2.983
4 16 0 -29.316 -2.983 1.381 -28.85 -3 1.328 -28.439 2.946 0 -28.878 2.968
3 16 0 -28.878 2.968 1.328 -28.439 2.946 0 -26.9 2.936
3 16 1.381 -28.85 -3 2.6406 -26.3749 -3.036 2.6406 -26.3749 3.001
3 16 1.381 -28.85 -3 2.6406 -26.3749 3.001 1.328 -28.439 2.946
3 16 2.6406 -26.3749 3.001 0 -26.9 2.936 1.328 -28.439 2.946
2 24 2.6406 -26.3749 -3.036 1.381 -28.85 -3
5 24 0 -26.9 -2.935 1.381 -28.85 -3 2.6406 -26.3749 -3.036 0 -29.316 -2.983
2 24 1.381 -28.85 -3 0 -29.316 -2.983
2 24 0 -28.878 2.968 1.328 -28.439 2.946
5 24 1.328 -28.439 2.946 0 -26.9 2.936 2.6406 -26.3749 3.001 0 -28.878 2.968
2 24 1.328 -28.439 2.946 2.6406 -26.3749 3.001
5 24 1.328 -28.439 2.946 1.381 -28.85 -3 0 -28.878 2.968 2.6406 -26.3749 3.001
5 24 2.6406 -26.3749 3.001 1.381 -28.85 -3 2.6406 -26.3749 -3.036 1.328 -28.439 2.946
2 24 0 -26.9 -2.935 2.6406 -26.3749 -3.036
2 24 2.6406 -26.3749 3.001 0 -26.9 2.936
2 24 2.6406 -26.3749 -3.036 2.6406 -26.3749 3.001
3 16 -1.381 -28.85 -3 -2.6406 -26.3749 -3.036 0 -26.9 -2.935
3 16 -1.381 -28.85 -3 0 -26.9 -2.935 0 -29.316 -2.983
4 16 -1.328 -28.439 2.946 -1.381 -28.85 -3 0 -29.316 -2.983 0 -28.878 2.968
3 16 -1.328 -28.439 2.946 0 -28.878 2.968 0 -26.9 2.936
3 16 -2.6406 -26.3749 -3.036 -1.381 -28.85 -3 -2.6406 -26.3749 3.001
3 16 -2.6406 -26.3749 3.001 -1.381 -28.85 -3 -1.328 -28.439 2.946
3 16 0 -26.9 2.936 -2.6406 -26.3749 3.001 -1.328 -28.439 2.946
2 24 -1.381 -28.85 -3 -2.6406 -26.3749 -3.036
5 24 -1.381 -28.85 -3 0 -26.9 -2.935 -2.6406 -26.3749 -3.036 0 -29.316 -2.983
2 24 0 -29.316 -2.983 -1.381 -28.85 -3
2 24 -1.328 -28.439 2.946 0 -28.878 2.968
5 24 0 -26.9 2.936 -1.328 -28.439 2.946 -2.6406 -26.3749 3.001 0 -28.878 2.968
2 24 -2.6406 -26.3749 3.001 -1.328 -28.439 2.946
5 24 -1.381 -28.85 -3 -1.328 -28.439 2.946 0 -28.878 2.968 -2.6406 -26.3749 3.001
5 24 -1.381 -28.85 -3 -2.6406 -26.3749 3.001 -2.6406 -26.3749 -3.036 -1.328 -28.439 2.946
2 24 -2.6406 -26.3749 -3.036 0 -26.9 -2.935
2 24 0 -26.9 2.936 -2.6406 -26.3749 3.001
2 24 -2.6406 -26.3749 3.001 -2.6406 -26.3749 -3.036
5 24 -1.328 -28.439 2.946 0 -29.316 -2.983 -1.381 -28.85 -3 0 -28.878 2.968
5 24 0 -29.316 -2.983 0 -26.9 -2.935 -1.381 -28.85 -3 1.381 -28.85 -3
5 24 0 -26.9 2.936 0 -28.878 2.968 1.328 -28.439 2.946 -1.328 -28.439 2.946
5 24 0 -28.878 2.968 0 -29.316 -2.983 -1.328 -28.439 2.946 1.381 -28.85 -3
Errors Found (HN)
Willy Tschager [Holly-Wood]
Has Uncertified Subfiles
Evert-Jan Boer [ejboer]
2023-09-22 15:06:54
posted a vote of Hold
2023-09-22 16:24:47
Orion Pobursky [OrionP]
2023-09-22 16:36:41
subfile references use "/" vice "\"
2023-09-23 07:20:00
updated subfile reference
2023-09-23 08:05:57
Scaling of the stud.dat primitive is not allowed.
2023-09-23 14:13:59
Corrected the stud scalings
made the following comment.
2023-09-23 16:30:22
I think the orientation of the stud might be wrong. Guess the logo should be horizontal.
Is it possible to insert an axle into the skull?
2023-09-23 16:35:18
cgi images, and the ldd download, show a different inside of the skull.
2023-09-23 16:38:21
The ldd model has some edgelines on the side of the skull that I think are missing.
Gerald Lasser [GeraldLasser]
2023-09-23 16:50:52
The hole at the top of the skull should be able to fit a standard bar, it is too small to do so now
2023-09-24 07:37:19
Due to the reasons above. The skull is not correct.
2023-09-24 08:16:55
That was indeed a concern, should it be able to hold a axle, bar or both? I took the technic brick with axle hole as example, it has the same issue with a bar
2023-09-24 08:21:45
Now i tested it, it can hold the axle of a brick separator, but that is a smaller axle.
See difference on inside at https://rebrickable.com/parts/23985/weapon-sword-hilt-with-skull-and-bar-djinn/, the photo is correct, the renders are not. Will do some changes and look at the skull edges as well.
edited the part header.
2023-10-16 20:23:29
Header Edits
category:
Minifig
to
Minifig Accessory
2024-03-23 00:59:43
Update ring primitives via script. This will not reset the vote status of the part.
Jeff Jones [notmaster]
2025-01-25 15:43:11
dont know if im stupid but
the hole at the top of the skull doesnt seem too small for the bar
maybe add ninjago djinn blade and sets ref keywords
and maybe add a help line for placing angle of the axe head (53454)
cancelled their vote.
2025-01-25 18:01:44
subfile was updated with the fix to hold the bar, removing hold
2025-01-26 09:17:49
I think the stud should be rotated, to have the logo horizontal.
2025-08-25 22:18:58
bump
2025-09-28 08:32:18
* Stud orientation
* Overlap:
2 24 0 -38.723 -8.391 0 -36.395 -7.583
2 24 0 -36.395 -7.583 0 -35.056 -2.458
* Overlap:
2026-07-02 09:14:02
* Upgrade to HOILD
Interesting subfile structure.
