Unofficial File parts/s/821s01.dat
~Garage Door Frame  1 x  6 x  4 without Studs - without Tabs
0 ~Garage Door Frame 1 x 6 x 4 without Studs - without Tabs 0 Name: s\821s01.dat 0 Author: N. W. Perry [Plastikean] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
1 16 -2.5 0 0 0 0 -7.5 0 1 0 60 0 0 rect.dat 1 16 -4 1 0 0 0 -6 0 1 0 54 0 0 box2-11.dat 2 24 2 2 54 -10 2 54 2 24 2 2 -54 -10 2 -54 1 16 3.5 6 0 0 0 -1.5 0 4 0 54 0 0 box2-5.dat 4 16 5 0 60 5 0 -60 5 10 -54 5 10 54 4 16 2 2 54 -10 2 54 -10 102 54 2 10 54 4 16 5 10 54 2 10 54 -10 102 54 5 102 54 4 16 -10 102 -54 -10 2 -54 2 2 -54 2 10 -54 4 16 -10 102 -54 2 10 -54 5 10 -54 5 102 -54 4 16 -10 6 60 -10 2 54 -10 0 54 -10 0 60 4 16 -10 102 54 -10 2 54 -10 6 60 -10 96 60 3 16 -10 102 54 -10 96 60 -10 102 60 2 24 -10 2 54 -10 102 54 2 24 -10 0 60 -10 6 60 2 24 -10 96 60 -10 102 60 4 16 -10 0 60 5 0 60 -8 6 60 -10 6 60 4 16 -8 96 60 -8 6 60 5 0 60 5 102 60 4 16 -10 102 60 -10 96 60 -8 96 60 5 102 60 4 16 5 0 60 5 10 54 5 102 54 5 102 60 2 24 5 102 60 5 0 60 2 24 5 102 54 5 10 54 4 16 -10 0 -54 -10 2 -54 -10 6 -60 -10 0 -60 4 16 -10 6 -60 -10 2 -54 -10 102 -54 -10 96 -60 3 16 -10 96 -60 -10 102 -54 -10 102 -60 2 24 -10 2 -54 -10 102 -54 2 24 -10 0 -60 -10 6 -60 2 24 -10 96 -60 -10 102 -60 4 16 -8 6 -60 5 0 -60 -10 0 -60 -10 6 -60 4 16 5 0 -60 -8 6 -60 -8 96 -60 5 102 -60 4 16 -8 96 -60 -10 96 -60 -10 102 -60 5 102 -60 4 16 5 10 -54 5 0 -60 5 102 -60 5 102 -54 2 24 5 102 -60 5 0 -60 2 24 5 102 -54 5 10 -54 1 16 -2.5 102 57 7.5 0 0 0 -1 0 0 0 3 rect.dat 1 16 -2.5 102 -57 7.5 0 0 0 -1 0 0 0 3 rect.dat 1 16 -17.5 33.5 57 0 0 -7.5 7.5 0 0 0 -4 0 2-4cylo.dat 1 16 -17.5 33.5 57 0 0 -7.5 7.5 0 0 0 -1 0 2-4chrd.dat 1 16 -13.75 33.5 57 3.75 0 0 0 0 -7.5 0 -1 0 rect1.dat 1 16 -17.5 33.5 53 0 0 -7.5 7.5 0 0 0 1 0 2-4chrd.dat 1 16 -13.75 33.5 53 3.75 0 0 0 0 -7.5 0 1 0 rect1.dat 1 16 -13.75 41 55 0 0 3.75 0 -1 0 2 0 0 rect3.dat 1 16 -13.75 26 55 0 0 3.75 0 1 0 2 0 0 rect3.dat 1 16 -10 33.5 53.5 0 -1 0 0 0 7.5 -.5 0 0 rect1.dat 1 16 -17.5 33.5 53 0 0 -2 2 0 0 0 1 0 4-4edge.dat 1 16 -17.5 33.5 50.5 0 0 -2 -2 0 0 0 2.5 0 4-4cyli.dat 1 16 -17.5 33.5 50.5 0 0 -2 -2 0 0 0 -2.5 0 4-8sphe.dat 1 16 -17.5 33.5 -57 0 0 -7.5 7.5 0 0 0 4 0 2-4cylo.dat 1 16 -17.5 33.5 -57 0 0 -7.5 7.5 0 0 0 1 0 2-4chrd.dat 1 16 -13.75 33.5 -57 3.75 0 0 0 0 -7.5 0 1 0 rect1.dat 1 16 -17.5 33.5 -53 0 0 -7.5 7.5 0 0 0 -1 0 2-4chrd.dat 1 16 -13.75 33.5 -53 3.75 0 0 0 0 -7.5 0 -1 0 rect1.dat 1 16 -13.75 41 -55 0 0 3.75 0 -1 0 2 0 0 rect3.dat 1 16 -13.75 26 -55 0 0 3.75 0 1 0 2 0 0 rect3.dat 1 16 -10 33.5 -53.5 0 -1 0 0 0 -7.5 .5 0 0 rect1.dat 1 16 -17.5 33.5 -53 0 0 -2 2 0 0 0 1 0 4-4edge.dat 1 16 -17.5 33.5 -50.5 0 0 -2 -2 0 0 0 -2.5 0 4-4cyli.dat 1 16 -17.5 33.5 -50.5 0 0 -2 -2 0 0 0 2.5 0 4-8sphe.dat
None
Part Reviewer
2023-10-10 01:51:06
Part Reviewer
2023-10-10 01:54:38
Fixing a BFC error…
posted a vote of Hold
2023-10-15 13:56:17
All empty comments, loose zeros, should be deleted.
2023-10-15 14:03:52
Orientation is wrong. Should be the same as the doors.
Part Reviewer
made the following comment.
2023-10-15 23:03:08
Agreed. The weird orientation was inherited from somewhere…
I'll also change the origin to match existing 821, or should it be at the hinge pin to also match the door?
Part Reviewer
2023-10-15 23:05:44
Orientation and origin fixed
2023-10-16 15:18:41
I don't like this origin.
We have a chance now to correct the strange origin of 821.dat, if we choose to renumber and move it.
821 has an origin inherited from the bottom plate 820.dat. Bad. Should be at top stud surface, between the studs.
These 2 frames should have an origin that make them behave like the doors and windows from the Mursten era of parts.
You had a good origin. Only the orientation was wrong.
1 7 0 0 0 1 0 0 0 1 0 0 0 1 820.dat
1 2 70 -96 0 0 0 -1 0 1 0 1 0 0 821b.dat
1 4 53 -62 0 0 1 0 -1 0 0 0 0 1 822ec01.dat
1 10047 60 -24 70 -1 0 0 0 1 0 0 0 -1 u8001c.dat
1 10047 70 -48 80 0 0 -1 0 1 0 1 0 0 u8001a.dat
1 10047 60 -72 70 -1 0 0 0 1 0 0 0 -1 u8001c.dat
1 10047 70 -96 80 0 0 -1 0 1 0 1 0 0 u8001a.dat
1 7 0 0 0 1 0 0 0 1 0 0 0 1 821.dat
1 2 70 -72 120 0 0 -1 0 1 0 1 0 0 u8041.dat
btw, there's a collission between the counterweights and the conical, sloping ramp.
Part Reviewer
2023-10-21 01:28:53
Origin reverted
Part Reviewer
2023-10-21 01:34:29
Re: the collision, yeah...this kind of confirms what I've suspected, that the counterweights are a bit too thick. But to fix this requires fixing the connection point on the door as well. Worth it?
Willy Tschager [Holly-Wood]
2025-10-06 06:19:30
* Duplicated edges due to rects:
2 24 -10 41 53 -10 26 53
2 24 -10 41 -53 -10 26 -53
* Rects
2025-10-06 06:25:44
* T-junk
2 27 -10 0 60 -10 0 -60
2 27 -10 26 54 -10 41 54
This part is copyright © N. W. Perry
