Unofficial File parts/3937c02.dat
Base Part: 3937.dat
0 Hinge 1 x 2 with 2 x 2 Top Plate
0 Name: 3937c02.dat
0 !HISTORY 2024-11-12 [MagFors] Reworked as a uncoloured shourtcut using 6134
1 16 0 0 0 1 0 0 0 1 0 0 0 1 3937.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 6134.dat
Errors Found (CCHN)
| User | Vote |
| OrionP | Hold |
| Blechtaler | Certify |
| WUIt | Certify |
Vincent Messenet [Cheenzo]
2023-11-28 19:47:35
made the following comment.
2024-01-25 17:11:13
I think we should remake this, as an uncoloured assy of the base and the 2x2 hinge plate, 6134.
Rene Rechthaler [Blechtaler]
2024-01-25 17:24:33
which way should the 2x2 go? (both are possible, but the one to the front cant be fully used...)
2024-01-25 17:31:27
I would place it so that a full 90 degree rotation is possible.
Orion Pobursky [OrionP]
posted a vote of Hold
2024-11-11 19:39:40
I see no reason for this shortcut
2024-11-11 21:10:59
I agree.
2024-11-11 21:24:50
guess there are too many different ones, there were other colors too but they got deleted
cancelled their vote.
2024-11-11 21:32:28
As I said above:
"I think we should remake this, as an uncoloured assy of the base and the 2x2 hinge plate, 6134."
2024-11-11 21:34:18
long side of the 2x2 to the back?
2024-11-11 21:54:17
Yes
2024-11-12 17:11:15
Peter Blomberg [WUIt]
posted a vote of Certify
2025-11-20 06:07:01
The assembly is fine. Not sure if needed.
2025-11-20 08:53:32
2025-11-29 15:16:38
I'm still dubious about why this is needed. Convince me.
Philippe Hurbain [Philo]
2025-11-29 16:21:15
As it is trivial to assemble and it is not provided as such by LEGO, I don't see the point of this shortcut.
2025-11-29 17:29:51
Your original objection was against a coloured shortcut. Black top part.
I'd say since we have c01 in the library, we ought to also include c02.
This part is copyright ©
Vincent Messenet
Licensed under
CC BY 4.0
LDraw.org Parts Tracker,
Magnus Forsberg
