Unofficial File parts/3068bp0q.dat
Tile  2 x  2 with Super Mario Scanner Code Television Pattern
0 Tile  2 x  2 with Super Mario Scanner Code Television Pattern
0 Name: 3068bp0q.dat
0 Author: Florent Faramond [Makou]
0 !CATEGORY Sticker Shortcut
0 !KEYWORDS Bricklink 3068bpb1390, Brickowl 91353, Rebrickable 3068bpr0047
0 !KEYWORDS Set 71374
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bs01.dat
4 16 20 0 -20 20 0 20 -20 0 20 -20 0 -20
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s48.dat
Not releaseable Errors Found (CHN) Errors Found (CHN)
Certify
Hold
Part Author
2023-12-08 16:43:21
Javier Orquera [kuramapika1]
Part Author
made the following comment.
2023-12-08 17:53:59
I don't understand: as far as I know, it's the PT Admin job to change the part numbers (also, don't know if the change of autor is right); and the following https://library.ldraw.org/tracker/29963 prevents me to do the changes myself.
The question is: wath is the procedure to follow?
Gerald Lasser [GeraldLasser]
2023-12-08 22:54:43
What is the problem with it? please state what admin shall do with it.
Orion Pobursky [OrionP]
2023-12-09 00:26:16
There's been some off and on comments on these parts. We made a decision but I'm one person and haven't had time to rename all these parts
Part Author
2023-12-09 01:00:30
Orion, if there is a range of numbers to be asigned, tell me and I starting to do the change. Then, it is better to submit to the part tracker or send directly to the e-mail?
posted a vote of Certify
2024-05-18 16:41:56
Should be renumbered to 3068bpm** assigned for Super Mario barcode tiles
posted a vote of Hold
2025-03-25 20:54:56
Hold until renumbering is resolved.
This should be a Sticker Shortcut rather than a Printed Version IMHO.
Part Author
2025-03-25 20:59:50
I did most of them, with correct numbers (long time ago); what do I do now?
