Unofficial File parts/54779d01.dat
0 Boat Hull Floating 51 x 12 with Dark Bluish Grey Top with "POLICE 7287" and Life Preserver Stickers
0 Name: 54779d01.dat
0 !CATEGORY Boat
0 !KEYWORDS Bricklink 70670stk01, Brickowl 385606, City, Police boat
0 !KEYWORDS Rebrickable 46481, Set 7287, ship
0 !HISTORY 2026-10-08 [KnightOfTarenta] Changed Base Part to Full Assembly
0 // Base Part
1 16 0 0 0 1 0 0 0 1 0 0 0 1 54779p02.dat
0 // Stickers
1 16 113.6409 39.75 100 0 -.9964 .0851 0 -.0851 -.9964 1 0 0 4599941b.dat
1 16 -113.6409 39.75 100 0 .9964 -.0851 0 .0851 -.9964 -1 0 0 4599941a.dat
1 16 113.9827 35.75 -320 0 -.9964 .0851 0 -.0851 -.9964 1 0 0 4599941f.dat
1 16 -113.9827 35.75 -320 0 .9964 -.0851 0 .0851 -.9964 -1 0 0 4599941f.dat
Needs 2 More Votes (N)
2023-12-28 13:51:29
Orion Pobursky [OrionP]
edited the part header.
2024-05-18 04:21:01
posted a vote of Hold
2025-12-20 20:16:41
This is not a sticker shortcut and is mis-named
renamed the part.
2026-01-12 08:19:47
"parts/54779c02d01.dat" to "parts/54779d01c02.dat"
2026-01-12 08:21:07
Header Edits
description:
to
Boat Hull Floating 51 x 12 with "POLICE 7287" and Life Preserver Stickers with Dark Bluish Grey Top
2026-01-12 17:16:37
Header Edits
category:
Sticker Shortcut
to
Boat
made the following comment.
2026-01-12 22:48:30
IMHO it's wrong to use -c02 on these. 54779 is the assy number of these hulls.
The other 2 should be changed from -c01 and -c02, and should be -p01 and -p02.
But that will create another issue. Is it possible to have a the "pattern" on this part made by a colour combo + a sticker?
I would like this to be 54779p03. Or should it be 54779p02d01 ?
2026-01-13 01:25:41
Your right. What should happen is that the assembly should have the stickers not the component parts. Therefore 54779p01 will get the stickers applied and so forth.
2026-01-13 22:20:50
When the stickers are in this file it should be renumbered to 54479d01.
renamed the part.
2026-01-14 14:57:29
"parts/54779d01c02.dat" to "parts/54779d01.dat"
2026-01-14 17:29:45
Aren’t almost all of the keywords incorrect? The links point to a different set (Monastery of Spinjitzu), and the set number doesn’t match the sticker numbering at all.
2026-01-14 18:18:13
Name is still wrong. The part should be 54479p02d01 and should consist of 54479p02 and the stickers.
2026-01-14 18:43:25
Yes, you're right. I was to fast. Forgot the p02.
2026-10-08 13:15:41
*moved stickers to the full assembly, name and external links fixed
Someone please move this to the correct part number.
2026-10-08 13:16:34
Header Edits
history:
to
2026-10-08 13:18:26
54779c02 > 54779p02
category:
Boatto
Sticker Shortcut
