Unofficial File parts/765c04.dat
Part Attributes: Base Part: 765.dat
Electric Plug (Type 4) Single with Wide Cable End
0 Electric Plug (Type 4) Single with Wide Cable End 0 Name: 765c04.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2023-12-28 [Blechtaler] made from 765c03.dat 0 !HISTORY 2024-07-02 [Blechtaler] corrected origin
1 16 17.5 0 3 0 -1 0 1 0 0 0 0 1 765c01.dat 1 375 0 0 25 0 0 1 1 0 0 0 1 0 u9136.dat 1 16 -17.5 0 3 0 1 0 1 0 0 0 0 1 765c01.dat
None
2023-12-28 20:09:37
as an alternative to 2775c02.dat
2024-07-02 21:30:47
changed the origin (is now identical to 2775c02)
made the following comment.
2024-07-04 16:44:48
I think these description need some changes:
765c01, Electric Plug (Type 4) Single (Complete)
765c02, Electric Plug (Type 4) Single with Cable End
765c04, Electric Plug (Type 4) Single with Wide Cable End
765c05, Electric Plug (Type 4) Single with Cable End (Plugs placed flat)
765c03, Electric Cable Grey with Plugs (Type 4) Single
I get that the name of one plug is "(Type 4) Single", but,
why are all files containing 2 plugs, using "Single" ?
why do the cable, containg 4 single plugs, 2 in each end, have "Single" in the description.
2024-07-04 17:08:32
https://library.ldraw.org/search/suffix?basepart=592
this one (the old single plugs) isnt better...
LDraw.org Parts Tracker,
