Unofficial File parts/35763.dat
0 Minifig Balloon with Thin Bar on Handle
0 Name: 35763.dat
0 !CATEGORY Minifig Accessory
0 !KEYWORDS Bricklink 35703c01, Brickowl 540713
1 16 0 0 0 1 0 0 0 1 0 0 0 1 35703.dat
1 16 0 0 -7 0 0 -1 0 1 0 1 0 0 35702.dat
1 16 0 0 -7 0 0 -1 0 1 0 -1 0 0 35702.dat
Awaiting Admin Review (CCN)
Gerald Lasser [GeraldLasser]
2024-01-03 22:04:43
posted a vote of Hold
2024-01-04 21:15:24
Rene Rechthaler [Blechtaler]
made the following comment.
2024-01-04 22:10:50
shouldnt the handle be white? there are two versions: orange balloon and dark purple balloon...
or should these be separate shortcuts?
the handle is always white, only the balloon changes, but BL has two different parts because of the different bloon colors.
how are the color versions handled then?
2024-01-04 22:59:31
I think the handle position is ok, as it fits best in a minifig hand this way.
I will rotate the balloon and will use u-numbers and create a white c01
2024-01-04 23:34:06
2024-01-05 08:41:51
I still think it needs a 90 degree rotation to better fit a minifig hand.
https://images.brickset.com/sets/large/71021-6.jpg?
2025-10-19 00:50:11
Agree on that.
Also is there a need to have the balloon halves at -7? Unlikely they are used elsewhere.
Do we have a correct parts ID meanwhile?
Peter Blomberg [WUIt]
2025-11-20 06:33:54
I concur that the assembly needs a 90 degree rotation such that the bar points backward. At the same time, as Chris points out, the displacement by 7 LDU should be propagated to the quarter subfile so that unnecessary offsets are avoided in the half and the assembly.
2025-11-20 16:24:25
This partnumber is only valid on the string. The complete assy is 35763. The balloon half is 35702.
https://brickset.com/parts/design-35763
The only thing I don't know is if 35703 is a dual mould of string+half a balloon. I guess not.
IMO, 35763 is an assy of a string (35703) + 2 pcs. of 35702.
Hold for the orientation.
2026-05-13 22:57:17
re-oriented and rounded
2026-05-13 22:57:18
renamed the part.
2026-05-15 15:15:10
"parts/35703.dat" to "parts/35763.dat"
edited the part header.
2026-05-15 15:29:08
Header Edits
description:
Minifig Ballon with Thin Bar on Handle
to
posted a vote of Certify
2026-11-02 18:37:16
2026-11-02 19:27:52
https://forums.ldraw.org/thread-27921-post-52324.html#pid52324
But I think maybe the handle should be rotated instead...
