Unofficial File parts/70928.dat
0 Electric Train 9V Transformer Europlug
0 Name: 70928.dat
0 !HELP this part is just a static shortcut for display, use both subparts separately
0 !CATEGORY Electric
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\70928s01.dat
1 16 0 426 80 1 0 0 0 0 -1 0 1 0 s\70928s02.dat
0 // cable (or use u9028.dat scaled 2x)
1 16 -40 157 80 2 0 0 0 0 -2 0 -2 0 s\61930s01.dat
Needs 2 More Votes (N)
Rene Rechthaler [Blechtaler]
2024-02-14 11:48:06
2024-02-14 11:50:13
got some links wrong
2024-05-26 17:07:22
corrected position
2025-09-02 16:33:19
used u9028 and 61930s01
made the following comment.
2025-09-02 17:50:10
I don't think this works. A user wanting to reconfigure this into another shape can't work with subfiles.
The Help info need to be removed.
2025-09-02 20:10:44
Should everything be parts instead of subparts? which numbers? (70928 is printed on the wall plug)
(the small dotted cable parts should signal a longer cable)
