Unofficial File parts/u9258.dat
~Electric Switch: Remote Control for Train Point  2 x  7 Switch
0 ~Electric Switch: Remote Control for Train Point  2 x  7 Switch
0 Name: u9258.dat
0 !CATEGORY Electric
0 !CMDLINE -c4
0 !HISTORY 2024-02-15 [Steffen] separated into ~parts
0 !HISTORY 2024-11-11 [Blechtaler] moved origin to top, separated electric contacts
0 !HISTORY 2026-07-01 [MagFors] closed mesh
1 16 0 -4 22.5 10 0 0 0 1 -4 0 0 -2.5 rect3.dat
1 16 0 -6 10 0 0 10 2 1 0 -10 0 0 rect2p.dat
2 24 -10 -4 0 10 -4 0
1 16 0 -6 -10 0 0 10 2 1 0 10 0 0 rect2p.dat
1 16 0 -4 -22.5 10 0 0 0 1 -4 0 0 2.5 rect3.dat
3 16 10 0 25 10 -8 20 10 -4 0
3 16 10 0 25 10 -4 0 10 0 -25
3 16 10 0 -25 10 -4 0 10 -8 -20
3 16 -10 -8 20 -10 0 25 -10 -4 0
3 16 -10 -4 0 -10 0 25 -10 0 -25
3 16 -10 -4 0 -10 0 -25 -10 -8 -20
1 16 0 0 0 0 0 -10 0 1 0 25 0 0 box5-2p.dat
Steffen [Steffen]
2024-02-15 18:27:53
Steffen [Steffen]
posted a vote of Hold
2024-02-15 18:29:58
the switch is modeled too small, i.e., when it gets put into "pressed down position",
then a gap in the parent part is caused. the switch should at least be enlarged so far that when it is positioned pressed-down
no gap is visible in the parent switch part.
Rene Rechthaler [Blechtaler]
2024-11-11 21:32:02
moved origin to top, separated contacts
Willy Tschager [Holly-Wood]
made the following comment.
2025-09-15 07:01:50
* Correct me if I'm wrong. When you sub you get authorship of the sub.
2025-09-15 15:59:43
As a separate part, the bottom edges are missing.
Maybe add a bottom surface to close the mesh?
2026-07-01 17:46:00
2026-07-01 22:05:20
Where is the rotation centre on the button?
Maybe the origin should be changed?
