Unofficial File parts/18605p0q.dat
0 ~Electric Brick 4 x 4 x 0.667 Round - Top with 2 Studs with Blue and Red 3D Glasses on White Background Pattern
0 Name: 18605p0q.dat
0 !CATEGORY Electric
0 !KEYWORDS Dimensions, gizmo, Gremlins, Set 71256
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\18605s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\18605s02.dat
0 BFC NOCLIP
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\18605p0qs01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\18605p0qs01.dat
1 70 0 0 0 1 0 0 0 1 0 0 0 1 s\18605s03.dat
1 15 0 0 0 1 0 0 0 1 0 0 0 1 s\18605s04.dat
3 15 -21.65 0 -16.75 0 0 -19.3 21.65 0 -16.75
4 1 -4.1 0 -22.6 -11 0 -22.6 -11 0 -26.7 -10.95 0 -26.85
4 1 -4.1 0 -22.6 -10.95 0 -26.85 -10.8 0 -26.9 -3.9 0 -22.65
4 1 -3.75 0 -22.8 -3.9 0 -22.65 -10.8 0 -26.9 -3.7 0 -23.05
4 1 -3.65 0 -23.4 -3.7 0 -23.05 -10.8 0 -26.9 -3.7 0 -24.2
4 1 -3.85 0 -25.1 -3.7 0 -24.2 -10.8 0 -26.9 -4.1 0 -26
4 1 -4.35 0 -26.6 -4.1 0 -26 -10.8 0 -26.9 -4.5 0 -26.8
3 1 -4.5 0 -26.8 -10.8 0 -26.9 -4.7 0 -26.9
4 4 11 0 -26.7 11 0 -22.6 4.1 0 -22.6 10.95 0 -26.85
4 4 10.8 0 -26.9 10.95 0 -26.85 4.1 0 -22.6 3.9 0 -22.65
4 4 10.8 0 -26.9 3.9 0 -22.65 3.75 0 -22.8 3.7 0 -23.05
4 4 10.8 0 -26.9 3.7 0 -23.05 3.65 0 -23.4 3.7 0 -24.2
4 4 10.8 0 -26.9 3.7 0 -24.2 3.85 0 -25.1 4.1 0 -26
4 4 10.8 0 -26.9 4.1 0 -26 4.35 0 -26.6 4.5 0 -26.8
3 4 10.8 0 -26.9 4.5 0 -26.8 4.7 0 -26.9
Needs 2 More Votes (N)
Has Uncertified Subfiles
Evert-Jan Boer [ejboer]
2024-02-17 16:01:23
2024-10-21 17:13:50
Added NOCLIP
posted a vote of Hold
2025-04-23 08:24:54
Pattern could be improved:
*the outlines of the 3D glasses should be about the same size as the panel borders
*the nose cutout should be pointier (more like a parabola than half an ellipsis if this makes sense)
*the lenses should have rounder edges, especially towards the nose region where there's a sharp edge currently
*the fillets on the outer edges don't match somehow on inside and outside. The black line should form a quarter circle which it currently doesn't
edited the part header.
2025-04-23 08:25:38
Header Edits
keywords:
Set 71256
to
Set 71256, Dimensions, Gremlins, Gizmo
2026-01-19 07:45:39
Updated pattern
