Unofficial File parts/s/105645s03.dat
~Wheel 22 x 50 with Integral Smooth Racing Tyre Rim Holes  1/12
0 ~Wheel 22 x 50 with Integral Smooth Racing Tyre Rim Holes 1/12 0 Name: s\105645s03.dat 0 Author: Philippe Hurbain [Philo] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2024-03-23 [OrionP] Updated ring primitives
1 16 0 0 -2 0 0 29.4 29.4 0 0 0 1 0 48\1-12edge.dat 1 16 0 0 -2 0 0 29.4 29.4 0 0 0 1 0 48\1-12chrd.dat 1 16 4.1861 22.101 -2 0.55669 0 2.9708 3.96107 0 -0.41752 0 1 0 1-4ndis.dat 1 16 2.5399 17.565 -2 -0.1396 0 2.99817 -3.99756 0 -0.1047 0 1 0 3-16ndis.dat 4 16 5.3985 13.4628 -2 5.2565 15.9384 -2 7.1569 21.6835 -2 14.7 25.4604 -2 3 16 7.1569 21.6835 -2 7.7136 25.6445 -2 14.7 25.4604 -2 3 16 0 26.5 -2 0 29.4 -2 4.7428 26.062 -2 4 16 14.7 25.4604 -2 7.7136 25.6445 -2 4.7428 26.062 -2 0 29.4 -2 4 16 0 8 -2 0 13.401 -2 2.4003 13.5675 -2 4.0286 6.9778 -2 3 16 2.4003 13.5675 -2 5.3985 13.4628 -2 4.0286 6.9778 -2 3 16 4.0286 6.9778 -2 5.3985 13.4628 -2 14.7 25.4604 -2 1 16 0 0 2 0 0 29.4 29.4 0 0 0 -1 0 48\1-12edge.dat 1 16 0 0 2 0 0 29.4 29.4 0 0 0 -1 0 48\1-12chrd.dat 1 16 4.1861 22.101 2 0.55669 0 2.9708 3.96107 0 -0.41752 0 -1 0 1-4ndis.dat 1 16 2.5399 17.565 2 -0.1396 0 2.99817 -3.99756 0 -0.1047 0 -1 0 3-16ndis.dat 4 16 7.1569 21.6835 2 5.2565 15.9384 2 5.3985 13.4628 2 14.7 25.4604 2 3 16 7.7136 25.6445 2 7.1569 21.6835 2 14.7 25.4604 2 3 16 0 29.4 2 0 26.5 2 4.7428 26.062 2 4 16 4.7428 26.062 2 7.7136 25.6445 2 14.7 25.4604 2 0 29.4 2 4 16 2.4003 13.5675 2 0 13.401 2 0 8 2 4.0286 6.9778 2 3 16 5.3985 13.4628 2 2.4003 13.5675 2 4.0286 6.9778 2 3 16 5.3985 13.4628 2 4.0286 6.9778 2 14.7 25.4604 2 0 BFC INVERTNEXT 1 16 4.1861 22.101 -2 0.55669 0 2.9708 3.96107 0 -0.41752 0 4 0 1-4cylo.dat 0 BFC INVERTNEXT 1 16 2.5399 17.565 -2 -0.1396 0 2.99817 -3.99756 0 -0.1047 0 4 0 3-16cylo.dat 2 24 4.7428 26.062 -2 0 26.5 -2 2 24 0 13.401 -2 2.4003 13.5675 -2 2 24 0 13.401 2 2.4003 13.5675 2 2 24 4.7428 26.062 2 0 26.5 2 2 24 5.2565 15.9384 -2 7.1569 21.6835 -2 2 24 5.2565 15.9384 2 7.1569 21.6835 2 4 16 7.1569 21.6835 -2 5.2565 15.9384 -2 5.2565 15.9384 2 7.1569 21.6835 2 4 16 0 26.5 -2 4.7428 26.062 -2 4.7428 26.062 2 0 26.5 2 4 16 2.4003 13.5675 -2 0 13.401 -2 0 13.401 2 2.4003 13.5675 2 5 24 0 26.5 2 0 26.5 -2 4.7428 26.062 -2 -4.7428 26.062 -2 5 24 0 13.401 -2 0 13.401 2 -2.4003 13.5675 2 2.4003 13.5675 2
Awaiting Admin Review (CCN) Awaiting Admin Review (CCN)
User Vote
Cheenzo Certify
WUIt Certify
2024-03-13 19:12:56
Orion Pobursky [OrionP]
2024-03-23 00:59:44
Update ring primitives via script. This will not reset the vote status of the part.
Rene Rechthaler [Blechtaler]
made the following comment.
2025-06-26 10:30:46
should this be a quarter ringwise, but only half front/rear? (quarters would avoid some rotating artifacts)
anything which can be reused in the 110638 (the wide variant)?
posted a vote of Hold.
2025-06-26 10:36:37
both inside cylos miss complementary condlines to the spoke
2025-06-26 11:47:23
Concave complementary condlines are useless. Cylo condlines is enough to trigger LDview smoothing, and the condline itself is never visible in concave configuration.
2025-06-28 14:49:26
"anything which can be reused in the 110638 (the wide variant)?"
Yes. 110638 and patterned versions were not available when I made this one, I'll update!
2025-07-01 08:45:08
Modified to account for patterned and wide versions
2025-07-01 10:05:23
Still missing the complementary condlines
2025-07-01 13:07:35
See above!!! they are useless here !!!
Vincent Messenet [Cheenzo]
posted a vote of Certify.
2025-07-25 21:57:04
2025-08-02 19:12:17
bump!
Peter Blomberg [WUIt]
2025-11-19 10:18:31
2025-11-19 14:54:29
Réné, would you please revise your hold vote?
cancelled their vote.
2025-11-19 20:40:27
