Unofficial File parts/4266d02.dat
Part Attributes: Base Part: 4266.dat
Wheel Rim 20 x 30 Smooth with 6 Pinholes with Yellow Triangular Arrow Sticker
0 Wheel Rim 20 x 30 Smooth with 6 Pinholes with Yellow Triangular Arrow Sticker 0 Name: 4266d02.dat 0 Author: Takeshi Takahashi [RainbowDolphin] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Sticker Shortcut 0 !KEYWORDS Bricklink 4266pb02, Engine, helicopter, Set 8856, Technic 0 !KEYWORDS Whirlwind rescue
1 16 0 0 0 1 0 0 0 1 0 0 0 1 4266.dat 1 16 38 0 4 0 -1 0 0 0 1 -1 0 0 164525bc01.dat
Not releaseable Errors Found (HN) Errors Found (HN)
User Vote
KnightOfTarenta Hold
2024-09-12 13:08:52
posted a vote of Hold
2025-03-25 23:51:12
*current edge offset is 2 LDU, typically this should be 1 LDU
*I am not entirely sure this is meant to be symmetrical to the xz-plane of the model. It looks like it is turned 10-20 degree upwards
made the following comment.
2025-03-25 23:55:30
Maybe ignore the comment about the turning, this would require a mirrored version, likely not worth it.
