Unofficial File parts/s/81911s03.dat
~Windscreen  2 x  4 x  1 Curved - Patternable Area - Half
0 ~Windscreen  2 x  4 x  1 Curved - Patternable Area - Half
0 Name: s\81911s03.dat
1 16 0 -24 44 .54386 0 4.13102 0 19.2 0 -4.13102 -24 .54386 48\5-48con12.dat
4 16 7.07018 -24 -9.70326 0 -24 -10.167 0 -5.768 -29 3.5 -5.546 -29
4 16 3.5 -5.546 -29 4.23 -4.8 -29.723 6.52632 -4.8 -29.57224 7.07018 -24 -9.70326
4 16 40 -24 7.632 38.30403 -24 5.69616 35.35756 -4.8 -15.35739 40.002 -4.8 -10.062
5 24 0 -24 -10.167 0 -5.768 -29 7.07018 -24 -9.70326 -7.07 -24 -9.703
5 24 6.52632 -4.8 -29.57224 7.07018 -24 -9.70326 3.5 -5.546 -29 12.939 -4.8 -28.294
5 24 35.35756 -4.8 -15.35739 38.30403 -24 5.69616 30.438 -4.8 -19.666 40.002 -4.8 -10.062
Certify
Vincent Messenet [Cheenzo]
Willy Tschager [Holly-Wood]
2024-10-11 20:46:53
Rearranged subs and geometry
Gerald Lasser [GeraldLasser]
posted a vote of Certify
2024-10-12 08:51:27
posted a vote of Hold
2024-10-12 09:21:19
Due to the rotated prim there is some gap between the slanted front surface ant the top ring prim.
but there is also a small gap in the front surface itself.
those vertices:
0 !LPE VERTEX 7.069 -24 -9.701
0 !LPE VERTEX 7.07 -24 -9.703
should be merged to
0 !LPE VERTEX 7.07018 -24 -9.70326
As well at the bottom
0 !LPE VERTEX 6.526 -4.8 -29.572
to
0 !LPE VERTEX 6.52632 -4.8 -29.57224
to have a gapless font surface
2024-10-12 10:53:09
Merged vertices
made the following comment.
2024-10-12 12:54:13
If you have 5 decimals on the sloping cylinder, you also need to have at least one more, 6 on the connecting vertices.
If not, you will still have unmatched vertices.
2025-10-26 16:28:30
Closed micro gap
2026-03-04 08:04:29
2026-04-26 20:13:53
cancelled their vote.
2026-04-26 20:13:59
