Unofficial File parts/4526.dat
View official version of part
Technic Beam 13 x  3 with Two Open Areas  5 x  1
0 Technic Beam 13 x 3 with Two Open Areas 5 x 1 0 Name: 4526.dat 0 Author: Jeff Jones [notmaster] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2024-07-27 [notmaster] modified from 67491.dat 0 !HISTORY 2024-10-27 [OrionP] Official Update 2024-09 0 !HISTORY 2024-11-01 [Blechtaler] fixed the small offset
1 16 20 0 120 1 0 0 0 1 0 0 0 1 s\39790s02.dat 1 16 -20 0 120 -1 0 0 0 1 0 0 0 1 s\39790s02.dat 1 16 0 0 130 1 0 0 0 0 1 0 -1 0 peghole.dat 1 16 0 0 110 1 0 0 0 0 -1 0 1 0 peghole5.dat 0 BFC INVERTNEXT 1 16 0 0 128 6 0 0 0 0 6 0 -16 0 4-4cyli.dat 1 16 20 0 80 1 0 0 0 1 0 0 0 1 s\39790s01.dat 1 16 20 0 40 1 0 0 0 1 0 0 0 -1 s\39790s01.dat 1 16 -20 0 40 -1 0 0 0 1 0 0 0 -1 s\39790s01.dat 1 16 -20 0 80 -1 0 0 0 1 0 0 0 1 s\39790s01.dat 1 16 30 0 60 0 -1 0 1 0 0 0 0 1 peghole.dat 1 16 10 0 60 0 1 0 0 0 -1 1 0 0 peghole5.dat 0 BFC INVERTNEXT 1 16 28 0 60 0 -16 0 6 0 0 0 0 6 4-4cyli.dat 1 16 -30 0 60 0 1 0 1 0 0 0 0 1 peghole.dat 1 16 -10 0 60 0 -1 0 0 0 -1 1 0 0 peghole5.dat 0 BFC INVERTNEXT 1 16 -28 0 60 0 16 0 6 0 0 0 0 6 4-4cyli.dat 1 16 20 0 0 1 0 0 0 1 0 0 0 1 s\67491s01.dat 1 16 20 0 0 1 0 0 0 1 0 0 0 -1 s\67491s01.dat 1 16 20 0 0 -1 0 0 0 1 0 0 0 1 connhole.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 connhole.dat 1 16 -20 0 0 -1 0 0 0 1 0 0 0 1 s\67491s01.dat 1 16 -20 0 0 -1 0 0 0 1 0 0 0 -1 s\67491s01.dat 1 16 -20 0 0 1 0 0 0 1 0 0 0 1 connhole.dat 1 16 20 0 -40 1 0 0 0 1 0 0 0 1 s\39790s01.dat 1 16 20 0 -80 1 0 0 0 1 0 0 0 -1 s\39790s01.dat 1 16 -20 0 -80 -1 0 0 0 1 0 0 0 -1 s\39790s01.dat 1 16 -20 0 -40 -1 0 0 0 1 0 0 0 1 s\39790s01.dat 1 16 30 0 -60 0 -1 0 -1 0 0 0 0 1 peghole.dat 1 16 10 0 -60 0 1 0 0 0 -1 1 0 0 peghole5.dat 0 BFC INVERTNEXT 1 16 28 0 -60 0 -16 0 6 0 0 0 0 6 4-4cyli.dat 1 16 -30 0 -60 0 1 0 -1 0 0 0 0 -1 peghole.dat 1 16 -10 0 -60 0 -1 0 0 0 -1 1 0 0 peghole5.dat 0 BFC INVERTNEXT 1 16 -28 0 -60 0 16 0 6 0 0 0 0 6 4-4cyli.dat 1 16 20 0 -120 1 0 0 0 1 0 0 0 -1 s\39790s02.dat 1 16 -20 0 -120 -1 0 0 0 1 0 0 0 -1 s\39790s02.dat 1 16 0 0 -130 0 0 -1 -1 0 0 0 1 0 peghole.dat 1 16 0 0 -110 -1 0 0 0 0 -1 0 -1 0 peghole5.dat 0 BFC INVERTNEXT 1 16 0 0 -128 6 0 0 0 0 6 0 16 0 4-4cyli.dat
Certified (ACCF) Certified (ACCF)
User Vote
OrionP Admin Review
Philo Certify
WUIt Certify
Rene Rechthaler [Blechtaler]
2024-11-01 11:22:37
Part Author
made the following comment.
2024-11-01 13:10:06
cool
how me do vote
2024-11-01 13:10:56
you cant vote yet (and technically its still your part)
Part Author
2024-11-01 13:22:18
oh but i can hold vote wanna see it
Orion Pobursky [OrionP]
2024-11-01 14:43:50
What was the "small offset"
2024-11-01 15:19:29
about .34 LDU (now everything aligns with the grid)
2024-11-01 15:27:15
For the whole part? If so, we need to "moved to" this.
2024-11-01 15:33:27
hm, was in the last update, its quite recent
(why didnt we notice that earlier?)
Stephan den Ridder found it:
https://forums.ldraw.org/thread-28481.html
2024-11-01 16:23:50
Official parts require a "Moved to" to adjust the origin
2024-11-01 16:30:12
2024-11-01 16:31:05
Make sure I didn't screw up the adjustment
posted a vote of Hold.
2025-01-12 12:46:31
i think just an offset for the whole part isnt enough, the offset is different for some things...
1 16 20 0 120.34 1 0 0 0 1 0 0 0 1 s\39790s02.dat
1 16 -20 0 120.34 -1 0 0 0 1 0 0 0 1 s\39790s02.dat
1 16 20 0 -119.4 1 0 0 0 1 0 0 0 -1 s\39790s02.dat
1 16 -20 0 -119.4 -1 0 0 0 1 0 0 0 -1 s\39790s02.dat
we have to fix the whole part
(all z values have to be whole numbers, everything on grid)
2025-01-12 12:47:15
should I reupoad my fixed one?
2025-01-12 14:19:23
We can not fix this file. The fix has to be placed in a new file.
Question is, Should this be obsoleted instead, due to bad geometry?
The Move to will only handle ~75% of the incorrect pin holes.
2025-01-12 14:39:27
then this one should get obsoleted, the fixed a version is in grid.
2025-02-03 22:53:24
if obsoleted due to bad geometry, should it be empty then? or the original code back? or the link to the fix?
2025-02-03 23:03:12
The original code, including header data, restored in this file. 4526a should get the corrected code and new header data.
2025-02-03 23:35:37
like this? with ~ and (Obsolete)
2025-02-03 23:55:35
Yup
2025-02-04 16:24:54
Restoring the moved to.
2025-02-04 16:51:11
From Magnus:
All of the file was 0.34 ldu off, but part of the designs was further offset by another 0.06 ldu.
Thus making it impossible to fix with a simple Move to. It has to be Obsoleted.
2025-02-04 16:52:54
2025-10-11 21:09:22
is this now the old code back? ready to cert even if wrong?
Philippe Hurbain [Philo]
2025-11-05 13:09:39
I still think it's a fix of a buggy part, without significant difference between versions. Introducing a B version just adds to the mess.
2025-11-05 16:51:33
In the ensuing time since February, I've changed my mind. The change is so small (~.1mm) that it would virtually undetectable, even in models that use it. The only people at that level of pedantry to notice is us.
2025-11-05 17:07:33
who should change that? should I revert it back to my old first time fix?
(should we then also delete the other one?)
2025-11-05 19:29:05
Current code in 4526b looks fine to me, should be ported here and current 4526b be deleted.
2025-11-05 20:14:35
like this? (should now be like my original fix)
the b can then get deleted
Peter Blomberg [WUIt]
posted a vote of Certify.
2025-11-05 22:31:40
2025-11-06 12:44:11
posted a vote of Admin Review.
2025-11-06 16:05:22
This part is copyright © Jeff Jones
LDraw.org Parts Tracker, Orion Pobursky, Rene Rechthaler,
