Unofficial File parts/6009177a.dat
Sticker  0.8 x  1.8 with Three Metallic Silver Circles on Black Oval and Yellow Background
0 Sticker  0.8 x  1.8 with Three Metallic Silver Circles on Black Oval and Yellow Background
0 Name: 6009177a.dat
0 !CATEGORY Sticker
0 !KEYWORDS BrickLink 30194stk01, Brickowl 43887, Rebrickable 10977
0 // 0 !KEYWORDS Bricklink 30194stk01, Brickowl 43887, Rebrickable 10977
0 // 0 !KEYWORDS 458 Italia Polybag, Set 30194, Racers
0 // Sticker-Bottom
1 16 17.0 0 -7.0 1 0 0 0 -1 0 0 0 -1 1-4chrd.dat
1 16 17.0 0 7.0 1 0 0 0 -1 0 0 0 1 1-4chrd.dat
1 16 -17.0 0 -7.0 -1 0 0 0 -1 0 0 0 -1 1-4chrd.dat
1 16 -17.0 0 7.0 -1 0 0 0 -1 0 0 0 1 1-4chrd.dat
4 16 18.0 0 7.0 18.0 0 -7.0 17.0 0 -8.0 17.0 0 8.0
4 16 -18.0 0 7.0 -17.0 0 8.0 -17.0 0 -8.0 -18.0 0 -7.0
4 16 17.0 0 8.0 17.0 0 -8.0 -17.0 0 -8.0 -17.0 0 8.0
0 // Sticker-Side
1 16 17.0 -0.25 -7.0 1 0 0 0 0.25 0 0 0 -1 1-4cyli.dat
1 16 17.0 -0.25 7.0 1 0 0 0 0.25 0 0 0 1 1-4cyli.dat
1 16 -17.0 -0.25 -7.0 -1 0 0 0 0.25 0 0 0 -1 1-4cyli.dat
1 16 -17.0 -0.25 7.0 -1 0 0 0 0.25 0 0 0 1 1-4cyli.dat
4 16 18 0 7 18 -.25 7 18 -.25 -7 18 0 -7
4 16 -18 0 7 -18 0 -7 -18 -.25 -7 -18 -.25 7
4 16 -17 0 8 -17 -.25 8 17 -.25 8 17 0 8
4 16 -17 0 -8 17 0 -8 17 -.25 -8 -17 -.25 -8
0 // Sticker-Front
1 0 -8.25 -.25 0 3 0 0 0 1 0 0 0 3 4-4disc.dat
1 0 8.25 -.25 0 3 0 0 0 1 0 0 0 3 4-4disc.dat
1 0 0 -.25 0 3 0 0 0 1 0 0 0 3 4-4disc.dat
1 0 8.25 -.25 0 0 0 -3.75 0 1 0 3.75 0 0 2-4ndis.dat
1 0 0 -.25 0 3.75 0 0 0 1 0 0 0 3.75 4-4ndis.dat
1 0 -8.25 -.25 0 0 0 -1.25 0 1 0 1.25 0 0 2-4ring3.dat
1 0 8.25 -.25 0 0 0 1.25 0 1 0 -1.25 0 0 2-4ring3.dat
1 0 -8.25 -.25 0 0 0 3.75 0 1 0 -3.75 0 0 2-4ndis.dat
1 14 -8.25 -.25 0 0 0 -5 0 1 0 5 0 0 2-4ndis.dat
1 14 8.25 -.25 0 0 0 5 0 1 0 -5 0 0 2-4ndis.dat
1 14 17 -.25 7 1 0 0 0 1 0 0 0 1 1-4chrd.dat
1 14 17 -.25 -7 1 0 0 0 1 0 0 0 -1 1-4chrd.dat
1 14 -17 -.25 -7 -1 0 0 0 1 0 0 0 -1 1-4chrd.dat
1 14 -17 -.25 7 -1 0 0 0 1 0 0 0 1 1-4chrd.dat
1 80 -8.25 -.25 0 .75 0 0 0 1 0 0 0 .75 4-4ring4.dat
1 80 0 -.25 0 .75 0 0 0 1 0 0 0 .75 4-4ring4.dat
1 80 8.25 -.25 0 .75 0 0 0 1 0 0 0 .75 4-4ring4.dat
4 0 -3.75 -.25 3.75 -4.5 -.25 3.75 -4.5 -.25 0 -3.75 -.25 0
4 0 4.5 -.25 3.75 3.75 -.25 3.75 3.75 -.25 0 4.5 -.25 0
4 0 4.5 -.25 0 3.75 -.25 0 3.75 -.25 -3.75 4.5 -.25 -3.75
4 0 8.25 -.25 5 -8.25 -.25 5 0 -.25 3.75 3.75 -.25 3.75
3 0 8.25 -.25 5 3.75 -.25 3.75 4.5 -.25 3.75
3 0 8.25 -.25 5 4.5 -.25 3.75 8.25 -.25 3.75
3 0 -8.25 -.25 5 -8.25 -.25 3.75 -4.5 -.25 3.75
3 0 -8.25 -.25 5 -4.5 -.25 3.75 -3.75 -.25 3.75
3 0 -8.25 -.25 5 -3.75 -.25 3.75 0 -.25 3.75
4 0 0 -.25 -3.75 -8.25 -.25 -5 8.25 -.25 -5 3.75 -.25 -3.75
3 0 4.5 -.25 -3.75 3.75 -.25 -3.75 8.25 -.25 -5
3 0 8.25 -.25 -3.75 4.5 -.25 -3.75 8.25 -.25 -5
3 0 0 -.25 -3.75 -3.75 -.25 -3.75 -8.25 -.25 -5
3 0 -3.75 -.25 -3.75 -4.5 -.25 -3.75 -8.25 -.25 -5
3 0 -8.25 -.25 -3.75 -8.25 -.25 -5 -4.5 -.25 -3.75
4 0 -3.75 -.25 0 -4.5 -.25 0 -4.5 -.25 -3.75 -3.75 -.25 -3.75
4 14 13.25 -.25 -5 17 -.25 -8 18 -.25 -7 18 -.25 7
3 14 -18 -.25 7 -18 -.25 -7 -13.25 -.25 -5
3 14 13.25 -.25 0 13.25 -.25 -5 18 -.25 7
4 14 18 -.25 7 17 -.25 8 13.25 -.25 5 13.25 -.25 0
3 14 -13.25 -.25 -5 -13.25 -.25 0 -18 -.25 7
4 14 -13.25 -.25 0 -13.25 -.25 5 -17 -.25 8 -18 -.25 7
4 14 -13.25 -.25 -5 -18 -.25 -7 -17 -.25 -8 -8.25 -.25 -5
4 14 8.25 -.25 -5 -8.25 -.25 -5 -17 -.25 -8 17 -.25 -8
3 14 13.25 -.25 -5 8.25 -.25 -5 17 -.25 -8
4 14 -17 -.25 8 -8.25 -.25 5 8.25 -.25 5 17 -.25 8
3 14 8.25 -.25 5 13.25 -.25 5 17 -.25 8
3 14 -17 -.25 8 -13.25 -.25 5 -8.25 -.25 5
  • Numbers cannot have trailing zeros (except one zero immediately after a decimal point)
    Line 16: 1 16 17.0 0 -7.0 1 0 0 0 -1 0 0 0 -1 1-4chrd.dat
    Line 17: 1 16 17.0 0 7.0 1 0 0 0 -1 0 0 0 1 1-4chrd.dat
    Line 18: 1 16 -17.0 0 -7.0 -1 0 0 0 -1 0 0 0 -1 1-4chrd.dat
    Line 19: 1 16 -17.0 0 7.0 -1 0 0 0 -1 0 0 0 1 1-4chrd.dat
    Line 20: 4 16 18.0 0 7.0 18.0 0 -7.0 17.0 0 -8.0 17.0 0 8.0
    Line 21: 4 16 -18.0 0 7.0 -17.0 0 8.0 -17.0 0 -8.0 -18.0 0 -7.0
    Line 22: 4 16 17.0 0 8.0 17.0 0 -8.0 -17.0 0 -8.0 -17.0 0 8.0
    Line 25: 1 16 17.0 -0.25 -7.0 1 0 0 0 0.25 0 0 0 -1 1-4cyli.dat
    Line 26: 1 16 17.0 -0.25 7.0 1 0 0 0 0.25 0 0 0 1 1-4cyli.dat
    Line 27: 1 16 -17.0 -0.25 -7.0 -1 0 0 0 0.25 0 0 0 -1 1-4cyli.dat
    Line 28: 1 16 -17.0 -0.25 7.0 -1 0 0 0 0.25 0 0 0 1 1-4cyli.dat
    Line :
Part Reviewer
2024-11-13 19:29:23
Rene Rechthaler [Blechtaler]
posted a vote of Hold
2024-11-13 20:04:08
all outer rim faces are inverted
mirror silver (383)? what should be used here?
if you are using prims for the inside and outside of the round things, consider the "rings and cones" finder in LDPE, (finds something like that:
1 80 0 -.25 0 .6 0 0 0 1 0 0 0 .6 4-4ring5.dat
1 80 0 -.25 0 .2 0 0 0 1 0 0 0 .2 4-4ring18.dat
1 0 8.25 -.25 0 0 0 .95 0 1 0 .95 0 0 2-4ring4.dat
1 0 8.25 -.25 0 0 0 .25 0 1 0 .25 0 0 2-4ring19.dat
or change the inner ring size from 3.8 to 3.75 or 4, then its even easier with ring prims)
Part Reviewer
2024-11-13 20:46:34
Corrected outer rims. Changed color from 383 to 80. Have used ring-and-cones for sticker sheet 6083353 before but decied against to use it here for no specific reason. Will use it in the future. But can also change it here if necessary.
edited the part header.
2024-11-13 21:21:47
Header Edits
keywords:
to
description:
Sticker 0.8 x 1.8 with three Metallic Silver Circles on Black Oval and Yellow Background
to
made the following comment.
2024-11-13 21:56:55
mixing that will create gaps/overlaps on prim substitution...
2024-11-13 22:04:36
Yes, mixing curved primitives and quads like this is not good.
2024-11-13 22:09:35
reducing the outer dimension of the ring from 3.8 to 3.75 would allow to use a .75 ring4 (silver) and a 1.25 ring3 (black)
2024-12-26 09:59:15
I agree with Rene and Magnus's comments.
Or, ering and tang prims will work if you don't like to change the dimensions.
I'm not sure if this meets "hold" criteria.
Part Reviewer
2024-12-29 20:39:47
Used more prims. Hopefully better now.
posted a vote of Certify
2024-12-29 21:12:33
much better.
2024-12-30 17:58:27
Please don't use the obsoleted rin-primitives.
This would remove a few vertices:
1 12 8.25 -.25 0 0 0 3.8 0 1 0 -3.8 0 0 1-8tndis.dat
1 12 8.25 -.25 0 0 0 5 0 1 0 -5 0 0 1-8chrd.dat
3 12 8.25 -.25 -5 11.7855 -.25 -3.5355 10.93698 -.25 -3.8
3 12 8.25 -.25 -5 10.93698 -.25 -3.8 8.25 -.25 -3.8
3 12 10.93698 -.25 -3.8 11.7855 -.25 -3.5355 10.93698 -.25 -2.68698
1 11 8.25 -.25 0 0 0 3 0 1 0 -3 0 0 1-8tang.dat
1 11 8.25 -.25 0 0 0 3.8 0 1 0 -3.8 0 0 1-8chrd.dat
3 11 8.25 -.25 -3 8.25 -.25 -3.8 8.8467 -.25 -3
3 11 8.8467 -.25 -3 8.25 -.25 -3.8 9.3981 -.25 -2.7717
3 11 9.3981 -.25 -2.7717 8.25 -.25 -3.8 10.93698 -.25 -2.68698
3 11 9.3981 -.25 -2.7717 10.93698 -.25 -2.68698 9.9495 -.25 -2.5434
3 11 9.9495 -.25 -2.5434 10.93698 -.25 -2.68698 10.3713 -.25 -2.1213
... but I think Rene's idea of reducing the ring to 3.75 is better.
Part Reviewer
2024-12-30 22:14:29
Changed to .75 ring4 (silver) and a 1.25 ring3 (black).
2024-12-30 22:19:35
has some t-junk now (but that is not critical)
Part Reviewer
2024-12-30 22:36:12
Number of t-junctions reduced.
2026-01-18 11:37:12
stickerback? https://library.ldraw.org/parts/46836
7.0 and 17.0 cause errors (but all of them are in stickerback section)
