Unofficial File parts/28621p0f.dat
Part Attributes: Base Part: 28621.dat
Minifig Head with Black Skull Type 1 (Smiling) (Vented Stud) Pattern
0 Minifig Head with Black Skull Type 1 (Smiling) (Vented Stud) Pattern 0 Name: 28621p0f.dat 0 Author: Jeff Jones [notmaster] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS BrickLink 3626pb3417, Brickowl 981218, Brickset 103937, CMF 0 !KEYWORDS Dungeons and Dragons, Rebrickable 28621pr4094, Set 71047-11
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\28621s01.dat 1 16 0 4 0 0 0 8 0 -6.4 0 8 0 0 t04o6250.dat 1 16 0 4 0 8 0 0 0 -6.4 0 0 0 -8 t04o6250.dat 1 16 0 4 0 0 0 -8 0 -6.4 0 8 0 0 t04o6250.dat 1 16 0 4 0 -8 0 0 0 -6.4 0 0 0 -8 t04o6250.dat 1 16 0 17 0 8 0 0 0 6.4 0 0 0 -8 t08o6250.dat 1 16 0 17 0 8 0 0 0 6.4 0 0 0 8 t04o6250.dat 1 16 0 4 0 0 0 13 0 13 0 13 0 0 3-8cyli.dat 1 16 0 4 0 0 0 -13 0 13 0 13 0 0 3-8cyli.dat 1 16 0 17 0 -8 0 0 0 6.4 0 0 0 -8 t08o6250.dat 1 16 0 17 0 -8 0 0 0 6.4 0 0 0 8 t04o6250.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\28621p0es02.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\28621p0es02.dat 1 0 0 0 0 1 0 0 0 1 0 0 0 1 s\28621p0es01.dat 1 0 0 0 0 -1 0 0 0 1 0 0 0 1 s\28621p0es01.dat 5 24 0 17 -13 0 4 -13 -4.9752 4 -12.0104 4.9751 4 -12.0107 5 24 0 18.5309 -12.6192 0 17 -13 4.9751 17 -12.0107 -4.9752 17 -12.0104 5 24 0 18.5309 -12.6192 0 19.8282 -11.5352 4.4144 19.8282 -10.6576 -4.4144 19.8282 -10.6576 5 24 0 19.8282 -11.5352 0 20.6954 -9.9136 3.7936 20.6954 -9.1592 -3.7936 20.6954 -9.1592 5 24 0 20.6954 -9.9136 0 21 -8 3.7936 20.6954 -9.1592 -3.7936 20.6954 -9.1592
Not releaseable Errors Found (HHN) Errors Found (HHN)
  • Ensure correct Minifig category
User Vote
Philo Hold
KnightOfTarenta Hold
2024-11-14 10:20:30
Philippe Hurbain [Philo]
posted a vote of Hold.
2026-01-21 16:02:36
Skull should be DBG, not black. Set KW are wrong
edited the part header.
2026-01-23 16:10:47
Header Edits
keywords:
BrickLink 3626pb3417, CMF, Dnd, Dungeons and Dragons, Rebrickable 28621pr4094, Set 71047
to
CMF, Dungeons and Dragons, Set 71047-11, BrickLink 3626pb3417, Rebrickable 28621pr4094
Comment:
Corrected KW
made the following comment.
2026-01-23 16:15:55
Skull is indeed black on this one, but RB keyword is wrong (and I couldn't correct, should be 28621pr0895).
Still holding because it should have a NOCLIP on skull pattern.
2026-01-23 16:47:34
2026-04-15 22:15:00
I don't think this (nor the 3626c counterpart) should use the old Castle Pattern from 1995.
The print was updated slightly (even recognized in LDD) sometime around 2012-2014 (the Hobbit sets probably being the first to use the modern variant). 3626c and this vented variant came out after that.
This part is copyright © Jeff Jones
