Unofficial File parts/2566.dat
View official version of part
~Plant Tree Palm Top (Obsolete)
0 ~Plant Tree Palm Top (Obsolete) 0 Name: 2566.dat 0 Author: Tore Eriksson [Tore_Eriksson] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Obsolete 0 !HISTORY 1998-07-15 [PTadmin] Official Update 1998-07 0 !HISTORY 1999-03-26 [PTadmin] Official Update 1999-02 0 !HISTORY 1999-05-17 [PTadmin] Official Update 1999-03 0 !HISTORY 1999-05-24 [PTadmin] Official Update 1999-04 0 !HISTORY 2003-08-10 [technog] BFC'd, corrected l3p errors, general cleanup 0 !HISTORY 2003-12-19 [PTadmin] Official Update 2003-03 0 !HISTORY 2007-05-17 [PTadmin] Header formatted for Contributor Agreement 0 !HISTORY 2008-07-01 [PTadmin] Official Update 2008-01 0 !HISTORY 2008-07-07 [DeannaEarley] Removed erroneous BFC CERTIFY entry (2005-08-29) 0 !HISTORY 2009-05-02 [PTadmin] Official Update 2009-01 0 !HISTORY 2020-06-04 [Sirio] Updated the use of primitives: removed ringr.dat or ringrr.dat 0 !HISTORY 2021-10-08 [MMR1988] Reworked due to bleed-ins and misplaced edges. 0 !HISTORY 2022-07-18 [PTadmin] Official Update 2022-04 0 !HISTORY 2025-01-27 [notmaster] Obsoleted due to bad geometry
1 16 0 0 0 1 0 0 0 1 0 0 0 1 stud2a.dat 1 16 0 0 0 6 0 0 0 1 0 0 0 6 4-4edge.dat 1 16 0 8 0 4 0 0 0 -1 0 0 0 4 4-4edge.dat 1 16 0 8 0 4 0 0 0 1 0 0 0 4 4-4disc.dat 0 BFC INVERTNEXT 1 16 0 8 0 4 0 0 0 -8 0 0 0 4 4-4cyli.dat 1 16 0 24 0 1 0 0 0 -4 0 0 0 1 stud3.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\2566s01.dat 1 16 0 0 0 0 0 -1 0 1 0 1 0 0 s\2566s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\2566s01.dat 1 16 0 0 0 0 0 1 0 1 0 -1 0 0 s\2566s01.dat
Certified (ACCF) Certified (ACCF)
User Vote
OrionP Admin Review
MagFors Certify
WUIt Certify
None
Jeff Jones [notmaster]
Part Author
2024-12-14 08:38:05
Philippe Hurbain [Philo]
posted a vote of Hold.
2024-12-14 08:58:50
Missing condlines between quarters.
(also needs to be renamed 2566b)
2024-12-14 14:57:43
Yes, your new version has to be uploaded as 2566b.dat, using subfile s\2566bs01.dat
The old version should be reuploaded containing the old bad mesh, and only adding the word (Obsolete) and a History comment about why it is made obsolete.
Part Author
made the following comment.
2024-12-14 15:19:11
why cant it be just a fix of 2566.dat?
2024-12-14 15:32:18
Because there is a change in the geometry.
Any model using the old part/geometry will be affected by the redesign, and parts might be out of position.
We also need to figure out how this change will affect official assy 2518c01. Will it too have to be made obsolete?
2024-12-26 18:50:37
Could you please correct this?
Part Author
2024-12-26 19:42:46
ok
2025-01-25 15:27:00
Bump
2025-01-25 15:47:55
Regarding 2518c01:
Actually, that shortcut has an overlap due to the bad geometry. The bottom of the old 2566 cuts into the top most palm tree segment.
Part Author
2025-01-25 16:01:57
nice i got a ability to cancel vote
2025-01-27 17:08:02
@ Jeff
Do you need help with this?
Part Author
2025-01-27 17:23:03
ok
move this and subfile to 2566b and i would upload the obsolete version
2025-01-27 17:32:12
Not possible, since the old history, and author, belong in the old obsolete files.
Part Author
2025-01-27 17:42:17
how about i upload the 2566b a admin deletes this and i upload the obsolete version
2025-01-27 18:09:19
All you need to do, is to upload both your new design, as 2566b + bs01.
And then upload a un-edited version of 2566 + s01, only adding one history line about why it is obsoleted.
Part Author
2025-01-27 18:24:39
2025-02-24 18:41:08
Where did the new version go?
Part Author
2025-05-08 12:30:40
tested it 2566b doesnt seem to affect 2518c01.dat
Part Author
2025-06-05 10:36:39
2566b now uploaded pls lift hold
cancelled their vote.
2025-06-06 07:12:59
posted a vote of Certify.
2025-06-06 07:13:06
Peter Blomberg [WUIt]
2025-07-29 21:06:10
Orion Pobursky [OrionP]
posted a vote of Admin Review.
2025-08-24 00:42:32
This part is copyright © Tore Eriksson
LDraw.org Parts Tracker, Donald Sutter, Deanna Earley, Massimo Maso, Max Martin Richter, Jeff Jones,
