Unofficial File parts/30144p01.dat
View official version of part
Part Attributes: Base Part: 30144.dat
Brick  2 x  4 x  3 with 4 White Stripes Pattern
0 Brick 2 x 4 x 3 with 4 White Stripes Pattern 0 Name: 30144p01.dat 0 Author: Steve Bliss [sbliss] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Brickowl 392618, Freestyle, Rebrickable 30144pr0009, Set 4139 0 !HISTORY 2001-12-05 [BrickCaster] Pattern added 0 !HISTORY 2003-06-28 [OrionP] Converted black lines to quads 0 !HISTORY 2003-06-29 [Steffen] BFCed 0 !HISTORY 2003-08-01 [PTadmin] Official Update 2003-02 0 !HISTORY 2007-06-06 [PTadmin] Header formatted for Contributor Agreement 0 !HISTORY 2008-07-01 [PTadmin] Official Update 2008-01 0 !HISTORY 2025-02-21 [KnightOfTarenta] Sub-filed, CCW, Added Border on Edges
0 // Base Part 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\30144s01.dat 0 // Back 4 16 -40 0 20 40 0 20 40 72 20 -40 72 20 0 // Pattern 0 // Colour 0 Black 4 0 -38.5 57 -20 -39.5 56 -20 -39.5 64 -20 -38.5 63 -20 4 0 39.5 64 -20 38.5 63 -20 -38.5 63 -20 -39.5 64 -20 4 0 39.5 64 -20 39.5 56 -20 38.5 57 -20 38.5 63 -20 4 0 -39.5 56 -20 -38.5 57 -20 38.5 57 -20 39.5 56 -20 4 0 -38.5 47 -20 -38.5 41 -20 -39.5 40 -20 -39.5 48 -20 4 0 -38.5 47 -20 -39.5 48 -20 39.5 48 -20 38.5 47 -20 4 0 39.5 40 -20 38.5 41 -20 38.5 47 -20 39.5 48 -20 4 0 -39.5 40 -20 -38.5 41 -20 38.5 41 -20 39.5 40 -20 4 0 -38.5 25 -20 -39.5 24 -20 -39.5 32 -20 -38.5 31 -20 4 0 39.5 32 -20 38.5 31 -20 -38.5 31 -20 -39.5 32 -20 4 0 39.5 24 -20 38.5 25 -20 38.5 31 -20 39.5 32 -20 4 0 -39.5 24 -20 -38.5 25 -20 38.5 25 -20 39.5 24 -20 4 0 -38.5 15 -20 -38.5 9 -20 -39.5 8 -20 -39.5 16 -20 4 0 39.5 16 -20 38.5 15 -20 -38.5 15 -20 -39.5 16 -20 4 0 39.5 16 -20 39.5 8 -20 38.5 9 -20 38.5 15 -20 4 0 -39.5 8 -20 -38.5 9 -20 38.5 9 -20 39.5 8 -20 0 // Colour 0 Black 4 15 38.5 63 -20 38.5 57 -20 -38.5 57 -20 -38.5 63 -20 4 15 -38.5 47 -20 38.5 47 -20 38.5 41 -20 -38.5 41 -20 4 15 -38.5 31 -20 38.5 31 -20 38.5 25 -20 -38.5 25 -20 4 15 -38.5 15 -20 38.5 15 -20 38.5 9 -20 -38.5 9 -20 0 // Colour 16 Main Colour 3 16 40 36 -20 39.5 40 -20 39.5 48 -20 3 16 39.5 56 -20 39.5 64 -20 40 72 -20 3 16 39.5 24 -20 39.5 32 -20 40 36 -20 3 16 39.5 16 -20 39.5 24 -20 40 36 -20 3 16 -40 36 -20 -39.5 48 -20 -39.5 40 -20 3 16 -39.5 24 -20 -40 36 -20 -39.5 32 -20 3 16 -40 0 -20 -39.5 16 -20 -39.5 8 -20 3 16 -40 36 -20 -39.5 56 -20 -39.5 48 -20 4 16 -39.5 32 -20 -40 36 -20 -39.5 40 -20 39.5 40 -20 4 16 39.5 32 -20 -39.5 32 -20 39.5 40 -20 40 36 -20 4 16 40 36 -20 39.5 48 -20 39.5 56 -20 40 72 -20 4 16 39.5 8 -20 39.5 16 -20 40 36 -20 40 0 -20 4 16 40 72 -20 39.5 64 -20 -39.5 64 -20 -40 72 -20 4 16 -40 72 -20 -39.5 64 -20 -39.5 56 -20 -40 36 -20 4 16 -40 36 -20 -39.5 24 -20 -39.5 16 -20 -40 0 -20 4 16 -39.5 16 -20 -39.5 24 -20 39.5 24 -20 39.5 16 -20 4 16 39.5 8 -20 40 0 -20 -40 0 -20 -39.5 8 -20 4 16 -39.5 48 -20 -39.5 56 -20 39.5 56 -20 39.5 48 -20
Awaiting Admin Review (CCF) Awaiting Admin Review (CCF)
User Vote
Blechtaler Certify
WUIt Certify
2025-02-21 00:06:05
Rene Rechthaler [Blechtaler]
made the following comment.
2025-02-21 00:41:40
i think thats one of the cases where we can place vertexes on a line to avoid too long triangles
(for example place one in the center of the sides)
2025-06-14 19:26:13
Added 1 vertex each side
Orion Pobursky [OrionP]
posted a vote of Hold.
2025-08-06 16:41:01
There no way I'm the author of this part, it's too old. I checked the 2003-02 update zip and I'm listed there too so it's not a PT bug. I'll have to pull the archived comments to see what's up.
2025-08-06 22:02:13
Weird.
The very similar 30145 version was made by James Jessiman. It was a bit strange though, that both parts originally used different dimensions for the stripes (which does suggest two different authors).
2025-08-06 22:21:14
Does this help?
https://web.archive.org/web/20020816153238/http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/30144p01.dat
If I get it right, Steve Bliss was the original author.
2025-08-06 22:30:00
Seems not to be the case. Steve Bliss only authored the unprinted version.
0 Brick 2 x 4 x 3 with White Stripes Pattern
0 Name: 30144p01.DAT
0 Author: James Jessiman (as 3001.dat), modified by Steve Bliss
0 2001-Dec-05 DG Pattern added
0 Unofficial Part
Was it possible to submit part anonymously back in 2001?
Date: 2001-12-05 22:10
Action: submit
Part: parts/30144p01.dat
Other Information: Brick 2 x 4 x 3 with White Stripes Pattern
2025-08-06 23:36:03
This was part of the initial PT load by Steve. There's no post on LUGNET about it. A can only assume this was authored by Steve.
Here's my submit comment:
At Sat Jun 28 17:00:01 2003, a new version of the file was submitted.
Submitted by: OrionP
Comments:
Added black outlines
2025-08-06 23:37:16
Actually, the author is probably BrickCaster.
2025-08-06 23:39:22
I'm gonna stick with Steve.
2025-08-06 23:40:17
Changed author to Steve Bliss. Added a history line for my changes.
edited the part header.
2025-08-07 08:36:18
Header Edits
description:
to
2025-08-07 12:00:13
Wait, how did the author change to Chris?
2025-08-07 12:16:02
Maybe he was preselected in the dropdown when I added the "4" in the description?
2025-08-07 12:51:44
That box isn't setup to actually change anything. I'll have to do some testing to make sure there isn't an issue.
2025-08-07 13:22:24
Restore Steve as author.
2025-08-11 13:29:55
The front surface is bfc inverse. In fact, all of Chris's changes are gone.
2025-08-15 07:08:13
Shall I re-upload the version with changes (and new author/history lines) or will this mess up things further?
2025-10-17 22:15:01
Hope this fixes things.
*re-uploaded old geometry content (that was removed by the editing bug)
*kept current file header
Peter Blomberg [WUIt]
posted a vote of Certify.
2025-11-20 12:52:45
2025-11-26 22:55:42
This part is copyright © Steve Bliss
LDraw.org Parts Tracker, Damien Guichard, Orion Pobursky, Steffen, Chris Böhnke,
