Unofficial File parts/5995.dat
Technic Beam 2L with Towball
0 Technic Beam 2L with Towball 0 Name: 5995.dat 0 Author: Gerald Lasser [GeraldLasser] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS suspension
1 16 0 0 20 0 -1 0 -1 0 0 0 0 -1 60483.dat 1 16 0 0 -20 0 0 -8 0 8 0 8 0 0 8-8sphe.dat 1 16 0 0 -20 0 0 -4 4 0 0 0 -4 0 4-4cyl1sph2.dat 1 16 0 0 -12 0 0 -4 4 0 0 0 3 0 4-4cyli.dat 1 16 0 0 -9 0 0 -4 4 0 0 0 1.0563 0 1-4cyls2.dat 1 16 0 0 -9 0 0 4 4 0 0 0 1.0563 0 1-4cyls2.dat 1 16 0 0 -9 0 0 -4 -4 0 0 0 1.0563 0 1-4cyls2.dat 1 16 0 0 -9 0 0 4 -4 0 0 0 1.0563 0 1-4cyls2.dat 2 24 -1.906823 3.4443 -8.3151 -2.8284 2.8284 -8.437572 2 24 -4 0 -9 -3.6956 1.5308 -8.6956 2 24 -2.8284 2.8284 -8.437572 -3.6956 1.5308 -8.6956 2 24 2.8284 2.8284 -8.437572 3.6956 1.5308 -8.6956 2 24 3.6956 1.5308 -8.6956 4 0 -9 2 24 1.906823 3.4443 -8.3151 2.8284 2.8284 -8.437572 2 24 -1.906823 3.4443 -8.3151 -1.5308 3.6956 -8.147154 2 24 0 4 -7.94372 -1.5308 3.6956 -8.147154 2 24 0 4 -7.94372 1.5308 3.6956 -8.147154 2 24 1.906823 3.4443 -8.3151 1.5308 3.6956 -8.147154 2 24 0 -4 -7.94372 -1.5308 -3.6956 -8.147154 2 24 -1.5308 -3.6956 -8.147154 -1.906823 -3.4443 -8.3151 2 24 1.5308 -3.6956 -8.147154 1.906823 -3.4443 -8.3151 2 24 1.5308 -3.6956 -8.147154 0 -4 -7.94372 2 24 -2.8284 -2.8284 -8.437572 -3.6956 -1.5308 -8.6956 2 24 -3.6956 -1.5308 -8.6956 -4 0 -9 2 24 -2.8284 -2.8284 -8.437572 -1.906823 -3.4443 -8.3151 2 24 2.8284 -2.8284 -8.437572 1.906823 -3.4443 -8.3151 2 24 4 0 -9 3.6956 -1.5308 -8.6956 2 24 3.6956 -1.5308 -8.6956 2.8284 -2.8284 -8.437572
  • Decimal precision exceeds normal specification for part type
None
2025-02-26 22:29:16
Orientation:
- I chose an orientation like 6572
but might be better to stick to the "know" orientation of the 2L Beam?
5997 I oriented in line with 15459
Rene Rechthaler [Blechtaler]
made the following comment.
2025-02-26 23:07:00
should be Towball instead of Twoball
edited the part header.
2025-02-26 23:23:25
Header Edits
description:
Technic Beam 2L with Twoball
to
Comment:
Indeed, only one ball :-)
You can correct headers as well
2025-02-26 23:27:05
yes, but it is your part, so I waited ;)
LDraw.org Parts Tracker,
