Unofficial File parts/973pz3.dat
0 Minifig Torso with SW Senate Commando Armour (Clone Wars 2009) Pattern
0 Name: 973pz3.dat
0 !CATEGORY Minifig
0 !KEYWORDS Armor, belt, brickLink 973pb0510, republic army, set 8039, set 8128
0 !KEYWORDS soldier, Star Wars
0 // Base Part
0 // Front Pattern
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\973psus01.dat
1 272 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus03.dat
1 272 0 0 0 -1 0 0 0 1 0 0 0 1 s\973psus03.dat
1 272 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus04.dat
1 272 0 0 0 -1 0 0 0 1 0 0 0 1 s\973psus04.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus09.dat
0 // Back Pattern
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus02.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\973psus02.dat
1 272 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus05.dat
1 272 0 0 0 -1 0 0 0 1 0 0 0 1 s\973psus05.dat
1 272 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus06.dat
1 272 0 0 0 -1 0 0 0 1 0 0 0 1 s\973psus06.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus07.dat
1 272 0 0 0 1 0 0 0 1 0 0 0 1 s\973psus08.dat
Needs 2 More Votes (N)
No recorded votesThis part has the following warnings
- Category: Minifig is retired, use suitable active Minifig category
Has Uncertified Subfilesparts/s/973psus01.dat (Needs 2 More Votes)
parts/s/973psus02.dat (Needs 2 More Votes)
parts/s/973psus03.dat (Needs 2 More Votes)
parts/s/973psus04.dat (Needs 2 More Votes)
parts/s/973psus05.dat (Needs 2 More Votes)
parts/s/973psus06.dat (Needs 2 More Votes)
parts/s/973psus07.dat (Needs 2 More Votes)
parts/s/973psus08.dat (Needs 2 More Votes)
parts/s/973psus09.dat (Needs 2 More Votes)
2025-02-28 13:46:17
Jeff Jones [notmaster]
made the following comment.
2025-02-28 14:26:06
https://img.bricklink.com/ItemImage/PN/7/973pb1845c01.png
more differences
more differences
2025-02-28 15:22:00
Your linnk is the updated one from 2015.
This particular one is the original 2009 version (much simpler). BL (and certain other sites) do not differentiate between this and the 2008 Clone Trooper, despite it clearly having dark blue shadows.
2025-03-27 21:35:37
Why have front and back in separate files?
I think you should split the pattern, and reuse them to recreate 973psu. That file need a rework.
The "button" on the back cracks open in hi-res mode, and overlap other areas.
2025-07-12 21:51:04
and its also a 2.0 part
2025-07-24 10:20:42
also agreed magnus
2025-07-31 13:00:34
problem is this is based on eldar's 2.0 pattern, should be completely reworked
2025-08-26 20:16:35
bump again
2025-08-26 21:44:32
It's up my list, just hadn't time yet.
2025-08-26 21:51:19
ok
will update the cody torso when you eady
2025-08-26 21:54:09
Do you have an overview which of all the clone torsos could be based on this?
2025-08-26 22:12:32
phase 2 torso
also subfile i maybe subfile alot when you do it
2025-09-03 01:31:00
2025-09-03 01:35:19
new subfiles used
2025-09-03 21:05:22
Same here. I want to move Armour.
edited the part header.
2025-09-03 22:06:52
Header Edits
description:
Minifig Torso with SW Armour Senate Commando (Clone Wars 2009) Pattern
to
The Clone Trooper uses 2 different shades for the shadows, whilst this seems to use only one. Not sure if there are more tiny differences.
