Unofficial File parts/s/51377s01.dat
View official version of part
~Wheel Rim 14 x 18 with  8 Spokes - Spoke
0 ~Wheel Rim 14 x 18 with 8 Spokes - Spoke 0 Name: s\51377s01.dat 0 Author: Donald Sutter [technog] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2012-07-31 [MagFors] Retitled, recreated condlines 0 !HISTORY 2013-07-21 [PTadmin] Official Update 2013-01 0 !HISTORY 2025-03-07 [Blechtaler] made outside standard res again (to fit the other rims)
1 16 5.1758 -2.845 -7 0 -1 -.3676 0 0 -.5488 2 0 0 rect3.dat 1 16 5.6717 -1.6481 -7 0 -1 .1283 0 0 .6481 -2 0 0 rect3.dat 1 16 0 0 -5 11.7694 0 -2.341 -2.341 0 -11.7694 0 1 0 48\1-16chrd.dat 1 16 0 0 -5 11.7694 0 -2.341 -2.341 0 -11.7694 0 1 0 48\1-16edge.dat 0 BFC INVERTNEXT 1 16 0 0 -7 5.8847 0 -1.1705 -1.1705 0 -5.8847 0 2 0 48\1-16con2.dat 0 BFC INVERTNEXT 1 16 0 0 -7 17.6541 0 -3.5115 -3.5115 0 -17.6541 0 -10 0 48\1-16cylo.dat 1 16 0 0 -17 17.6541 0 -3.5115 -3.5115 0 -17.6541 0 1 0 48\1-16tang.dat 4 16 5.5434 -2.2962 -5 9.9778 -6.667 -5 9.0518 -7.6376 -5 4.8082 -3.3938 -5 3 16 9.9778 -6.667 -5 5.5434 -2.2962 -5 11.7694 -2.341 -5 4 16 11.8012 -1 -5 11.7694 -2.341 -5 5.5434 -2.2962 -5 5.8 -1 -5 4 16 13.2944 -11.8802 -7 9.0518 -7.6376 -5 9.9778 -6.667 -5 14.9668 -10.0005 -7 4 16 13.2944 -11.8802 -7 14.9668 -10.0005 -7 14.9668 -10.0005 -17 13.2944 -11.8802 -17 4 16 17.6541 -3.5115 -7 11.7694 -2.341 -5 11.8012 -1 -5 17.8012 -1 -7 4 16 17.6541 -3.5115 -17 17.6541 -3.5115 -7 17.8012 -1 -7 17.8012 -1 -17 3 16 14.8491 -14.8491 -17 13.2944 -11.8802 -17 14.9668 -10.0005 -17 3 16 14.8491 -14.8491 -17 14.9668 -10.0005 -17 16.9557 -7.0229 -17 3 16 14.8491 -14.8491 -17 16.9557 -7.0229 -17 21 0 -17 3 16 16.9557 -7.0229 -17 17.6541 -3.5115 -17 21 0 -17 3 16 17.6541 -3.5115 -17 17.8012 -1 -17 21 0 -17 2 24 9.0518 -7.6376 -5 9.9778 -6.667 -5 2 24 11.7694 -2.341 -5 11.8012 -1 -5 2 24 14.9668 -10.0005 -7 13.2944 -11.8802 -7 2 24 13.2944 -11.8802 -7 13.2944 -11.8802 -17 2 24 13.2944 -11.8802 -17 14.9668 -10.0005 -17 2 24 17.6541 -3.5115 -7 17.8012 -1 -7 2 24 17.8012 -1 -7 17.8012 -1 -17 2 24 17.8012 -1 -17 17.6541 -3.5115 -17 5 24 9.9778 -6.667 -5 14.9668 -10.0005 -7 13.2944 -11.8802 -7 16.1433 -7.9606 -7 5 24 14.9668 -10.0005 -7 14.9668 -10.0005 -17 13.2944 -11.8802 -17 16.1433 -7.9606 -17 5 24 11.7694 -2.341 -5 17.6541 -3.5115 -7 17.044 -5.7852 -7 17.8012 -1 -7 5 24 17.6541 -3.5115 -7 17.6541 -3.5115 -17 17.044 -5.7852 -17 17.8012 -1 -17 4 16 14.8491 -14.8491 -17 7.7782 -7.7782 -17 8.4854 -7.071 -17 13.2944 -11.8802 -17 1 16 6.2932 -5.586 -13 -1.8386 0 .3536 1.8386 -1 .3536 4 0 0 rect3.dat 4 16 17.8012 -1 -17 11 -1 -17 11 0 -17 21 0 -17 1 16 8.4 -.5 -13 2.6 1 0 0 0 -.5 -4 0 0 rect3.dat 1 16 0 0 -17 21 0 0 0 0 -21 0 1 0 1-8chrd.dat 1 16 0 0 -9 4 0 0 0 0 -4 0 1 0 1-8tndis.dat 4 16 4.101 -4.101 -9 2.8284 -2.8284 -9 4 -2.8284 -9 4.8082 -3.3938 -9 4 16 5.5434 -2.2962 -9 4.8082 -3.3938 -9 4 -2.8284 -9 5.8 -1 -9 4 16 5.8 -1 -9 4 -2.8284 -9 4 0 -9 5.8 0 -9 4 16 5.8 -1 -5 5.8 -1 -9 11 -1 -17 11.8012 -1 -5 4 16 11.8012 -1 -5 11 -1 -17 17.8012 -1 -17 17.8012 -1 -7 4 16 9.0518 -7.6376 -5 8.4854 -7.071 -17 4.8082 -3.3938 -9 4.8082 -3.3938 -5 4 16 13.2944 -11.8802 -7 13.2944 -11.8802 -17 8.4854 -7.071 -17 9.0518 -7.6376 -5 2 24 13.2944 -11.8802 -7 9.0518 -7.6376 -5 2 24 9.0518 -7.6376 -5 4.8082 -3.3938 -5 2 24 5.8 -1 -5 11.8012 -1 -5 2 24 11.8012 -1 -5 17.8012 -1 -7 2 24 13.2944 -11.8802 -17 8.4854 -7.071 -17 2 24 11 -1 -17 17.8012 -1 -17 5 24 5.5434 -2.2962 -5 5.5434 -2.2962 -9 4.8082 -3.3938 -5 5.8 -1 -5
None
Rene Rechthaler [Blechtaler]
2025-03-07 16:21:24
standard res like the other from that family
used unrotated spoke subpart
2025-03-07 17:01:35
synchronized the groove with the similar rims
made the following comment.
2025-11-25 20:17:18
Could you please remove the added condlines? I put them in the base subfile.
2025-11-25 21:37:12
Maybe we should add a few vertices in the inside diameter?
2 24 15.26304223 -9.57302644 -17 16.6302 -6.8886 -17
2 24 13.2944 -11.8802 -17 15.26304223 -9.57302644 -17
2 24 17.56173557 -4.02358043 -17 16.6302 -6.8886 -17
2 24 17.8012 -1 -17 17.56173557 -4.02358043 -17
2025-11-25 23:21:23
removed inner condlines
2025-11-26 17:00:13
How about changing the shape?
2025-11-26 17:14:56
what parts should be hi-res?
as of now everything is hardcoded normal res with a prim in/outside...
you mean the rear inside cone and the outer inverted cyl?
2025-11-26 17:23:25
See my suggested shape above.
2025-11-26 20:48:55
smoother rim inside
This part is copyright © Donald Sutter
LDraw.org Parts Tracker, Magnus Forsberg, Rene Rechthaler
