Unofficial File parts/s/6377s02.dat
~Duplo Train Track Straight  4 x  8 - Track Base
0 ~Duplo Train Track Straight  4 x  8 - Track Base
0 Name: s\6377s02.dat
0 !HISTORY 2013-01-10 [MMR1988] BFC'ed, add license, replace of quads by boxes and rects, rewrite some ares
0 !HISTORY 2024-11-22 [WUIt] Used subfile for tracks, moved origin to point of symmetry, and merged symmetric elements across the split
0 !HISTORY 2025-02-14 [WUIt] Rearranged to more subparts, corrected underside, and removed several T-junctions around middle sleeper
0 !HISTORY 2025-09-18 [WUIt] Subfiled half for symmetry, removed one edge
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6377s05.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 -1 s\6377s05.dat
1 16 54 7 0 14 0 0 0 1 0 0 0 160 rect.dat
4 16 34 0 -40 34 -9 -160 34 -9 160 34 0 40
1 16 35 -9 0 0 0 1 0 1 0 160 0 0 rect.dat
4 16 40 7 -160 40 7 160 36 -9 160 36 -9 -160
2 24 68 8 -160 68 7 -160
2 24 68 8 160 68 7 160
Not releaseable Errors Found (HN) Errors Found (HN)
Hold
Peter Blomberg [WUIt]
2025-03-14 12:15:01
Rearranged and subfiled lines to create more reusable modules. Corrected underside edge reinforcement. Removed several T-junctions around the exterior of the middle and end sleepers. Subfile 6377s01 is reused by 31442. Subfiles 6377s02 and 6377s03 are reused by 31442, 35965, and 5370. Subfile 6377s04 is reused by 35965 and could be reused elsewhere (e.g. track crossings).
edited the part header.
2025-04-30 20:46:05
Header Edits
description:
~Duplo Train Track Straight 4 x 8 (Track Base)
to
Comment:
Changed parenthesis to dash in description
posted a vote of Certify
2025-08-16 17:05:40
Rene Rechthaler [Blechtaler]
made the following comment.
2025-08-16 19:41:56
should the end quads get removed to avoid the overlap in 31442?
Willy Tschager [Holly-Wood]
2025-09-15 07:22:40
* Looks good
2025-09-18 10:15:02
Small change needed to remove overlap with s03. Subfiled for symmetry at the same time.
2025-09-20 06:34:26
* Looks good beside the rects
posted a vote of Hold
2026-09-20 19:25:54
History is wrong, if this is a new file.
Mike isn't the first author, and Max has not edited this file.
2026-09-20 19:36:13
Please try to make a short summary of you edits. Or remove it.
A history line is not needed since this is a new file.
