Unofficial File parts/31180.dat
Duplo Barrel
0 Duplo Barrel
0 Name: 31180.dat
0 !CATEGORY Duplo
0 !KEYWORDS container
0 // top
1 16 0 0 0 5.8 0 0 0 1 0 0 0 5.8 48\4-4ring10.dat
0 // inside
1 16 0 0 0 58 0 0 0 116 0 0 0 58 48\4-4cylo.dat
1 16 0 116 0 2 0 0 0 1 0 0 0 2 48\4-4ring28.dat
1 16 0 116 0 56 0 0 0 8 0 0 0 56 48\4-4cylo.dat
1 16 0 124 0 56 0 0 0 1 0 0 0 56 48\4-4disc.dat
0 // outside
1 16 0 0 0 63.8 0 0 0 11 0 0 0 63.8 48\4-4cylo.dat
1 16 0 11 0 2.2 0 0 0 -1 0 0 0 2.2 48\4-4ring28.dat
1 16 0 54.5 0 1.1 0 0 0 1 0 0 0 1.1 48\4-4ring57.dat
1 16 0 54.5 0 63.8 0 0 0 11 0 0 0 63.8 48\4-4cylo.dat
1 16 0 65.5 0 1.1 0 0 0 -1 0 0 0 1.1 48\4-4ring57.dat
1 16 0 109 0 2.2 0 0 0 1 0 0 0 2.2 48\4-4ring28.dat
1 16 0 120 0 63.8 0 0 0 -11 0 0 0 63.8 48\4-4cylo.dat
1 16 0 120 0 3.9875 0 0 0 -1 0 0 0 3.9875 48\4-4ring15.dat
1 16 0 120 0 59.8125 0 0 0 8 0 0 0 59.8125 48\4-4cylo.dat
1 16 0 128 0 59.8125 0 0 0 -1 0 0 0 59.8125 48\4-4disc.dat
0 // upper planks
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\31180s01.dat
1 16 0 0 0 0 0 1 0 1 0 -1 0 0 s\31180s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\31180s01.dat
1 16 0 0 0 0 0 -1 0 1 0 1 0 0 s\31180s01.dat
0 // lower planks
1 16 0 120 0 1 0 0 0 -1 0 0 0 1 s\31180s01.dat
1 16 0 120 0 0 0 1 0 -1 0 -1 0 0 s\31180s01.dat
1 16 0 120 0 -1 0 0 0 -1 0 0 0 -1 s\31180s01.dat
1 16 0 120 0 0 0 -1 0 -1 0 1 0 0 s\31180s01.dat
0 // bottom cylinders
1 16 0 128 0 40.3 0 0 0 16 0 0 0 40.3 48\4-4cylo.dat
1 16 0 144 0 4.03 0 0 0 -1 0 0 0 4.03 48\4-4ring10.dat
1 16 0 128 0 44.33 0 0 0 16 0 0 0 44.33 48\4-4cylo.dat
1 16 0 128 0 -1 0 0 0 -4 0 0 0 1 stud8.dat
Certify
Willy Tschager [Holly-Wood]
Peter Blomberg [WUIt]
2025-03-22 00:05:39
The subfile is unlikely to be reused anywhere else. The subfile would be repeated eight times if inlined. Having a subfile here saves a lot of lines.
The part has no studs. Chosen top of part for origin. Could easily have been bottom as well.
posted a vote of Hold
2025-04-26 12:39:12
* A cavity like this:
2 368 55.8917 64.5 28.1202 55.892 66.5
cannot be molded. The:
4 16 55.4433 64.5 27.89906 55.89174 64.5 28.1202 56.33402 64.5 27.22332 55.88558 64.5 27.00218
has to be on the same level as the ring. If the two subs are of different height you cannot reuse it on top and bottom.
2025-04-28 01:47:50
Corrected subpart height. The barrel is symmetric.
Removed edges as suggested. Moved edges to subfile as suggested.
posted a vote of Certify
2025-04-28 06:51:07
