Unofficial File parts/973ptj.dat
Minifig Torso with SW Layered Vest with Reddish Brown Undershirt and Dark Brown Belt Pattern
0 Minifig Torso with SW Layered Vest with Reddish Brown Undershirt and Dark Brown Belt Pattern
0 Name: 973ptj.dat
0 Author: Jeff Jones [notmaster]
0 !CATEGORY Minifig
0 !KEYWORDS Anakin Skywalker, Armor, Bricklink 973pb0420, Brickowl 468771
0 !KEYWORDS Rebrickable 973c19h03, Set 7669, set 7675, Set 7931, Set 8037
0 !KEYWORDS set 8098, set 9515, Star Wars, The Clone Wars
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\973ptjs01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\973ptjs01.dat
3 16 -12 0 -10 0 .9 -10 12 0 -10
3 16 0 31.6 -10 -19 32 -10 19 32 -10
4 82 -13.806 24.445 -10 -15.194 24.445 -10 -15.194 30.555 -10 -13.806 30.555 -10
4 82 -11.806 24.145 -10 -13.194 24.145 -10 -13.194 30.255 -10 -11.806 30.255 -10
4 16 -13.806 30.555 -10 -15.194 30.555 -10 -15.665 31.244 -10 -13.435 31.244 -10
3 16 -15.665 29.5 -10 -15.665 31.244 -10 -15.194 30.555 -10
3 16 -13.806 30.555 -10 -13.435 31.244 -10 -13.435 31.044 -10
4 16 -13.194 30.255 -10 -13.806 30.555 -10 -13.435 31.044 -10 -11.235 31.044 -10
3 16 -11.806 30.255 -10 -13.194 30.255 -10 -11.235 31.044 -10
3 16 -11.235 29.5 -10 -11.806 30.255 -10 -11.235 31.044 -10
3 16 -11.235 29.3 -10 -11.806 30.255 -10 -11.235 29.5 -10
4 16 -13.194 24.145 -10 -13.806 24.445 -10 -13.806 30.555 -10 -13.194 30.255 -10
3 16 -15.665 24 -10 -15.194 24.445 -10 -13.806 24.445 -10
3 16 -15.665 24 -10 -15.665 25.6 -10 -15.194 24.445 -10
3 16 -15.194 24.445 -10 -15.665 25.6 -10 -15.665 25.9 -10
3 16 -15.665 27.7 -10 -15.665 29.3 -10 -15.194 30.555 -10
3 16 -15.665 29.3 -10 -15.665 29.5 -10 -15.194 30.555 -10
4 16 -15.194 24.445 -10 -15.665 25.9 -10 -15.665 27.5 -10 -15.194 30.555 -10
3 16 -15.665 27.5 -10 -15.665 27.7 -10 -15.194 30.555 -10
4 16 -11.235 27.5 -10 -11.806 24.145 -10 -11.806 30.255 -10 -11.235 27.7 -10
3 16 -11.235 27.7 -10 -11.806 30.255 -10 -11.235 29.3 -10
3 16 -11.806 24.145 -10 -11.235 25.9 -10 -11.235 25.6 -10
3 16 -11.806 24.145 -10 -11.235 27.5 -10 -11.235 25.9 -10
3 308 13 24 -10 11.235 24 -10 11.235 25.6 -10
3 308 15.665 24 -10 13.4 24 -10 15.665 25.6 -10
4 308 13.4 24 -10 13 24 -10 11.235 25.6 -10 15.665 25.6 -10
4 16 15.665 25.9 -10 15.665 25.6 -10 11.235 25.6 -10 11.235 25.9 -10
4 308 15.665 25.9 -10 11.235 25.9 -10 11.235 27.5 -10 15.665 27.5 -10
4 16 15.665 27.7 -10 15.665 27.5 -10 11.235 27.5 -10 11.235 27.7 -10
4 308 15.665 29.3 -10 15.665 27.7 -10 11.235 27.7 -10 11.235 29.3 -10
4 16 15.665 29.5 -10 15.665 29.3 -10 11.235 29.3 -10 11.235 29.5 -10
4 308 15.665 29.5 -10 11.235 29.5 -10 11.235 31.044 -10 13.435 31.044 -10
4 308 13.435 31.044 -10 13.435 31.244 -10 15.665 31.244 -10 15.665 29.5 -10
3 16 -11.235 24 -10 -11.806 24.145 -10 -11.235 25.6 -10
3 16 -13.4 24 -10 -15.665 24 -10 -13.806 24.445 -10
3 16 -13.4 24 -10 -13.806 24.445 -10 -13.194 24.145 -10
3 16 -13.4 24 -10 -13.194 24.145 -10 -13 24 -10
3 16 -13 24 -10 -13.194 24.145 -10 -11.806 24.145 -10
3 16 -13 24 -10 -11.806 24.145 -10 -11.235 24 -10
2025-04-23 23:45:11
3rd part made in ldpc
posted a vote of Hold
2025-04-24 15:02:39
*"outlines" for the golden rectangles on the bel should have a mire similar thickness (center stripe and outsides equal)
*the corner indent on the left crease's bottom is not present on all image of this print, I think is caused by print mis-alignment, causing an overlap with a base layer for the golden ink. Probably this should look more like the right side.
made the following comment.
2025-04-24 20:43:39
Why is this called "... DBG Armour Lines and Wrinkles ..."?
BL = Torso SW Layered Vest with Belt Pattern (Anakin Clone Wars)
RB = Torso SW Layered Vest with Belt Print (Anakin Clone Wars)
2025-04-25 21:52:31
2025-04-25 21:54:33
2025-04-26 05:40:05
Please explain why Armour is relevant in this description.
2025-04-26 08:34:06
2025-04-27 16:57:37
2025-04-27 17:00:54
fixed description
2025-05-28 09:05:03
