Unofficial File parts/65186.dat
0 Car Base 4 x 10 x 1.333 with 4 x 2 Recessed Center and 4 Pin Holes
0 Name: 65186.dat
0 !CATEGORY Car
0 !KEYWORDS Dragon body, Vehicle
0 !HISTORY 2021-04-27 [Sirio] File preparation for LDraw Parts Tracker
0 !HISTORY 2021-04-29 {LEGO/Unity Microgame} Original part shape
0 // Subparts
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\65186s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\65186s01.dat
0 // Primitives
1 16 -30 0 0 0 0 -1 0 1 0 1 0 0 stug2-1x2.dat
1 16 30 0 0 0 0 -1 0 1 0 1 0 0 stug2-1x2.dat
1 16 -10 24 0 0 0 -1 0 1 0 1 0 0 stug-1x4.dat
1 16 10 24 0 0 0 -1 0 1 0 1 0 0 stug-1x4.dat
1 16 0 28 0 1 0 0 0 -3 0 0 0 1 stud4a.dat
1 16 0 28 0 8 0 0 0 -1 0 0 0 8 4-4ndis.dat
1 16 0 24 0 6 0 0 0 1 0 0 0 6 4-4ndis.dat
1 16 0 24 0 6 0 0 0 1 0 0 0 6 4-4edge.dat
1 16 0 24 0 6 0 0 0 4 0 0 0 6 4-4cyli.dat
1 16 0 28 0 8 0 0 0 1 0 0 0 8 4-4edge.dat
1 16 -20 28 0 0 0 1 0 -3 0 1 0 0 2-4stud4.dat
1 16 20 28 0 0 0 -1 0 -3 0 1 0 0 2-4stud4.dat
Needs 2 More Votes (N)
No recorded votesThis part has the following warnings
Has Uncertified Subfiles
Massimo Maso [Sirio]
2025-04-27 16:09:13
Jeff Jones [notmaster]
made the following comment.
2025-04-27 16:55:56
maybe add dragon in the keywords since it was introduced as the body for a ninjago dragon.
Rene Rechthaler [Blechtaler]
2025-04-27 17:49:44
I would rather change "Car" to "Vehicle"
2025-04-28 17:34:16
Swapped subparts namee. Used s01 (new) only two times in main part, and s02 (new) two times in s01 (new).
edited the part header.
2025-04-28 17:38:57
Header Edits
keywords:
to
2025-04-28 17:41:54
I added the KEYWORDS Dragon and Vehicle. For me the description "Car base" is better because we have more parts referred to as "Car base" than as "Vehicle". Currently the parts referred to as "Vehicle" are actually "Car base" of the Fabuland series.
2025-04-28 17:56:30
Header Edits
description:
Car Base 4 x 10 x 1.3333 with 4 x 2 Recessed Center and 4 Pin Holes
to
2025-04-29 16:48:31
Of the 9 sets using this part, none is Car.
Aircrafts, Airboats or Dragon body seams to be the current use.
4 parts use "Vehicle Base ...", 1 is unofficial.
5 parts use "Vehicle Chassis ...", 1 is unofficial.
2025-04-29 17:24:42
Moved some stud primitves from main part to subparts.
2025-04-29 17:54:26
Choose the description you prefer.
2025-04-29 17:59:00
i would prefer "Vehicle Base"
(yes you could slap some wheels on the pinholes but that would result in some funny car/boat hybrid.
Plane is too specialized, and a Dragon can also be ridden -> Vehicle)
2025-04-29 17:59:55
(if you got a decision, you dont need to upload everything again, ask for Headeredit)
