Unofficial File parts/3808.dat
Duplo Plate  2 x  4 x  0.333 Half Circle with 2 Studs
0 Duplo Plate  2 x  4 x  0.333 Half Circle with 2 Studs
0 Name: 3808.dat
0 Author: Chris Dee [cwdee]
0 !CATEGORY Plate
0 !HISTORY 2020-05-25 [PTadmin] Update description
0 !HISTORY 2025-04-30 [WUIt] CCW'd BFC, used more prims, removed microgaps
0 // top
1 16 20 0 0 1 0 0 0 2.75 0 0 0 1 stud7.dat
1 16 -20 0 0 1 0 0 0 2.75 0 0 0 1 stud7.dat
1 16 0 0 -20 80 0 0 0 1 0 0 0 80 48\2-4chrd.dat
0 // sides
1 16 0 0 -20 80 0 0 0 16 0 0 0 80 48\2-4cylo.dat
1 16 0 8 -20 -80 0 0 0 0 8 0 1 0 rect.dat
0 // bottom
1 16 0 4 20 1 0 0 0 -1.75 0 0 0 1 stug8-1x3.dat
1 16 0 16 -20 4 0 0 0 -1 0 0 0 4 48\2-4ring19.dat
4 16 -75.7364 16 -16 75.7364 16 -16 76 16 -20 -76 16 -20
2 24 75.7364 4 -16 75.3464 4 -10.082
2 24 75.7364 16 -16 75.3464 16 -10.082
4 16 75.3464 4 -10.082 75.3464 16 -10.082 75.7364 16 -16 75.7364 4 -16
2 24 -75.7364 4 -16 -75.3464 4 -10.082
2 24 -75.7364 16 -16 -75.3464 16 -10.082
4 16 -75.3464 16 -10.082 -75.3464 4 -10.082 -75.7364 4 -16 -75.7364 16 -16
1 16 0 10 -16 75.7364 0 0 0 0 6 0 -1 0 rect.dat
1 16 0 4 -20 0 0 76 0 12 0 76 0 0 48\11-48cylo.dat
1 16 0 4 -20 0 0 -76 0 12 0 76 0 0 48\11-48cylo.dat
1 16 0 4 -20 0 0 76 0 -1 0 76 0 0 48\11-48chrd.dat
1 16 0 4 -20 0 0 -76 0 -1 0 76 0 0 48\11-48chrd.dat
4 16 75.3464 4 -10.082 75.7364 4 -16 -75.7364 4 -16 -75.3464 4 -10.082
3 16 -75.3464 4 -10.082 0 4 56 75.3464 4 -10.082
1 16 60 9.5 -16 1.5 0 0 0 0 5.5 0 4 0 box4-1.dat
1 16 20 9.5 -16 1.5 0 0 0 0 5.5 0 4 0 box4-1.dat
1 16 -20 9.5 -16 1.5 0 0 0 0 5.5 0 4 0 box4-1.dat
1 16 -60 9.5 -16 1.5 0 0 0 0 5.5 0 4 0 box4-1.dat
1 16 20 9.5 56 1.5 0 0 0 0 5.5 0 -4 0 box4-1.dat
1 16 76 9.5 0 0 -4 0 0 0 5.5 -1.5 0 0 box4-1.dat
2 24 73.4084 15 -.3312 72.7877 15 1.5
2 24 73.6407 15 -1.5 73.4084 15 -.3312
2 24 72.7877 4 1.5 72.7877 15 1.5
2 24 73.6407 15 -1.5 73.6407 4 -1.5
2 24 18.5 15 53.6407 19.6688 15 53.4084
2 24 19.6688 15 53.4084 21.5 15 52.7877
2 24 18.5 15 53.6407 18.5 4 53.6407
2 24 21.5 15 52.7877 21.5 4 52.7877
1 16 -20 9.5 56 -1.5 0 0 0 0 5.5 0 -4 0 box4-1.dat
1 16 -76 9.5 0 0 4 0 0 0 5.5 -1.5 0 0 box4-1.dat
2 24 -72.7877 15 1.5 -73.4084 15 -.3312
2 24 -73.4084 15 -.3312 -73.6407 15 -1.5
2 24 -72.7877 15 1.5 -72.7877 4 1.5
2 24 -73.6407 4 -1.5 -73.6407 15 -1.5
2 24 -19.6688 15 53.4084 -18.5 15 53.6407
2 24 -21.5 15 52.7877 -19.6688 15 53.4084
2 24 -18.5 4 53.6407 -18.5 15 53.6407
2 24 -21.5 4 52.7877 -21.5 15 52.7877
Peter Blomberg [WUIt]
2025-04-30 07:51:13
Made BFC compliant
Rene Rechthaler [Blechtaler]
made the following comment.
2025-04-30 10:59:55
should the inside get changed to unrotated 11-48 prims? instead of the rotated 11-24
2025-04-30 15:29:20
A minor detail, don't know of the imprortance. This fils was already "BFC compliant", but you change it from CW to CCW.
Maybe the history should be corrected?
2025-04-30 16:21:28
Increased the use of primitives as suggested.
2025-04-30 16:26:58
Corrected history line as suggested.
Gerald Lasser [GeraldLasser]
posted a vote of Hold
2025-10-28 23:08:52
There are four fillets missing along the semi circle, those allow for more connection variants
1 9 20 9.5 56 1.5 0 0 0 0 5.5 0 -4 0 box4-1.dat
1 9 -20 9.5 56 1.5 0 0 0 0 5.5 0 -4 0 box4-1.dat
1 9 -76 3.5 0 0 4 0 0 0 5.5 -1.5 0 0 box4-1.dat
1 9 76 3.5 0 0 -4 0 0 0 5.5 -1.5 0 0 box4-1.dat
2025-11-13 07:03:00
Added the four missing fillets as suggested.
