Unofficial File p/48/3-16cyls.dat
Hi-Res Cylinder Sloped 0.1875
0 Hi-Res Cylinder Sloped 0.1875 0 Name: 48\3-16cyls.dat 0 Author: Peter Blomberg [WUIt] 0 !LDRAW_ORG Unofficial_48_Primitive 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
3 16 1 0 0 0.9914 0.0086 0.1305 0.9914 0 0.1305 4 16 0.9914 0.0086 0.1305 0.9659 0.0341 0.2588 0.9659 0 0.2588 0.9914 0 0.1305 4 16 0.9659 0.0341 0.2588 0.9239 0.0761 0.3827 0.9239 0 0.3827 0.9659 0 0.2588 4 16 0.9239 0.0761 0.3827 0.866 0.1340 0.5 0.866 0 0.5 0.9239 0 0.3827 4 16 0.866 0.1340 0.5 0.7934 0.2066 0.6088 0.7934 0 0.6088 0.866 0 0.5 4 16 0.7934 0.2066 0.6088 0.7071 0.2929 0.7071 0.7071 0 0.7071 0.7934 0 0.6088 4 16 0.7071 0.2929 0.7071 0.6088 0.3912 0.7934 0.6088 0 0.7934 0.7071 0 0.7071 4 16 0.6088 0.3912 0.7934 0.5 0.5 0.866 0.5 0 0.866 0.6088 0 0.7934 4 16 0.5 0.5 0.866 0.3827 0.6173 0.9239 0.3827 0 0.9239 0.5 0 0.866 5 24 0.9914 0 0.1305 0.9914 0.0086 0.1305 1 0 0 0.9659 0 0.2588 5 24 0.9659 0 0.2588 0.9659 0.0341 0.2588 0.9914 0 0.1305 0.9239 0 0.3827 5 24 0.9239 0 0.3827 0.9239 0.0761 0.3827 0.9659 0 0.2588 0.866 0 0.5 5 24 0.866 0 0.5 0.866 0.1340 0.5 0.9239 0 0.3827 0.7934 0 0.6088 5 24 0.7934 0 0.6088 0.7934 0.2066 0.6088 0.866 0 0.5 0.7071 0 0.7071 5 24 0.7071 0 0.7071 0.7071 0.2929 0.7071 0.7934 0 0.6088 0.6088 0 0.7934 5 24 0.6088 0 0.7934 0.6088 0.3912 0.7934 0.7071 0 0.7071 0.5 0 0.866 5 24 0.5 0 0.866 0.5 0.5 0.866 0.6088 0 0.7934 0.3827 0 0.9239 5 24 .3827 0 .9239 .3827 0.6173 .9239 .5 0 .866 .2611 0 .9743
  • Numbers cannot have trailing zeros (except one zero immediately after a decimal point)
    Line 12: 4 16 0.9239 0.0761 0.3827 0.866 0.1340 0.5 0.866 0 0.5 0.9239 0 0.3827
    Line 13: 4 16 0.866 0.1340 0.5 0.7934 0.2066 0.6088 0.7934 0 0.6088 0.866 0 0.5
    Line 22: 5 24 0.866 0 0.5 0.866 0.1340 0.5 0.9239 0 0.3827 0.7934 0 0.6088
    Line :
User Vote
Holly-Wood Certify
2025-05-08 13:28:25
made the following comment.
2025-05-24 12:34:46
Shouldn't the last condline have a controlpoint on the tangental plane?
posted a vote of Hold
2025-05-24 14:17:49
Yes, how can that be fixed?
2025-05-24 23:38:39
Corrected last cond line to tangential as required.
2025-05-25 07:54:51
Do any of the files that use this primitive need to be changed?
Complementary condlines?
2025-05-25 08:26:46
Only one part uses this primitive and that part is on the tracker.
Willy Tschager [Holly-Wood]
posted a vote of Certify
2025-10-04 12:31:38
Rene Rechthaler [Blechtaler]
2026-01-18 11:34:04
0.1340 causes an error (3x, 2 quads one cond)
This part is copyright © Peter Blomberg
