Unofficial File parts/87552p02.dat
Panel  1 x  2 x  2 Reinforced with White Curved Right Corner Pattern
0 Panel  1 x  2 x  2 Reinforced with White Curved Right Corner Pattern
0 Name: 87552p02.dat
0 Author: Ulrich Röder [UR]
0 !CATEGORY Panel
0 !KEYWORDS Bricklink 87552pb070L, Brickowl 963825, Brickset 78293, Porsche
0 !KEYWORDS Rebrickable 87552pr0012, Set 10295
0 !CMDLINE -c47
0 !HISTORY 2025-05-11 [Blechtaler] added NOCLIP
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\87552s01.dat
1 16 19.5 20 10 0 0 -39 -20 0 0 0 -1 0 48\1-4chrd.dat
4 16 -20 48 10 -19.5 20 10 19.5 0 10 20 48 10
4 16 -20 0 10 -19.5 0 10 -19.5 20 10 -20 48 10
3 16 19.5 0 10 20 0 10 20 48 10
0 BFC NOCLIP
1 15 19.5 20 10 0 0 -39 -20 0 0 0 -1 0 48\1-4ndis.dat
Rene Rechthaler [Blechtaler]
2025-05-11 20:40:31
added NOCLIP
edited the part header.
2025-05-12 11:05:47
Header Edits
description:
Panel 1 x 2 x 2 Reinforced with White Curved Corner - Left Aligned Pattern
to
Panel 1 x 2 x 2 Reinforced with White Curved Corner - Left Side Pattern
Comment:
changed "aligned" to "Side" (because the part is used on the left side of the model, but the print is on the "right" side, when viewed from the patterned side)
Orion Pobursky [OrionP]
2025-05-12 13:52:42
Header Edits
description:
to
Panel 1 x 2 x 2 Reinforced with White Curved Left Corner Pattern
2025-05-12 15:35:13
Header Edits
description:
to
Panel 1 x 2 x 2 Reinforced with White Curved Right Corner - Left Side Pattern
Comment:
the (upper) right corner is white, but the part is used on the Left side
made the following comment.
2025-05-12 17:03:46
I edited this specifically to remove the dash which you just reverted without discussion.
2025-05-12 17:29:33
edited it again because without the dash - side and position were too close and could get mixed up
(the pattern is on the Right side of the part, but used on the Left side of the Set)
(sorry if that sounded too rude)
2025-05-12 17:53:44
Only the design on the part is relevant. Where on the model it is, is not.
I gave up that argument years ago.
Gerald Lasser [GeraldLasser]
2025-05-12 19:47:14
I agree with Magnus, if you look at it, the curve is on the top right
2025-05-12 20:08:18
should we delete the part position and just keep the print position?
(even if the left/right is then flipped?)
2025-05-12 21:46:43
Header Edits
description:
to
2025-05-12 22:00:15
If you look at the part, where is it? that should count imho
2026-04-28 10:37:24
without studs (now in subpart)
