0 ~Panel 1 x 2 x 2 with Phone in White Circle and Lines Pattern (Obsolete)
0 Name: 4864bp71.dat
0 !CATEGORY Obsolete
0 !KEYWORDS Bricklink 4864apx15, Rebrickable 4864apr0012, Set 6422
0 !HISTORY 2010-04-05 [PTadmin] Official Update 2010-01
0 !HISTORY 2022-06-22 [Philo] Updated description, added keywords
0 !HISTORY 2025-05-11 [Blechtaler] added NOCLIP
0 !HISTORY 2025-05-12 [Blechtaler] Obsoleted due to wrong part version (use 4864ap71.dat)
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\4864s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 stug2-1x2.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\4864p71s01.dat
Has uncertified subfiles
| User | Vote |
| RainbowDolphin | Certify |
It only ever came in 1 set: 6422, which was a limited release as far as I can tell (mine did come with solid studs).
Note that the transparent version of this part is technically a different mold (since it's PC not ABS), and said mold was updated later than the solid color version.
Either this part does not exist in this version or the pattern should be sub-filed for re-use in the solid stud version (which is proven to exist, see RB and BO links).
pattern itself is ok?
should this be a moved to? (to the correct studded part)
which part number should that one have? 4864ap15.dat (like BL/peeron)?
maybe instead obsoleting this it gets turned into 4864bpr0002 or 4864bpr0016
I don't think it matters much which part number the solid stud version gets (as long as it's 4864ap something).
Someone might have placed some bar-sized thing in the hollow studs, so the correct way must be to obsolete the old.
Or is it? Does a change from hollow to solid studs count as a change of geometry?
As you said, someone might have put something in the studs.
Not sure, if it makes a difference in this case if it's changed geometry or not - there are going to be two different parts anyways.
This part is copyright ©
Michael Heidemann
Licensed under
CC BY 4.0
LDraw.org Parts Tracker,
Philippe Hurbain, Rene Rechthaler
