Unofficial File parts/s/3070bpz2s01.dat
~Tile  1 x  1 with 15 Metallic Silver Dots Pattern - Patterned Face Quarter
0 ~Tile 1 x 1 with 15 Metallic Silver Dots Pattern - Patterned Face Quarter 0 Name: s\3070bpz2s01.dat 0 Author: Gabriel Läufer [Dr.Bricktacular] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
0 // Pattern 1 80 0 0 6.6 0 0 1.4 0 1 0 -1.4 0 0 2-4disc.dat 1 80 0 0 3.3 0 0 1.4 0 1 0 -1.4 0 0 2-4disc.dat 1 80 0 0 0 1.4 0 0 0 1 0 0 0 1.4 1-4disc.dat 1 80 4.5 0 0 1.4 0 0 0 1 0 0 0 1.4 2-4disc.dat 1 80 4.5 0 3.3 1.4 0 0 0 1 0 0 0 1.4 4-4disc.dat 1 80 4.5 0 6.6 1.4 0 0 0 1 0 0 0 1.4 4-4disc.dat 1 16 0 0 6.6 0 0 1.4 0 1 0 -1.4 0 0 2-4ndis.dat 1 16 0 0 3.3 0 0 1.4 0 1 0 -1.4 0 0 2-4ndis.dat 1 16 0 0 0 1.4 0 0 0 1 0 0 0 1.4 1-4ndis.dat 1 16 4.5 0 0 1.4 0 0 0 1 0 0 0 1.4 2-4ndis.dat 1 16 4.5 0 6.6 1.4 0 0 0 1 0 0 0 1.4 4-4ndis.dat 1 16 4.5 0 3.3 1.4 0 0 0 1 0 0 0 1.4 4-4ndis.dat 4 16 3.1 0 8 1.4 0 8 1.4 0 6.6 3.1 0 6.6 4 16 3.1 0 6.6 1.4 0 6.6 1.4 0 5.2 3.1 0 5.2 4 16 3.1 0 4.7 1.4 0 4.7 1.4 0 3.3 3.1 0 3.3 4 16 3.1 0 1.4 1.4 0 1.4 1.4 0 0 3.1 0 0 4 16 4.5 0 5.2 3.1 0 5.2 3.1 0 4.7 4.5 0 4.7 4 16 5.9 0 5.2 4.5 0 5.2 4.5 0 4.7 5.9 0 4.7 4 16 1.4 0 4.7 3.1 0 4.7 3.1 0 5.2 1.4 0 5.2 4 16 1.4 0 1.9 0 0 1.9 0 0 1.4 1.4 0 1.4 4 16 3.1 0 1.9 1.4 0 1.4 3.1 0 1.4 4.5 0 1.9 4 16 4.5 0 1.9 3.1 0 1.4 4.5 0 1.4 5.9 0 1.9 3 16 5.9 0 1.9 4.5 0 1.4 5.9 0 1.4 3 16 10 0 10 0 0 8 1.4 0 8 3 16 10 0 10 1.4 0 8 3.1 0 8 3 16 10 0 10 3.1 0 8 4.5 0 8 3 16 10 0 10 4.5 0 8 5.9 0 8 3 16 1.4 0 5.2 0 0 4.7 1.4 0 4.7 4 16 3.1 0 3.3 1.4 0 3.3 1.4 0 1.9 3.1 0 1.9 3 16 3.1 0 1.9 1.4 0 1.9 1.4 0 1.4 3 16 10 0 10 5.9 0 1.4 5.9 0 0 3 16 10 0 10 5.9 0 1.9 5.9 0 1.4 3 16 10 0 10 5.9 0 3.3 5.9 0 1.9 3 16 10 0 10 5.9 0 4.7 5.9 0 3.3 3 16 10 0 10 5.9 0 5.2 5.9 0 4.7 3 16 10 0 10 5.9 0 6.6 5.9 0 5.2 3 16 10 0 10 5.9 0 8 5.9 0 6.6 3 16 0 0 8 10 0 10 0 0 10 3 16 10 0 10 5.9 0 0 10 0 0 3 16 0 0 5.2 0 0 4.7 1.4 0 5.2
User Vote
RainbowDolphin Certify
Part Reviewer
2025-05-28 09:20:15
posted a vote of Hold.
2025-05-28 09:55:43
Why is this sub-file needed?
Rene Rechthaler [Blechtaler]
made the following comment.
2025-05-28 09:57:57
why a separate subpart? should this get inlined or will this be reused?
subpart would be ok for parts of patterns which are then used multiple times in the main part
(this could be cut to a quarter, for example keep the +x+z corner and cut the rest)
Part Reviewer
2025-05-28 19:30:20
Cut to a quarter (54200py0.dat/54200py0s01.dat very confusing when to use subparts, primitves or simply inline the pattern).
2025-05-28 20:59:47
some of the quads between the ndis could be changed to rectangles (no prims, just rectangular)
posted a vote of Certify.
2025-10-13 10:59:51
edited the part header.
2025-10-13 15:37:57
Header Edits
help:
0 !HELP
to
0 !HELP
description:
to
Massimo Maso [Sirio]
2025-10-14 16:01:01
You could save some vertex by replacing 2-4disc with 2-4chrd and 1-4disc with 1-4chrd. (You have to add a square in main part).
The face count unfortunately will not change.
This part is copyright © Gabriel Läufer
LDraw.org Parts Tracker,
